Will my old gaming pc work for Atmos 4k HDR? Here are the specs - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By rekbones
  • 1 Post By markmon1
post #1 of 5 Old 01-26-2020, 11:00 AM - Thread Starter
carlobenavidesahavia's Avatar
Quoted: 47 Post(s)
Liked: 5
So I ordered everything to upgrade my old HT system to Atmos 7.2.4 Pioneer elite VSX-LX503 9.2 plus Dayton stereo amp for the 2 extra channels not amplified extra polk sattelites and 1 subwoofer and just salvaged some of my old speakers from the 7.1 setup.
Here are the specs for my PC. I have an old Nvdia Shield Pro 2017 500gb as well btw. Don't know if that will work.
CPU I7 6700k
Ram 32gb
Video card Geforce GTX 980TI
Sent from my SM-N975F using Tapatalk
carlobenavidesahavia is offline
post #2 of 5 Old 01-26-2020, 10:11 PM
rekbones's Avatar
Quoted: 1206 Post(s)
Liked: 611
Audio is no problem as you bitstream over HDMI. H.265/hevc is where you may run into issue as the 980ti doesn't do hardware decoding of H.265. Doesn't mean it won't work as the CPU should be able to handle it. An Nvidia 10/16/20 series cards all do hardware decoding of H.265. The GTX1060 is one of the lowest recommended to run MadVR. I am running a 1050ti with no issues but I have no HDR displays to deal with only 4K/SDR
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
post #3 of 5 Old 01-27-2020, 04:18 AM - Thread Starter
Quoted: 47 Post(s)
Liked: 5
Damn so that's why the 4k atmos high bit rate videos I downloaded are lagging and have many dropped frames with MadVR...... I was planning to wait for the ampere cards to come out before I buy so the prices would would drop on the RTX cards or just get one of the entry level amperes depending on benchmarks.... Will the Nvdia shield be able to handle playing those files till ampere comes out?
post #4 of 5 Old 01-27-2020, 06:09 AM
markmon1's Avatar
Quoted: 5845 Post(s)
Liked: 3919
Tons of used 10x0 series cards on craigslist for great deals.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, Infinite Baffle Subs 4x15 fi audio running on behringer ep4000 + 2x12 fi audio mounted in main chair firing into back.
markmon1 is offline
post #5 of 5 Old 01-27-2020, 06:39 AM - Thread Starter
Quoted: 47 Post(s)
Liked: 5
I already checked craigs list.... the average prices for the 1080 ti and 2070 super are 500usd and above.... Buying anything lower than those 2 models right now would be a step down in terms of PC gaming coming from a 980ti not unless I buy something lower end and build a new frankenstein pc from all used parts just for a home theater rig.... but that would be redundant when ampere comes out and I get buyers remorse.... Would the shield be able to at least play ripped 4k high bit rate torrent files till then? Because when I do buy a new video card it should be an upgrade for gaming as well as home theater use....
Reply Home Theater Computers
