MB SPDIF OUT to Digital adapter - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By Worf
  • 1 Post By Worf
post #1 of 6 Old 12-04-2019, 07:13 PM - Thread Starter
Quoted: 956 Post(s)
Liked: 271
Hello,
Trying to get digital out from the MB. The board is a TUF B360-PLUS GAMING and it has a 4-1 pin SPDIF_OUT.
Page 16:
https://dlcdnets.asus.com/pub/ASUS/m..._UM_V2_WEB.pdf
There seem to be some adapters and high-definition front panel audio modules, but does not seem to be a lot of products for this setup.
Something like this would work?
https://www.amazon.com/SPDIF-Optical.../dp/B07FJMD7BF
https://www.amazon.com/SPDIF-Optical.../dp/B01LWNKIKN
Other suggestions?
noob00224 is online now
post #2 of 6 Old 12-05-2019, 12:27 AM
Worf's Avatar
Quoted: 872 Post(s)
Liked: 600
Yeah, they should work. The header is a standard pinout for that. The high definition modules are different and use the HD audio header. Again, another standard header.
noob00224 likes this.
Worf is online now
post #3 of 6 Old 12-05-2019, 12:32 AM - Thread Starter
Quoted: 956 Post(s)
Liked: 271
You mean the Front panel audio connector (10-1 pin AAFP)?
Could they be referring to some front panels that have SPDIF out outputs?
post #4 of 6 Old 12-05-2019, 11:40 PM
Worf's Avatar
Quoted: 872 Post(s)
Liked: 600
Yes, you can buy front panels with all sorts of inputs - like I said, the headers are standard. I bought a media front panel for my htpc and it just plugged into all the spare headers I wasn't using. Of course, a rear connection is better if it's a permanent connection so you don't have to live with a PC with a cable sticking out the front and snaking to the back.
Worf is online now
post #5 of 6 Old 12-10-2019, 09:41 AM - Thread Starter
Quoted: 956 Post(s)
Liked: 271
How will it show up?
In the Sound panel in Control Panel?
post #6 of 6 Old 12-11-2019, 12:44 AM
Worf's Avatar
Quoted: 872 Post(s)
Liked: 600
Depends on the sound card, but it should show up as a separate audio output device with digital in the name to separate it from the analog output. Just make it default and all audio will be sent through it.
Worf is online now
Reply Home Theater Computers
