PC Media Server Placement - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By greggplummer
post #1 of 12 Old 03-31-2020, 05:27 PM - Thread Starter
rustolemite's Avatar
Quoted: 385 Post(s)
Liked: 136
Have a dumb question is okay to put my tower PC close to my front tower speaker? It would be about 6 inches from my tower speaker which is a PowerSoundAudio MTM-210T.
This will be my media server which has 5 WD Red 8TB 5400 rpm drives.
Thanks for any input
VIDEO: Epson 5050UB * SeymourAV CenterStage XD 137.7" * Samsung UBD-M9500 * Nvidia Shield * HTPC * Xbox OneX * URC MX-990
AUDIO: Yamaha RX-A3080
SPEAKERS: PSA MTM-210T L/C/R * PSA MTM-110 (2) Surrounds * S2(4) Atmos * HSU VTF-3MK4
http://www.invelos.com/dvdcollection.aspx/Rustolamite
rustolemite is offline
post #2 of 12 Old 03-31-2020, 05:32 PM
Squirrel!'s Avatar
Quoted: 867 Post(s)
Liked: 549
Yes, that's fine. You just don't want a CRT TV near a speaker like that.
Main: Mitsubishi 73736|OTA|fireTV|Sony BDP-S1100|Denon AVR4311CI|MartinLogan Preface|Phantom|MartinLogan Encore TF|1-1000watt & 1-500watt DIY 12" Subs|2 Bass Shaker|APC H15 Power Conditioner|Harmony Hub|Sennheiser RS 160|SMSL B1 BT Rx|Linksys SE2500
MBR: Vizio VF550M|OTA|fireTV3|Sony BDP-S1100|Denon AVR-X1000|Chane A1rx-c|Phantom|Dayton SAT-BK|MartinLogan Dynamo 300|Belkin PF30|Harmony 550
Squirrel! is offline
post #3 of 12 Old 03-31-2020, 06:04 PM
richtomp's Avatar
Quoted: 21 Post(s)
agreed. you should be fine.
richtomp is offline
post #4 of 12 Old 04-01-2020, 05:32 AM - Thread Starter
Quoted: 385 Post(s)
Liked: 136
Thanks for the input was hoping it would be okay, was kinda worried about vibration when I am playing music extra loud but that is only once or twice a week.
post #5 of 12 Old 04-01-2020, 05:33 AM - Thread Starter
Quoted: 385 Post(s)
Liked: 136
Thanks for the input.
post #6 of 12 Old 04-01-2020, 08:05 AM
greggplummer's Avatar
Quoted: 26 Post(s)
Is that a silent PC? If not, why would you place it near a speaker? During quiet passages, you're going to hear the buzzing fan noise.
If it isn't silent, I'd try to place it away from my speakers. Ideally, in another room.
I also have a media server. It's located in a backroom in my basement, right next to my modem, router, and switches. I have a fairly basic home network with a few PCs connected via Ethernet.
Sent from my moto x4 using Tapatalk
Squirrel! likes this.
greggplummer is offline
post #7 of 12 Old 04-01-2020, 10:53 AM - Thread Starter
Quoted: 385 Post(s)
Liked: 136
I also have a media server. It's located in a back room in my basement, right nexy to my modem, router and switches. I have a fairly basic home network with a few PCs connected via Ethernet.
Well it has 4 8TB WD Reds 5400rpm and 4 120mm Noctua fans. I really don't have anywhere else to put except in the room with the rest of my equipment. The closest place is a room behind my rack but then would need at least a 20 network cable to get back to the router.
post #8 of 12 Old 04-01-2020, 01:45 PM
Quoted: 26 Post(s)
I'd buy a nice ethernet cable from monoprice.com. They're good quality and pretty cheap.
post #9 of 12 Old 04-11-2020, 02:04 AM
NIAVANNA's Avatar
Liked: 7
Are you concern bout electromagnetic interference ? no worry, you will be fine cause I do the same thing
NIAVANNA is offline
post #10 of 12 Old 04-11-2020, 02:27 AM
markmon1's Avatar
Quoted: 6580 Post(s)
Liked: 4730
Those HDD's will be spun down (off) most the time and only spinning when in use.
A 20 foot network cable doesn't sound like it should be a problem btw.
Video: JVC RS4500 135" ST130 G4 screen in batcave, htpc nvidia 1080ti madVR.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, Infinite Baffle Subs 4x15 fi audio running on behringer ep4000 + 2x12 fi audio mounted in main chair firing into back.
markmon1 is offline
post #11 of 12 Old 04-11-2020, 04:14 AM - Thread Starter
Quoted: 385 Post(s)
Liked: 136
Yeah I guess that as well as vibration.
Luckily I was able to move the tower (Fractal R6) to the right side of the rack against the wall. I swapped out my huge rack for a smaller foot print Salamander Archtye.
And had more room than I thought.
Do you have a pic of your setup?
Thanks for your input.
post #12 of 12 Old 06-02-2020, 02:39 PM - Thread Starter
Quoted: 385 Post(s)
Liked: 136
Please close this thread.
Reply Home Theater Computers
