CPU/GPU Load - 1920x1080 vs 3840x2160 ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-02-2020, 09:29 PM - Thread Starter
Quoted: 537 Post(s)
Liked: 117
probably a dumb question, but does feeding video to a 3840 x 2160 display put more of a load on the cpu/gpu than feeding video to a 1920 x 1080 display, assuming display and output resolutions match?
for example, if i have a 1920 x 1080 display and send it a 1920 x 1080 video, would that put less of a load on the cpu/gpu than if i have a 3840 x 2160 display and send it a 3840 x 2160 video?
thanks!
aeneas01 is online now
post #2 of 3 Old 01-02-2020, 11:03 PM
markmon1's Avatar
Quoted: 5679 Post(s)
Liked: 3732
thanks!
Yes. 1920x1080 is simply 1/4th the data for the video card to process. In addition, that video is not uncompressed. So you're also having to decode the video and it's going to be higher bitrate and perhaps a more difficult to decompress codec (h265 vs h264).
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #3 of 3 Old 01-03-2020, 12:56 AM - Thread Starter
Quoted: 537 Post(s)
Liked: 117
yep, was afraid of that, but wanted to make sure my windows system was performing as expected... i played around with madvr using 1080p videos and a 1920x1080 display and was very impressed with how well the intel igpu (655) handled the load at various settings, then i tried the same thing with 3840 hdr videos and a 3840x2160 display and the performance with madvr plummeted as the load went way up.
Reply Home Theater Computers
