Need to upgrade my HTPC - AVS Forum | Home Theater Discussions And Reviews
 6Likes
  • 2 Post By blizzard_c
  • 1 Post By Charles R
  • 1 Post By rekbones
  • 1 Post By markmon1
post #1 of 13 Old 02-21-2020, 08:32 AM - Thread Starter
Liked: 0
Hello
I have This PC since 2012 but I upgraded same part like GPU and SSD
Now my HTPC is
PC Case:
HTPC SilverStone GD08 (since 2012)
CPU:
Intel Core i5-3570K (since 2012)
Motherboard:
ASRock Z77 Extreme4 LGA 1155 (since 2012)
Graphics Card:
GTX 1660 ti (since 2019)
RAM
Corsair Vengeance 16GB 4×4GB (since 2012)
DDR3 1600 MHz (PC3 12800) 1.5V
SSD
Samsung 850 EVO 250GB 2.5-Inch (since 2019)
HDD
Seagate 3TB + 3TB
Cooling
Noctua NH-L12 Low-profile (since 2014)
Power Supply
Mushkin 700 Watt (since 2012)
My Nas: Synology DS918+
I need advices to develop that htpc Compatible with my case (GD08)
of course I use the device to watch movies 1080p and 4K UHD by MadVR
My budget (800$ ~ 1300$)
almawdah is offline
post #2 of 13 Old 02-21-2020, 10:15 AM
Liked: 4
If the HTPC is only used to play videos (2k or 4k with madvr), then I think only CPU and mainboard need to be upgraded, the rest are good enough for the task.
mlknez and almawdah like this.
blizzard_c is offline
post #3 of 13 Old 02-21-2020, 11:54 AM - Thread Starter
Liked: 0
please Can you refer models of CPU with Cooling and motherboard which are Compatible with my case and the old part
almawdah is offline
post #4 of 13 Old 02-21-2020, 12:19 PM
Charles R's Avatar
Liked: 881
For madVR upgrade the video card (up to your comfort level) and if it becomes CPU bound swap the i5 for a i7-3770K or some such.
markmon1 likes this.
| 125" Projection | 5.2.4 Audio | Shield TV | CoreELEC/ODROID-C2 Kodi Media Client | Ubuntu/ODROID-XU4 NAS/Server | 65" OLED TV | TiVo | Shield TV | Fire TV 4K |
| Water cooled Threadripper & Radeon VII, NVMe PC - 43" 4K IPS Panel |
Charles R is offline
post #5 of 13 Old 02-21-2020, 12:26 PM
Quoted: 1366 Post(s)
Liked: 397
For madvr the only component that would bring an improvement is the gpu. Depending on what you want to do with madvr, that gpu may be fine. There is no gpu that can use madvr to 100% anyway.
Better install madvr and see exactly what features you require.
What's the display?
noob00224 is online now
post #6 of 13 Old 02-21-2020, 02:32 PM - Thread Starter
Liked: 0
What's the display?
When I I wont to play movie (Gemini Man “2160p UHD - 60FPS) there is lag from the beginning when the movie run , and In the meantime I check the CPU & GPU activity it is 95%~100% !!!
BUT when I play any movies 4K (24FPS) it’s run smoothly!
Accordingly I think that related with the hardware
My display is (Sony X900F 85-inch)
almawdah is offline
post #7 of 13 Old 02-21-2020, 02:49 PM
Liked: 397
Render times must be under 16ms with 60fps content. Press Ctrl+J to activate the OSD.
To lower the render times you must reduce the options in madvr.
A more powerful card would help, but there are only two movies (so far) with 60fps (in 4K) and considering how well they did at the box office I don't think they will be making any more.
Even lower fps content is rare or non existent, the vast majority is 24p.
post #8 of 13 Old 02-21-2020, 03:15 PM - Thread Starter
Liked: 0
Ahaa Now I understand that thanks
but still I think my CPU and motherboard so old I want to keep up with new technologies
and Same time I need to run the movies by plex so my CPU i5 3570K so Weak when I encoding And specifically encoding 4K movies
almawdah is offline
post #9 of 13 Old 02-21-2020, 11:10 PM
rekbones's Avatar
Quoted: 1245 Post(s)
Liked: 630
Unfortunately you will need to upgrade everything except the PS. I am not up to speed on your case but all new mother boards require ddr4 memory and your video card is about the minimum for MadVR. You also want a PCI SSD as they are 4 times faster then SATA. Just as an example I just upgraded mine to a Ryzen 7 2700 (last years cpu as the 3700 is just been released), new Biostar AM4 motherboard, 16GB of DDR4 3200 mem, and a 256GB PCIe SSD all for well under $300.
almawdah likes this.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is online now
post #10 of 13 Old 02-22-2020, 12:16 AM - Thread Starter
Liked: 0
I think I will do what u say , I will upgrade all part and maybe I will upgrade the case also
So what u refer to me about the gpu if I wont to to run MadVR with high setting
almawdah is offline
post #11 of 13 Old 02-22-2020, 12:46 AM
markmon1's Avatar
Quoted: 6175 Post(s)
Liked: 4223
For an HTPC, your CPU is fine. But if you are also running plex media server *on your HTPC* then you're taking the graphics card and CPU away from playback in madVR and giving it to doing transcodes etc. I'd suggest installing plex media server on another pc. You can put the GTX1660 in it and set it to do hardware transcodes. Honestly, your setup is fine for madVR. Your graphics card could use an upgrade to say a 2070 or better, but the 1660 is sort of a bare minimum but still workable in most cases.
I think upgrading CPU will be a waste of money for you in this case.
Video: JVC RS4500 135" ST130 G4 screen in batcave, htpc nvidia 1080ti madVR.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, Infinite Baffle Subs 4x15 fi audio running on behringer ep4000 + 2x12 fi audio mounted in main chair firing into back.
markmon1 is offline
post #12 of 13 Old 02-22-2020, 08:44 AM
Charles R's Avatar
Liked: 881
post #13 of 13 Old 03-14-2020, 06:03 PM
6athome's Avatar
Quoted: 655 Post(s)
Liked: 176
I don't know if your are running window 7 or not?
I built a Skylake i7, windows 8.1, WMC, HTPC,last year. I had the WMC key so I put it together. If you are going to use WMC stay with windows 7.
Playready is a mess on windows 8.1,(support until 2023 LOL) won't allow playing of Fox channels or HBO. I can only find downloads for playready 1.3 and that's not working on windows 8.1.
I tried to find the latest verision of playready but no go,found a link for playready 1.3.10 but winscrew disabled it,no download links for 3.0.
I whish someone other then Microscrew, wold come out with a DRM, copy program for cablecards.
I unistalled playready and sliverlight, WMC still shows non DRM channels. Digital cable advisor on Windows 8.1 is another pice of junk for 8.1.
6athome is offline
Reply Home Theater Computers
