Questions about surround sound connection options - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Worf
post #1 of 5 Old 02-19-2020, 09:49 AM - Thread Starter
Skylinestar's Avatar
Quoted: 1313 Post(s)
Liked: 271
I'm currently using a pair of JBL 104 as a simple desktop (ASRock Z170 Fatal1ty K6 motherboard with Realtek ALC1150 audio) stereo setup. I am planning to expand my setup to 5.1 but I do have a few questions:
People who are using Dolby/DTS 5.1 live encoders from the motherboard onboard digital/optical/coaxial/SPDIF audio, does the live encoding always work fine? Have you experienced any Win10 update that breaks this experience? How much lag does the live encoder add?
As my main display/monitor ([email protected] G-Sync) is connected to my NVIDIA GTX1070 DisplayPort output, can I send 5.1 LPCM audio via the HDMI port of the graphics card to an AVR? Is there any chance that the PC treats the AVR sink as a video-audio device and makes the PC thinks it has dual display? Is there any EDID compatibility issue in this? Will it break my main display?
My main intention is to get a budget AVR (a used Denon 2311 AVR) and use it for surround sound setup via HDMI. With digital audio, the AVR can do bass management easily. If the HDMI method doesn't work, I'll have to use the optical SPDIF method (gotta use the DTS Interactive 5.1 of my motherboard). If the live encoding is not a good option, I'll just connect my speakers (active) directly to the motherboard's rear IO 3.5mm ports. I guess this last method is guaranteed to work, but there will be no bass management from the Realtek HD Audio control panel.
Skylinestar is offline
post #2 of 5 Old 02-20-2020, 12:08 AM
Worf's Avatar
Quoted: 905 Post(s)
Liked: 635
HDMI is easiest. though yes, it's seen as another display, so set it as extend and move it so the overlap is in a corner. Set it's resolution to 720p which is sufficient for all formats
Worf is offline
post #3 of 5 Old 02-20-2020, 10:40 AM
Keenan's Avatar
Quoted: 4408 Post(s)
Liked: 4076
When you say "move it so the overlap is in a corner" what does that mean exactly?
Keenan is offline
post #4 of 5 Old 02-20-2020, 10:13 PM
Worf's Avatar
Quoted: 905 Post(s)
Liked: 635
When you extend your displays, windows shows both monitors in a layout view.mthisnhelps determine the main display, as well as how the desktops are spanned - side by side, top and bottom or any other arrangement of monitors. When I use HDMI, I set the HDMI display to be attached to my desktop monitors by a corner which means it's a lot harder to accidentally go to the hidden screen. Normally I use the bottom right corner as when I lose the cursor I mouse the mouse up and left and that means of the cursor accidentally traversed to the HDMI audio display, it will wander back to my displays eventually.
Keenan likes this.
Worf is offline
post #5 of 5 Old 02-21-2020, 02:47 PM
Keenan's Avatar
Liked: 4076
Keenan is offline
Reply Home Theater Computers
