Remote for Windows OS ? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By bryan_chow
post #1 of 11 Old 01-05-2020, 03:08 AM - Thread Starter
Mike99's Avatar
Quoted: 156 Post(s)
Liked: 66
Is there a remote that controls Windows 7 like a wireless keyboard does, but without the keyboard part?
Sometimes I watch a program on TNT.com or CBS.com and use the HTPC's browser (Firefox) in order to login. But then I don't need a keyboard, just the buttons for Pause, FF, REW, etc. IOW I don't want to hold a wireless keyboard on my lap for an hour or two. But having a remote on hand, especially with volume control of the AVR, would be nice.
I have WMC remotes but of course they don't control Windows itself.
I know they make remotes with keyboards but the ones I looked at seem a bit large. Do they make any that are more size-like a TV or Blu-ray player remote? Or ones without a keyboard?
Thanks for any suggestions.
Mike99 is offline
post #2 of 11 Old 01-05-2020, 06:25 AM
markmon1's Avatar
Quoted: 5679 Post(s)
Liked: 3732
HTPC remote control works a bit differently. You buy something like an FLIRC (https://www.amazon.com/dp/B01NBRBWS6) and plug this into your PC. It is a generic IR receiver that can accept input from *any* remote and you can use the FLIRC app and tell it which keyboard key is assigned to each remote signal. You can find any old remote laying around, any universal remote programmed to another device you dont use anymore etc. These can send the unique IR signals to the PC.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #3 of 11 Old 01-05-2020, 07:45 AM
captain_video's Avatar
Quoted: 779 Post(s)
Liked: 445
For navigating in Windows your best bet is to use a wireless keyboard/mouse combo. There are lots of them on the market that will work. You could try to set up a remote to work in Windows but it is extremely clunky and difficult to use. Nothing beats a keyboard and mouse when working on a Windows desktop. The Lenovo 5902 keyboard remote is compact and works great for this, but unfortunately it has been discontinued. You can still find them on ebay, but usually at a premium price. I see many of them listed without the RF dongle, which essentially makes them useless so steer clear of them. I have them on every one of my HTPCs. The only drawback is that they don't have function keys (i.e., F1-F12). Other than that they have everything else a standard keyboard has. The mouse part is a touchpad that you can operate with your thumb. There's an older model that uses a small trackball instead of the thumb pad, model 5901. It works, but nowhere near as well as the 5902. The keyboard part is pretty much the same but the trackball can be a bit flaky at times. The good news is that you can pick them up fairly cheap on ebay. Again, be wary of the ones with no dongle.
I've tried all kinds of mini-keyboard and trackball combos and I haven't found anything I like better than the Lenovo 5902. The 5902 has a backlit keyboard whereas the 5901 does not.
captain_video is offline
post #4 of 11 Old 01-06-2020, 09:27 AM
ajkrishock's Avatar
Quoted: 83 Post(s)
Liked: 34
I have been using Unified Remote with both my HTPC's. It runs as a server and I use a couple of cheap android tablets with the Unified Remote app installed to control the HTPC's. My tablets also have an IR transmitter built in so I can send IR commands from the tablets, too. It sometimes takes about 10-15 seconds for the app to sync with the HTPC on power-up but it works fine otherwise. I even designed my own custom remote once I learned how.
ajkrishock is offline
post #5 of 11 Old 01-06-2020, 09:38 PM
rekbones's Avatar
Quoted: 1159 Post(s)
Liked: 592
I use these and think they work great.
https://www.ebay.com/itm/Mini-2-4G-W.../173344526554?
Battery is short lived so I have to charge it almost once a day but that's the only major flaw. They are a little bigger than a typical TV remote.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
post #6 of 11 Old 01-07-2020, 06:23 AM
Quoted: 779 Post(s)
Liked: 445
I've actually got a couple of those. I could never warm up to using them, but it's been quite some time since I have them a try. I seem to recall the touch pad was a bit flaky and didn't respond well. I do like that they have a full keyboard. You can't beat the price so it's certainly worth giving one a try. It's not going to break the bank if you decide you don't like it. There are lots of compact keyboard/touchpad combos similar to this and they don't cost an arm and a leg, but you do tend to get what you pay for.
post #7 of 11 Old 01-08-2020, 01:21 PM
Quoted: 779 Post(s)
Liked: 445
I justt found out that there's a newer version of the Lenovo keyboard/mouse remote. The model is the N5903. Amazon has them for $29.99 with free shipping.
https://www.amazon.com/Bestseller288...K1M0CB6BTH5Z4E
post #8 of 11 Old 01-14-2020, 12:50 AM
bryan_chow's Avatar
Quoted: 18 Post(s)
I have tried every kind of remote for my HTPC, such as:
USB-UIRT with many custom remotes that I painstakingly programmed in Girder
and many, many others over the past 15 years.
In the end nothing comes better than a standard fullsize media keyboard like this:
There are just too many occasions when you need to do things like web browsing, switch between open windows, access preferences of the media player, use Explorer etc that it's just not worthwhile (to me) to try to use a remote with limited keys.
I like the Microsft Media Keyboard because it has volume controls, and I can program the 3 buttons on the right to do whatever I want. I have one of them programmed to turn the system on and off.
mlknez likes this.
bryan_chow is offline
post #9 of 11 Old 01-14-2020, 06:27 AM
robn1's Avatar
A wireless trackball mouse really comes in handy
https://www.walmart.com/ip/Logitech-...?selected=true
you can set it on the arm of your chair or beside you on the couch. I operate mine with my left hand because I can roll the ball easier with my fingers, and use my thumb for r/l clicks.
Rob
robn1 is offline
post #10 of 11 Old 01-14-2020, 01:29 PM
Starsky's Avatar
My last gyration mce remote finally bit the dust a couple weeks ago, which was by far the best pc remote/air mouse I've used. There are a ton of $10-30 remotes out there and the few I've tried were garbage, there seems to be no quality backlit options out there. I've settled on this one which I give a solid meh.
Starsky is offline
post #11 of 11 Old 01-16-2020, 07:35 AM
SirMaster's Avatar
Quoted: 922 Post(s)
Liked: 597
I am a fan of this model.
https://www.amazon.com/W10-GYRO-Keyb.../dp/B078NT49MJ
It's got a bunch of shortcut buttons and functions that let you navigate and generally use a Windows 10 PC quite efficiently.
Otherwise it's a generic air mouse (like a wii mote) with a keyboard on the back.
SirMaster is offline
Reply Home Theater Computers
