nVidia GTX series cards and 23.976p - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By mrvideo
  • 1 Post By tommarra
post #1 of 8 Old 02-03-2020, 02:39 PM - Thread Starter
mrvideo's Avatar
Quoted: 1342 Post(s)
Liked: 997
I'm thinking about using a tower with a nVidia graphics cards, like the GTX-1050. What I want to possibly do is feed the HDMI out to a Denon AVR and that to a BenQ TK850 projector.
The plot being that I'd like to use VLC to play MKV, and/or TS, files to the projector, which handles 24p natively. Does anyone know if the nVidia drivers allow the HDMI refresh rate to be set to 24p (23.976)? I do not care if the box stays at 24p, even for computer stuff, since the computer stuff will be minimal (other computers handle the computer stuff). Or, am I stuff with 60p refresh rate?
It is a spare Win7 tower, so I won't be forking out money to put together a new box to do this, other than a newer graphics card to handle 4K resolution.
"VCR was in the closet. Still works. Can't get the clock to stop blinking, though."
Angela - Animal Kingdom - 7/16/19
My 2017 Total Solar Eclipse Photos
mrvideo is online now
post #2 of 8 Old 02-03-2020, 02:46 PM
DavidinGA's Avatar
Quoted: 504 Post(s)
Liked: 184
Yes, you can set nvidia to output 24.
I personally run all my movies through MPC-BE at 23, as 24 produces lip-syncing issues.
Source: HTPC w/madVR, Video: Epson 5040, 150" 16:9, Audio: Onkyo RZ 830 avr, 5.1.4 Atmos setup. 5 speaker Energy C Series: L/R C300's, C C-C100, SR/SL C50's, 4 in-ceiling Micca R-8c. Subwoofers: 1 MiniMarty um18 w/NX3000D. 2 VBSS 18" Subs w/NX3000D.
DavidinGA is online now
post #3 of 8 Old 02-03-2020, 02:49 PM - Thread Starter
mrvideo's Avatar
Liked: 997
Thanks, that was quick. That is good news. Any particular reason that you are using MPC-BE instead of VLC?
DavidinGA likes this.
post #4 of 8 Old 02-03-2020, 03:23 PM
tommarra's Avatar
Quoted: 774 Post(s)
Liked: 446
Overall a much better player. Plus it allows you to use MadVR and other better filters. VLC is very limited and not open.
If you have a projector and a HTPC - you should be running MadVR (for any upscaling and HDR tonemapping) - and VLC just cant do that.
Gear: Fronts: B&W 804D3 | Center: B&W HTM2D3 | Surrounds: B&W 705S2 | Backs: B&W 684S2 | Heights: B&W DM601S3 | Subs: 3x PSA S1500 Receiver & Amps: Anthem MRX 720 + Emotiva BasX-5 | Projector: JVC NX7 | Source: HTPC with Nvidia 2070, Kodi + External Player: MPC-HC with MadVR (for Blu-ray rips), Nvidia Shield (for streaming content)
tommarra is online now
post #5 of 8 Old 02-03-2020, 04:52 PM
brazen1's Avatar
Quoted: 626 Post(s)
Liked: 357
Can VLC player even do 23.976, 24, 30, 50? Isn't it stuck at 60 on the frame rate? This would introduce pull down with uncontrollable judder yet so many choose to use it. Maybe I'm mistaken...
HOW TO - Kodi 2D - 3D - UHD (4k) HDR Guide Internal & External Players
W10 1909 / MPC-BE\HC / PotPlayer / PowerDVD 19 / DVDFab Player 3&5 / KODI 19 videoplayer
GTX960 4GB / RGB Full 4:4:4 / 8bit Desktop mode =60Hz / 10/12bit Video mode = Matched Refresh rates IE 23,24,25,60Hz
65JS8500 UHD HDR 3D / Denon S720W
brazen1 is offline
post #6 of 8 Old 02-03-2020, 07:06 PM - Thread Starter
mrvideo's Avatar
Liked: 997
OK, I've installed both programs on a Win7 box that is only connected to a 60Hz monitor. The MadVR will end up not getting used as this box isn't connected to a projector.
If any upscaling is done, it will be done via the projector. The projector is a 1080p/4k projector. It is not native true 4k. It does a special display technique with the native 1080p to achieve the 4k. My plans are not to let up convert 1080p material and leave it at 1080p.
post #7 of 8 Old 02-03-2020, 07:11 PM - Thread Starter
mrvideo's Avatar
Liked: 997
Currently, the VLC output on any of my computers only goes to a 60Hz monitor. When I play 23.976 video I do not get any judder. 1080i29.97 that has 3:2 pulldown does experience issues. When I was capturing 1080i59.94 video from satellite feeds, I always recoded the MPEG-2 to H.264 and did an inverse telecine to get back the original 23.976 frame rate. That has always played smoothly.
It will be months before I have anything set up to do things via the projector. I have lots of work ahead of me.
post #8 of 8 Old 02-04-2020, 10:10 PM - Thread Starter
mrvideo's Avatar
Liked: 997
I just played a video (23.976) via MPC-BE and it did not play smoothly on the nVidia GTX-730 card. It had judder and did not sync with the vertical refresh rate. During motion you can end up seeing the frame break up.
That said, VLC has the exact same issue. Things will probably be better when HDMI is used to display on the projector and the refresh rate set accordingly.
As a side note, on my XP-32 system, VLC plays video smoothly. It has a GT-240 nVidia card. One would think that a newer OS and nVidia card would play better, but it doesn't.
Reply Home Theater Computers
