Disable win10 updates with exe? - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #1 of 38 Old 12-30-2019, 01:54 PM - Thread Starter
whiteboy714's Avatar
Quoted: 1563 Post(s)
Liked: 678
Someone was recommending an app a while ago that kills win 10 updates. I used it, and now have no idea what it was called and need to restore the ability to update. Anyone know what the app is?
TCL 65R625 -- Denon X1400h -- Klipsch RP600m -- RP450C -- Micca M-6S 6.5 -- Dual Klipsch RW-10
whiteboy714 is offline
post #2 of 38 Old 12-30-2019, 02:07 PM
Quoted: 2018 Post(s)
Liked: 1287
Maybe this? Win_Update_StopSetup.exe. Not sure, I googled it.
https://www.novirusthanks.org/get-fi...ile_type=setup
Mike
Sony XBR-65X930E | ATV4K-64GB & 2-32GB 5th Gens | Nvidia Shield TV Pro 2017 | Nvidia Shield TV Pro 2019 | Logitech Harmony Elite
m_snow is online now
post #3 of 38 Old 12-30-2019, 02:09 PM - Thread Starter
Liked: 678
I've been googling as well and don't think that was it. Can't seem to find it.
post #4 of 38 Old 12-30-2019, 03:58 PM
Liked: 1287
There are registry changes you can make that will stop automatic installs of updates. I suspect that’s what this exe did for you. I would google how to do that and undo what it did.
Mike
post #5 of 38 Old 12-30-2019, 04:48 PM - Thread Starter
Liked: 678
Yeah I probably will,. but the guy that suggested it was a regular so hoping he sees this first.
post #6 of 38 Old 12-30-2019, 04:55 PM
PrimeTime's Avatar
Quoted: 806 Post(s)
Liked: 506
You can discourage sudden updates in Win 10 by going through Settings and turning on the switch that says Metered Connection.
PrimeTime is offline
post #7 of 38 Old 12-31-2019, 09:12 AM
grittree's Avatar
Quoted: 475 Post(s)
Liked: 292
I know exactly what you are talking about. It was a small program with a unique name. Didn't involve going into settings. Unfortunately, I can't recall the name either.
grittree is offline
post #8 of 38 Old 12-31-2019, 10:54 AM
brazen1's Avatar
Quoted: 621 Post(s)
Liked: 353
If you want to stop specific Windows updates (GPU drivers) for example, MS offers this tool https://support.microsoft.com/en-us/...ling-in-window.
Google wushowhide.diagcab
HOW TO - Kodi 2D - 3D - UHD (4k) HDR Guide Internal & External Players
W10 1909 / MPC-BE\HC / PotPlayer / PowerDVD 19 / DVDFab Player 3&5 / KODI 19 videoplayer
GTX960 4GB / RGB Full 4:4:4 / 8bit Desktop mode =60Hz / 10/12bit Video mode = Matched Refresh rates IE 23,24,25,60Hz
65JS8500 UHD HDR 3D / Denon S720W
brazen1 is offline
post #9 of 38 Old 12-31-2019, 11:17 AM - Thread Starter
Liked: 678
Seems like some people don't read the OP. I've already done it but want to restore the ability.
Yup, the name has nothing to do with the purpose so google has been fruitless.
post #10 of 38 Old 12-31-2019, 11:34 AM
brazen1's Avatar
Quoted: 621 Post(s)
Liked: 353
Well, excuse me. I thought perhaps this was the app you used and could restore its functionality. My bad
brazen1 is offline
post #11 of 38 Old 12-31-2019, 12:22 PM
Quoted: 83 Post(s)
Liked: 50
From my search, the only seemingly unrelated tool is EaseUS. Sounds familiar?
Roussi is offline
post #12 of 38 Old 12-31-2019, 12:55 PM
talon95's Avatar
Quoted: 433 Post(s)
Liked: 243
https://greatis.com/stopupdates10/
I've been using it.
SuperFist likes this.
talon95 is offline
post #13 of 38 Old 12-31-2019, 07:01 PM - Thread Starter
Liked: 678
Ha sorry.
Originally Posted by talon95 View Post
This might be it thanks! I'll just try to restore and see what happens.
post #14 of 38 Old 12-31-2019, 07:03 PM
Quoted: 17 Post(s)
Liked: 1
You can not turn off updates like in Windows 7?
Living room HT
Front channels...3 Klipsch RP160Ms, 4 RP150Ms surrounds,Yamaha CXA5100, 2 Dune HD PRO, 2 Yamaha p2500s, 2 Nobsound 50wpc, UnRaid, APC HT power center, Pioneer bluray player, PS3, XBOX ONE,
Xilica xp4080 crossover
NBPk402 is offline
post #15 of 38 Old 12-31-2019, 07:12 PM
peniku8's Avatar
Quoted: 337 Post(s)
Liked: 337
DoNotSpy has a similar feature. I disable it once a year to do my updates, plus I don't get the annoying popup which tells me to update Defender as I do when switching to metered connection.
SuperFist and NBPk402 like this.
A Star Is Born - Lady Gaga goes Rock Audio&Video by Ocean Studios (me)
SKHorn Build
Samsung KS7500 - Marantz NR1504 - Klipsch R-26F - Klipsch R-25C - Klipsch R-15M - SKHorn (on FP-13000 clone)
Bass EQ for Filtered Video Games
peniku8 is online now
post #16 of 38 Old 12-31-2019, 07:40 PM
SuperFist's Avatar
Quoted: 1456 Post(s)
Liked: 6037
Thank you! This is EXACTLY what I've been looking for!
By the way, another tidbit for everyone. Sometimes Windows 10 is stubborn and doesn't give you just the option to "Shutdown." It only gives you "Install Updates and Shutdown."
If you want to bypass that nonsense and Shutdown ONLY...
Hold the Windows button + R and type in "CMD" and press ENTER.
Type in the following in the window: shutdown -s -t 0
NBPk402 likes this.
SuperFist is offline
post #17 of 38 Old 01-03-2020, 07:49 AM
Sammy2's Avatar
Quoted: 1059 Post(s)
Liked: 346
@whiteboy714
Have you checked the WMC Win10 thread at thegreenbutton.tv?
BTW, why did you disable updates for Win10?
Sent from my SM-G960U1 using Tapatalk
Sammy2 is offline
post #18 of 38 Old 01-03-2020, 08:09 AM - Thread Starter
Liked: 678
Originally Posted by Sammy2 View Post
@whiteboy714
I have not looked there. I haven't had the time to need with it since I posted this.
I always kill updates and do them when I want. Don't like the reboots it will do whenever it wants. And I was having trouble RDPing into the machine after every update. Would have to go hard reset the machine.
But with win 10 you can't just shut them off like win 7.
NBPk402 likes this.
post #19 of 38 Old 01-03-2020, 09:11 AM
Sammy2's Avatar
Liked: 346
I didn't realize the issue with reboots and RDP sessions being locked out. I just started with Win10 with my latest build last month. Why would RDP be locked out?
I did realize that the updates were forced in Win10 and could not be toggled on or off. I'm wondering, is there an application that can give back this level of control? I know enterprises do it, so why can't we?
Sammy2 is offline
post #20 of 38 Old 01-03-2020, 09:22 AM - Thread Starter
Liked: 678
I'm not sure why it would do that. The machine was still running fine as Emby was still accessible. But I couldn't login. Weird.
As far as ways to control the updated lol at some of the above posts. There are various options to take control.
post #21 of 38 Old 01-03-2020, 09:24 AM
Liked: 1287
You can, just google it. There are three settings in the registry, that’s how corporate enterprises deal with it. Back up those registry keys first.
Mike
post #22 of 38 Old 01-03-2020, 11:18 AM
Sammy2's Avatar
Liked: 346
So it is a matter of changing registry settings to "on or off"? I'll look further but this is good to know. I want some sort of GUI that simplifies rather than a one off *.exe so I don't have to do what @whiteboy714 is doing today! LOL.
Sammy2 is offline
post #23 of 38 Old 01-03-2020, 11:32 AM
Liked: 1287
I hear that! Yes, there are two keys to add (case sensitive) and another one or two that change a bit to 1 or 2. I can’t remember now.
Mike
post #24 of 38 Old 01-03-2020, 11:40 AM - Thread Starter
Liked: 678
Yeah I had a gui. I was just dumb and apparently deleted it. Doesn't seem like it was something that was installed but I should do some better digging I suppose.
post #25 of 38 Old 01-03-2020, 03:56 PM
Sammy2's Avatar
Liked: 346
So is stopupdates10 what I need?
Also, while we're on the subject of Win10, do I need to create a task to update the time so my recordings don't get messed up in Emby or did MicroSoft fix this issue?
Sammy2 is offline
post #26 of 38 Old 01-03-2020, 04:00 PM
captain_video's Avatar
Quoted: 779 Post(s)
Liked: 445
Are you referring to your computer's clock? Drifting clocks is a PC issue, not a Microsoft one. There are lots of apps out there that will keep your clock synchronized and accurate.
Sammy2 likes this.
captain_video is offline
post #27 of 38 Old 01-03-2020, 04:14 PM
Sammy2's Avatar
Liked: 346
I'll just create the scheduled task.
Sammy2 is offline
post #28 of 38 Old 01-03-2020, 04:25 PM
steveb18's Avatar
You should be able to disable or set to manual updates using local group policy as well by running gpedit.msc. If its "home" edition you may have to enable it first.
https://www.ghacks.net/2019/01/07/how-to-enable-gpedit-msc-group-policy-on-windows-10-home-devices
Sammy2 likes this.
steveb18 is offline
post #29 of 38 Old 01-05-2020, 07:50 AM - Thread Starter
Liked: 678
I used this from above
With one click it re-enabled updates. Going to do them now and then disable again. Thanks @talon95
Sammy2 likes this.
post #30 of 38 Old 01-07-2020, 10:58 AM
mrfattbill's Avatar
Quoted: 146 Post(s)
Liked: 106
This is the one that I use on my machines:
https://www.sordum.org/9470/windows-...-blocker-v1-5/
Bill
mrfattbill is offline
Reply Home Theater Computers
