Hardware Mornitoring - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-12-2020, 05:16 PM - Thread Starter
Quoted: 608 Post(s)
Liked: 132
like most, whenever i build a new pc i install several different monitoring softwares just to make sure things seem to be running ok, and then i usually forget about them... but since i have a new build i've been using hwmonitor quite a bit as i run my new system through the paces, and noticed this blank temp line - does this mean i have a bad sensor on my mobo? could it be an indication of a bigger issue, now or down the line?
aeneas01 is offline
post #2 of 3 Old 03-12-2020, 07:30 PM
cTwining's Avatar
Quoted: 45 Post(s)
Liked: 30
Originally Posted by aeneas01 View Post
hwmonitor ... this blank temp line
aeneas01,
On my Gigabyte/AORUS motherboard, two thermistors are not plugged in.
HWMonitor simply skipped them. It didn't report 0C temperatures.
In Bios setup --> "Smart fan 5 settings", the thermistors EC_TEMP1 & 2 are reported (correctly) as missing.
Perhaps your motherboard's bios could identify the sensor that's reporting 0C.
Carl
cTwining is offline
post #3 of 3 Old 03-13-2020, 05:16 AM - Thread Starter
Quoted: 608 Post(s)
Liked: 132
thanks very much, that seems to be it, and zero to worry about from what i can tell.... in fact after some more googling it looks like hwmonitor is known to report 0 to 100c+ when it comes to unused probe connections.
Originally Posted by cTwining View Post
aeneas01,
Carl
aeneas01 is offline
Reply Home Theater Computers
