DDL HTPC Upgrade - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 04-25-2020, 08:35 PM - Thread Starter
jasguild's Avatar
DDL HTPC Upgrade
I have an older HTPC based on Win 7 32bit based on Asus M4A88TD-V EVO/USB3 that I use primarily to play mp3, youtube and surf the web. Because Win 7 is no longer being supported I am thinking about going to windows 10. However, I have Turtle Bay Montego card in it based on CMedia 8768 chip which does not have a wind 10 driver. I also am still in love with Windows Media center which is also not support by windows 10.
I love the montego card because it has has Dolby digital live which in my opinion does an excellent job with my mp3 music. I have tried using my MB sound options to send stereo to my Denon 1910 receiver which then encodes with pro logic for my 5.1 speaker set up but doesnt sound as good to me.
I know the general sentiment on the internet is that DDL is old school but I cant just seem to get pro logic to sound comparable for mp3s.
Any ideas or suggestions.
If you ain't a Gator, then you must be GATOR BAIT!!!!
jasguild is offline
post #2 of 8 Old 04-25-2020, 08:46 PM
markmon1's Avatar
Quoted: 6579 Post(s)
Liked: 4726
A windows 7 / 8 x64 driver will still work in windows 10 for that hardware. Other people have gotten it to work.
Getting windows media center going may be more challenging.
If this is a limited use PC that you're only using for HTPC duties, why not just keep at windows 7?
Video: JVC RS4500 135" ST130 G4 screen in batcave, htpc nvidia 1080ti madVR.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, Infinite Baffle Subs 4x15 fi audio running on behringer ep4000 + 2x12 fi audio mounted in main chair firing into back.
markmon1 is offline
post #3 of 8 Old 04-26-2020, 11:20 AM - Thread Starter
jasguild's Avatar
Hey thanks for responding.
Well supposedly MS stop supporting windows 7 earlier this year and there are suggestions that its going to be vulnerable to attacks. Is that not correct?
Also is it correct that I can not get dolby or other encoded sound out of my htpc while playing MP3? My mb, has HDMI, 8 channel audio and Optical but I cant figure out how to get any digital 5.1 sound out of it.
Thanks for your help
jasguild is offline
post #4 of 8 Old 04-28-2020, 02:42 PM
HTPC8813's Avatar
Quoted: 28 Post(s)
IN my opinion, if that is just a HTPC without important financial information, even it is under attack what do you lose? The worst case scenario is that he PC is locked. YOu can always reformat it and restore from backup.
HTPC8813 is offline
post #5 of 8 Old 05-13-2020, 04:25 PM - Thread Starter
jasguild's Avatar
That is very true!
jasguild is offline
post #6 of 8 Old 05-25-2020, 08:48 PM
ES_Revenge's Avatar
Quoted: 584 Post(s)
Liked: 193
I think you can still do the trick with most Realtek chips, where you can just use the "hacked" drivers to enable DDL and DTS-Connect support, no? That's another option if it's doable for the ALC892 that is on that ancient board, lol.
ES_Revenge is offline
post #7 of 8 Old 05-26-2020, 01:59 PM - Thread Starter
jasguild's Avatar
where would I get a hacked driver
jasguild is offline
post #8 of 8 Old 05-26-2020, 08:45 PM
ES_Revenge's Avatar
Quoted: 584 Post(s)
Liked: 193
Should be able to find online by searching for "hacked realtek driver" or "enable dolby live realtek" or something similar.
Reply Home Theater Computers
