HELP: HTPC Not Recognize by Receiver - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Worf
post #1 of 5 Old 02-01-2020, 04:35 PM - Thread Starter
smokarz's Avatar
Quoted: 121 Post(s)
Liked: 109
I am not quite sure what happens exactly, this same set up works perfectly previously. Now it just doesn't seems to work.
Here's my setup:
HTPC: Windows 7 64bit, AMD Radeon HD 5670 (Catalyst version 2015.0804.21.41908)
Receiver: Integra DHC 9.9
Projector: BenQ
HTPC is connected to Integra, Optical audio works fine. But HDMI connection from HTPC to Integra is not detected. I've tried multiple HDMI cables and multiple HMDI connections on the Integra, nothing is detected.
Connection between Integra and BenQ projector is fine as I pulled up the Integra setup menu and it shows up on the projector display.
At this point, I am at a lost as to why the HDMI connection bewtween the HTPC and the Integra receiver is not detected.
Really appreciate all the help.
smokarz is offline
post #2 of 5 Old 02-01-2020, 11:21 PM
Worf's Avatar
Quoted: 891 Post(s)
Liked: 622
Check the resolution your PC is outputting. Most AVRs only support CEA-861 resolutions like 480i/p, 720p and 1080i/p and 2160p. Feed it with something like 1024x768 and it won't show anything. Also check to see if plugging the htpc into your projector directly works.
markmon1 likes this.
Worf is offline
post #3 of 5 Old 02-02-2020, 10:02 PM
rekbones's Avatar
Quoted: 1216 Post(s)
Liked: 615
Do you have another HDMI device to test the HDMI inputs on the AVR? It is possible you have a HDMI hardware failure in the AVR a very common issue.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
post #4 of 5 Old 02-03-2020, 05:29 PM - Thread Starter
smokarz's Avatar
Quoted: 121 Post(s)
Liked: 109
Thanks. It is 1080 i/p.
I also have the HTPC connected to an LCD monitor via DVI, and that connections work fine.
smokarz is offline
post #5 of 5 Old 02-03-2020, 05:31 PM - Thread Starter
smokarz's Avatar
Quoted: 121 Post(s)
Liked: 109
Good point. I'll have to find a laptop and try connecting to the AVR and test it out.
The strange thing is this same exact setup was working months ago. I did not use for months due to work/family, and now it just stopped working like it used to.
smokarz is offline
Reply Home Theater Computers
