Nvidia Shield TV 2019 and Netflix - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-02-2019, 11:53 AM - Thread Starter
yuimyt's Avatar
Hi,
Does somebody have issue with center audio is blended in to other channels with Nvidia Shield TV 2019 and Netflix app?
My set up is Nvidia Shild TV > Denon X6300H and Denon says it is Atmos audio. All voices are coming from non-center speakers, When I switch to Xbox One or Dishnetwork Netflix app, the center channel is working fine as it should.
Thanks in advance.
AVR-X6300H with DefTech BP8060 system and HSU sub
Panasonic 60in Plasma and BenQ HT5550
yuimyt is offline
post #2 of 3 Old 12-02-2019, 03:38 PM
MMoser's Avatar
Quoted: 88 Post(s)
I can't be much help other than to say I had odd channel mixing during a couple parts of streaming the Irishman on Netflix. Dialog was coming out of l/r a couple times in odd places and only for a second. Played from Shield2019 to a 7.2.4 config on a Marantz 8012. It fixed itself right away, but everyone watching was wondering what happened and commented when they heard it again, which was a handful of times...
Sent from my SM-N975U using Tapatalk
MMoser is offline
post #3 of 3 Old 03-18-2020, 05:49 AM
Liked: 0
I just bought Nvidia Shield tv pro 2019 and I have a problem, can not get Netflix and Prime Movies to get any audio except if its on PCM.
I need to chose “never use surround sound” option on the shield and then audio is on but PCM
I bought the Shield because I was hoping to get Atmos but I can not get even 5.1
I have onkyo rz730 with 5.2.4 speaker connection
Conection is
Nvidia-receiver-TV
Is it possible to be HDMI cables ?
Petkatalbc is offline
Reply Home Theater Computers
