Bluray (PowerDVD 15) playback is getting more often choppy - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-15-2020, 02:21 PM - Thread Starter
metropole's Avatar
Quoted: 92 Post(s)
I am using PowerDVD 15 for Bluray playback. It seems that newer movies more often exhibit some choppy pans.
I have looked at CPU, GPU usage and made sure I have latest software as much as possible.
I ma pretty certain it started during the last 6 months on new Netflix releases.
I have a LG WH16NS40 drive from 2016.
I realize this could be caused by many factors. Just wondering if anybody ever came across a similar issue and found a solution.
metropole is offline
post #2 of 6 Old 03-15-2020, 08:36 PM
rekbones's Avatar
Quoted: 1248 Post(s)
Liked: 630
A standalone Blu Ray player is fairly inexpensive and trumps by a wide margin trying to use a HTPC as a Blu Ray player.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
post #3 of 6 Old 03-16-2020, 05:09 AM
captain_video's Avatar
Quoted: 806 Post(s)
Liked: 458
I used to playback Blu-Ray iso's using PowerDVD but ran into the same issue with stuttering and freezing. I tried converting the Blu-Ray disc to mkv files and never had a problem with it. I have since converted my entire library to mkv files using MakeMKV. You can play them back in Kodi, MPC-HC, MPC-BE, VLC Media Player, and JRiver Media Center and probably other apps as well. I have several HTPCs in the house connected to individual HDTVs and having the mkv files on a server makes it very easy to play them on any TV. I don't have to deal with physical discs or worry about damaging them. I rip them and then put them away for safekeeping.
captain_video is offline
post #4 of 6 Old 03-16-2020, 05:12 PM - Thread Starter
metropole's Avatar
Quoted: 92 Post(s)
I use mostly Netflix rental discs. Trying to avoid ripping.
Would re-clock help?
I also noticed that PowerDVD sets the nvidia output to 23 frames. Is this expected (vs 24?)
post #5 of 6 Old 03-17-2020, 06:24 PM - Thread Starter
metropole's Avatar
Quoted: 92 Post(s)
btw. When I put to 60Hz I don't have judder. I am assuming 24Hz woudl be prefered?
post #6 of 6 Old 03-18-2020, 05:36 AM
Quoted: 806 Post(s)
Liked: 458
Get yourself a standalone player for your Netflix rentals. It's easier and more cost effective and will save you a lot of headaches.
Reply Home Theater Computers
