Kodi as a replacement for WMC - AVS Forum | Home Theater Discussions And Reviews
 13Likes
  • 1 Post By mdavej
  • 1 Post By smcmillan2
  • 1 Post By fullhorn
  • 1 Post By Nobr8ks
  • 2 Post By SirMaster
  • 1 Post By captain_video
  • 1 Post By Nobr8ks
  • 1 Post By byebye_cable
Old 11-03-2019, 02:42 PM - Thread Starter
byebye_cable's Avatar
Quoted: 20 Post(s)
Anyone try this (Kodi instead of WMC)?
Article below indicates Kodi works with tuner cards & has an EPG (guide) but is short on details.
https://www.howtogeek.com/132462/5-a...-on-windows-8/
With support for windows 7 stopping I suppose the options are the hacked WMC for windows 10 or (perhaps) Kodi?
byebye_cable is offline
Old 11-03-2019, 03:13 PM
mdavej's Avatar
Quoted: 3104 Post(s)
Liked: 1408
Problem with all WMC replacements is none of them can record copy protected cable channels.
If I were looking to replace WMC, I'd dump the PC altogether and go with something like Channels or Amazon Recast (if you need only OTA). Running Kodi on a PC doesn't have much appeal to me.
byebye_cable likes this.
mdavej is offline
Old 11-03-2019, 04:11 PM - Thread Starter
Quoted: 20 Post(s)
Thank you. I don't have cable, just a couple antenna's (one for us channels another for canada). So this limitation won't bother me then?
Old 11-03-2019, 04:23 PM
smcmillan2's Avatar
Quoted: 953 Post(s)
Liked: 815
Errm, no. There is no DRM'd content on OTA.
Last I looked into Kodi it didn't directly support Live TV, that has changed? (I didn't read through the entire link). I still use MythTV with SchedulesDirect for EPG.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is offline
Old 11-03-2019, 05:10 PM
fullhorn's Avatar
Quoted: 27 Post(s)
Liked: 58
I have two HD Homerun network tuners (OTA) and use Kodi on five computers at the house. I pay $35? a year for guide data through Silicondust (tuner manufacturer). Works good.
fullhorn is offline
Old 11-03-2019, 05:39 PM - Thread Starter
Quoted: 20 Post(s)
My religion doesn't let me pay for EPG. Also I have hauppauge cards.
Old 11-03-2019, 07:15 PM
fullhorn's Avatar
Quoted: 27 Post(s)
Liked: 58
The guide goes with the "DVR" service. I think the religious convictions will leave you SOL on "Free" Kodi. Although if you find a solution, post it here and I will definitely convert.
fullhorn is offline
Old 11-03-2019, 07:45 PM
Quoted: 41 Post(s)
I have RaspberryPi's connected to our TV's (ARC/CEC work good) that work with HDHR Prime regardless if WMC works.
2 PVR Clients on Pi's
ServerWMC & Unofficial HDHomeRun from Kodi (Magically provides channel icons)
Magically (Guessing from FiOS) when WMC powers off I still have an EPG.
Physically my WMC box isn't going anywhere (Headless on shelf). Without an EPG I could still set timers for recordings.
No plans on replacement.
Nobr8ks is offline
Old 11-04-2019, 04:38 PM - Thread Starter
Quoted: 20 Post(s)
I promise.
If I fail though, where is the link for for giving someone my hard-earned ~35 for EPG? I googled but did not find.
Old 11-04-2019, 04:45 PM
SirMaster's Avatar
Quoted: 789 Post(s)
Liked: 485
Kodi natively supports Live TV and being a DVR as a front end. You will still need an appropriate back-end, but there are a bunch to choose from.
smcmillan2 and byebye_cable like this.
SirMaster is offline
Old 11-04-2019, 05:24 PM
smcmillan2's Avatar
Quoted: 953 Post(s)
Liked: 815
I promise.
$25/year. http://www.schedulesdirect.org/
Old 11-04-2019, 05:30 PM
smcmillan2's Avatar
Quoted: 953 Post(s)
Liked: 815
I mis-worded my question, I meant to ask if Kodi now handled the backend portion of Live TV.
Been running a MythTV setup since 2006 so we're very used to the interface and will likely be sticking with it in the foreseeable future, but always good to keep tabs on the other offerings out there.
Thanks for the reply!
Old 11-04-2019, 06:07 PM
fullhorn's Avatar
Quoted: 27 Post(s)
Liked: 58
I promise.
Here is the service.
https://shop.silicondust.com/shop/?_...588.1571100076
Then there is some hdhr "add in" stuff on kodi that makes the dvr and tv recording way better than hdhr's stuff on its own.
Link stops short, click DVR software activation.
fullhorn is offline
Old 11-04-2019, 07:31 PM - Thread Starter
Quoted: 20 Post(s)
looks pretty good, since i'm in toronto i can pull in both usa & canada ota stations..by any chance does someone know if that is "supported" with kodi/schedulesdirect?
Old 11-05-2019, 06:07 AM
captain_video's Avatar
Quoted: 731 Post(s)
Liked: 427
If you use epg123 with a Schedules Direct subscription there's no need to replace WMC. I've been using it for a couple of years now and have no reason to get rid of WMC. I have broken ties with Microsoft and have become fully independent and no longer have to worry about whether or not they continue support for Windows 7. I can keep using it for as long as my computer survives.
Nobr8ks likes this.
captain_video is offline
Old 11-05-2019, 05:33 PM - Thread Starter
Quoted: 20 Post(s)
enjoy the chinese hackers infiltrating your home network thru your windows 7 machine
Old 11-06-2019, 11:15 AM
Mark Guebert's Avatar
Quoted: 48 Post(s)
Liked: 32
Why would that happen unless he has ports open on his firewall. Most people here I would venture have a separate firewall that would prevent that from happening.
Mark Guebert is offline
Old 11-06-2019, 05:23 PM
Quoted: 41 Post(s)
My Chinese wife says you have an E4200 Linksys router.
Nobr8ks is offline
Old 11-06-2019, 05:25 PM - Thread Starter
Quoted: 20 Post(s)
I mentioned it to her last night
Nobr8ks likes this.
Old 11-06-2019, 08:05 PM
smcmillan2's Avatar
Quoted: 953 Post(s)
Liked: 815
Anyone that has any idea how to run an HTPC properly knows how to keep it protected.
Troll somewhere else.
Old 11-07-2019, 05:40 AM
Quoted: 731 Post(s)
Liked: 427
Yeah. I'd hate for the Chinese to get hold of my TV recording schedule.
Old 11-07-2019, 06:38 AM - Thread Starter
Quoted: 20 Post(s)
All in fun which i think Nobr8ks understands
All kidding aside there seems to be a cavalier attitude towards leaving a windows 7 pc attached to your home network. That's a non-starter for me.
Old 11-07-2019, 11:21 AM
Quoted: 41 Post(s)
Wasn't obvious?
As for using protection, I've been using IPFire.
https://en.wikipedia.org/wiki/IPFire
Nobr8ks is offline
Old 11-07-2019, 08:56 PM
Liked: 0
If you decide to go the serverwmc route just be aware that Kodi might have dropped support for it in version 18 when they dropped support for wtv file playback. That would be something to confirm and I vaguely remember reading about it. I would look at nextpvr. Im coming from wmc to Kodi but I have hdhomerun tuners so that makes my life easier.
Jachin99 is offline
Old 11-07-2019, 10:58 PM
Krispy Kritter's Avatar
Quoted: 73 Post(s)
Liked: 31
It's only an issue if 1) you are using said WMC box to access the internet, such as with a browser or 2) if other devices on your network are not secure (ie: they hack into another box on your network and then access the WMC box).
You have a MUCH higher risk of any of your IoT devices being hacked than a WMC box that is only used for WMC.
Krispy Kritter is offline
Old 11-08-2019, 05:43 PM
grittree's Avatar
Quoted: 467 Post(s)
Liked: 288
Well, he only said that "he" wouldn't use Win7. For him, that might be appropriate.
grittree is offline
