Disable win10 updates with exe? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #31 of 38 Old 01-10-2020, 09:33 AM
Quoted: 18 Post(s)
Liked: 1
Could you just block windows update from updating with a firewall?
Living room HT
Front channels...3 Klipsch RP160Ms, 4 RP150Ms surrounds,Yamaha CXA5100, 2 Dune HD PRO, 2 Yamaha p2500s, 2 Nobsound 50wpc, UnRaid, APC HT power center, Pioneer bluray player, PS3, XBOX ONE,
Xilica xp4080 crossover
NBPk402 is offline
post #32 of 38 Old 01-15-2020, 08:38 AM
Sammy2's Avatar
Quoted: 1059 Post(s)
Liked: 346
So I just got my first (Update Tuesday yesterday) Update notification since my build in mid December. I have it set to pause for 7 days right now.
Where are the changes listed for each update?
Is there a KB that I can google?
Which of the several apps mentioned here is recommended?
Sammy2 is offline
post #33 of 38 Old 01-15-2020, 11:44 AM - Thread Starter
whiteboy714's Avatar
Quoted: 1566 Post(s)
Liked: 679
I would just use this one, it is a piece of cake, start and stop with ease. Has worked well for me.
Originally Posted by whiteboy714 View Post
I used this from above
https://greatis.com/stopupdates10/
With one click it re-enabled updates.
Sammy2 and m_snow like this.
TCL 65R625 -- Denon X1400h -- Klipsch RP600m -- RP450C -- Micca M-6S 6.5 -- Dual Klipsch RW-10
whiteboy714 is online now
post #34 of 38 Old 01-15-2020, 05:01 PM
Quoted: 2028 Post(s)
Liked: 1291
I agree, it works well. Today I turned it off just to install the Tuesday update for a very serious security issue and turned it back on after the update.
Mike
Sony XBR-65X930E | ATV4K-64GB & 2-32GB 5th Gens | Nvidia Shield TV Pro 2017 | Nvidia Shield TV Pro 2019 | Logitech Harmony Elite
m_snow is online now
post #35 of 38 Old 01-17-2020, 09:28 AM
Sammy2's Avatar
Liked: 346
Care to elaborate?
Sammy2 is offline
post #36 of 38 Old 01-17-2020, 10:50 AM
Liked: 1291
Care to elaborate?
It works well. I am able to turn it off, install updates then turn it back on to block updates.
Mike
post #37 of 38 Old 01-17-2020, 11:35 AM
Sammy2's Avatar
Liked: 346
I mean the serious security issue.
Sent from my SM-G960U1 using Tapatalk
Sammy2 is offline
post #38 of 38 Old 01-17-2020, 11:49 AM
Quoted: 83 Post(s)
Liked: 50
See here:
https://krebsonsecurity.com/2020/01/...-2020-edition/
For some reason, the update did not show up for me, I had to install it manually.
https://mspoweruser.com/windows-10-k...tallation-bug/
m_snow likes this.
Roussi is offline
Reply Home Theater Computers
