MadVR + MPC-HC Crush Blacks on my PX65 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-16-2019, 06:59 AM - Thread Starter
Quoted: 16 Post(s)
Liked: 0
Hi all. I'm new here so if I'm not supposed to post this here feel free to delete or move me around.
I'm using MadVR with MPC-HC and got it setup using the advanced guide here on AVS. I've gotten everything nailed down except for black levels. With my Vizio PX65-G1 blacks are getting crushed. Ive only tried my Blu-ray rips so far (full MakeMKV rips). MadVR output resolutions/frame rates are setup properly and RGB output is set to the following:
MadVR: Full
MPC-HC: Full
Nvidia Driver: RGB Full 12-Bit
When I try pretty much anything else blacks become gray but I can see a lot more detail. Black crush isn't an issue with other sources. Any ideas?
Specs:
Intel 6th Gen i5
16GB RAM
Nvidia GTX 1070
danni13 is offline
post #2 of 2 Old 11-16-2019, 08:26 AM
markmon1's Avatar
Quoted: 5444 Post(s)
Liked: 3562
MadVR: Full
MPC-HC: Full
Specs:
Intel 6th Gen i5
16GB RAM
Nvidia GTX 1070
Look for or create from png an mkv that is a black pattern generator that shows the numbers and lines like this image:
https://i.rtings.com/images/reviews/...-min-large.jpg
When it plays, you should *barely* see 17 but not 16. If that's working then your blacks aren't crushed - you're just use to raised blacks. If not, then either adjust the brightness until it's right or debug why it's not.
Your Full/Full/Full RGB sounds good - is how I run my setup.
For kicks you could try desktop limited, madvr full, display limited and see how that looks.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
Reply Home Theater Computers
