MKV Audio Problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-17-2019, 02:24 PM - Thread Starter
Liked: 0
MKV Audio Problem
I built a new HTPC with an AMD chipset running the latest version of Windows 10. I’ve got a weird problem with the audio in MKVs.
My HTPC is connected to my Sony STR-DN1040 via HDMI. I’ve ripped a couple of my blu rays to MKV using MakeMKV, and I’ve used MediaInfo to verify that the audio streams ripped lossless (passthru) in their native format.
But no matter which player I use - VLC or WMP Classic, the audio is coming to my receiver as PMC Linear 2.0.
When I play the very same disc in my dedicated blu ray player, without changing any settings on my receiver, the audio comes through as Dolby Digital and DTS.
My receiver is set to auto-detect the stream.
This seems to be a problem only with MKVs, because if I play a ripped movie in BDMV format, the audio passes thru fine.
It’s really weird! Any ideas? This also isn’t a problem with MakeMKV because I’m experiencing the same problem using a different MKV ripper.
bmirak is offline
post #2 of 2 Old 11-17-2019, 08:28 PM - Thread Starter
Liked: 0
Never mind - I found the solution. There’s an audio setting in VLC to Enable pass through. Odd that this isn’t the default.
So now it’s time to set up Plex and hopefully I can also pass through native audio there, too. The goal is to simply stream the MKVs from a Plex server via a client (either a stick or maybe a smart tv app) rather than interfacing directly with the server.
bmirak is offline
Reply Home Theater Computers
