Confused about resolution for new computer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-01-2020, 04:51 AM - Thread Starter
ctviggen's Avatar
Quoted: 142 Post(s)
Liked: 36
Due to Windows 7 no longer being supported, I put together a new HT computer (let's just say my old one died during the Win7 to Win10 upgrade). I'm configuring the new computer now.
I use my HT computer to watch movies and MKVs, along with serving TV via an HD Homerun Prime.
I'm using an Nvidia GeForce card to output to a Marantz S5010 receiver, which supports 4K. My TV supports 4K, which I watch using FireTV (I have no other sources of 4K).
When I look at the resolution selected by the video card/software, it initially listed1080i, 1920x1080, and a refresh rate of 30Hz. So, I changed this to 1080p at 60Hz.
Is this a suitable resolution/refresh rate? Or should I look into modifying it into a higher rate?
Bob
ctviggen is offline
post #2 of 3 Old 02-01-2020, 09:56 AM
brazen1's Avatar
Quoted: 626 Post(s)
Liked: 357
Notice in the nVidia control panel what the native resolution is. When using a 4k chain it should be 3840x2160p. It should be defaulted to that so you shouldn't have to modify anything unless you previously changed it for some reason.
HOW TO - Kodi 2D - 3D - UHD (4k) HDR Guide Internal & External Players
W10 1909 / MPC-BE\HC / PotPlayer / PowerDVD 19 / DVDFab Player 3&5 / KODI 19 videoplayer
GTX960 4GB / RGB Full 4:4:4 / 8bit Desktop mode =60Hz / 10/12bit Video mode = Matched Refresh rates IE 23,24,25,60Hz
65JS8500 UHD HDR 3D / Denon S720W
brazen1 is offline
post #3 of 3 Old 02-03-2020, 01:49 PM
mlknez's Avatar
Quoted: 565 Post(s)
Liked: 196
which video card do you have?
Media Room: LG oled65c7, Marantz AV8805, Sherbourn 7/2100, Emotiva A-300, Studer A80, Studer Revox b795, Nakamichi RX-202, HTPC, exaSound e38, Sweetvinyl Sugarcube SC-2, (2) Piega P10, Piega Coax Center, (6) Piega AP 1.2, Hsu VTF-15h mk2
Office: Emotiva mini-x A100, Geek Pulse, (2) KEF LS-50, Goldenear FF 4, PC, NAS 130TB
Bedroom: Panasonic TCP55vt35, Marantz NR1200, Dune 3 Prime, (2) Elac Uni-Fi UB5
mlknez is offline
Reply Home Theater Computers
