AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Home Theater Computers (https://www.avsforum.com/forum/26-home-theater-computers/)
-   -   Sapphire RX 480 does not go 10 bit with Custom resolution (https://www.avsforum.com/forum/26-home-theater-computers/3120296-sapphire-rx-480-does-not-go-10-bit-custom-resolution.html)
Nidios 02-01-2020 05:47 AM
A strange thing happens to me with my RX480.
HTPC system just assembled and all clean with the latest drivers, I made a Custon resolution (3840x1920) because of my 2: 1 format screen.
In short, I can not put a color depth greater than 8bit unless I enable the "GPU Scalin" function.
But by enabling this feature, movies jerky, like it doesn't enable DVXA2 video acceleration.
https://i.postimg.cc/DyhPYPPX/Pannello-Radeon.png
In the previous PC with the same video card and same resolution I was able to have 10bit (although I had difficulty and I don't know how it did it) but now it doesn't want to know.
I don't think it's a Driver problem, I had the same ones on the other PC with the same video card and the problem was not there.
I tried all the frequencies from 23 to 60, I inserted them all on the Radeon Software custon resolutions:
https://i.postimg.cc/3JvLXgYS/Cattura.pngwallpaper
Also with this mode (with GPU scalin disabled) it doesn't show me the YUV color space but only RGB but here it doesn't matter because using MadVR I go in RGB 0-255.
If instead I enable "GPU scalin" I am presented with everything:
https://i.postimg.cc/wxmfJS58/Cattura1.png
I know it's a particular problem ... but do you have any ideas?
Powered by vBulletin® Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
