dvd fab player vs mkv rips - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-10-2020, 03:20 PM - Thread Starter
gerall's Avatar
Quoted: 70 Post(s)
I've been ripping blu rays to MKV and playing with MPC HC. However there are discs which I will view only once and want a software player where I can pop in the disc and play. Tried Power dvd but it was too buggy. Any thoughts regarding DVD fab - specifically if the audio video quality is on par with mkv rips. Also, I recently purchased a 4k tv and want to play uhd discs without ripping - is a third party decrypter still required for use with dvd fab and also are there hardware requirements such as a uhd friendly drive or specific graphics card like those that are required when using madvr? Many thanks in advance -
gerall is offline
post #2 of 4 Old 01-10-2020, 09:16 PM
captain_video's Avatar
Quoted: 779 Post(s)
Liked: 445
By the time you finish paying for a PC Blu-Ray drive, decrypting software and a software player it might be more convenient and cost effective just to get a standalone Blu-Ray player to play the occasional disc. You can get a basic player for as little as $40. If you want a lot of bells and whistles then you will obviously pay much more. I personally wouldn't bother with trying a PC-based playback setup for physical discs. A standalone player is much more convenient for that.
captain_video is offline
post #3 of 4 Old 01-11-2020, 01:26 PM - Thread Starter
gerall's Avatar
Quoted: 70 Post(s)
Thanks, Captain Video. Totally agree. Problem is my audio is a very good 2 channel system that does not use HDMI. And the I want the 2 channel lossless (decoded to pcm) track sent to my dac. It is my understanding that unless hdmi is used, in a stand alone player the 2 channel track is the lossy decoded to pcm. With a computer the decryption would allow me to send the lossless - that is what I'm doing now with mkv - but it's a royal pain to rip discs every time I want to watch a move I rent.
gerall is offline
post #4 of 4 Old 01-12-2020, 08:35 AM
Quoted: 779 Post(s)
Liked: 445
If you're using a separate DAC then chances are you can get a Blu-Ray player that has a digital audio output that you can send to the DAC. The output may be limited to 5.1 audio but since you're only going to listen to it in stereo that shouldn't be a problem.
Reply Home Theater Computers
