Long HDMI: Argument Against or Good Budgeting for HTPCs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-10-2020, 12:14 AM - Thread Starter
Ahenobarbus's Avatar
Liked: 0
Lightbulb Long HDMI: Argument Against or Good Budgeting for HTPCs
Guys, I am building a main home PC now and I'm planning for a future HTPC too near my TV, and I'm thinking why have an ITX HTPC when you can run a long HDMI cable from your main PC to your TV's receiver? Control through wireless keyboard/trackpad.
Has anyone realised this or is there a fundamental flaw?
50m HDMI cable for $99.99 on Amazon: https://www.amazon.com/CNE634074-Fib.../dp/B01IBAGUUY
Ahenobarbus is offline
post #2 of 8 Old 05-10-2020, 03:13 AM
markmon1's Avatar
Quoted: 6579 Post(s)
Liked: 4726
If your needs are only 1080p and not 4K this might be ok. But I'd assume you're going to want 4K, in which case you'll need a fiber optic cable. The longer the run, the more flaky the HDMI will be. Also, how far is the PC for the keyboard / mouse? I'd recommend a Logitech K400, but of course performance depends on range.
Video: JVC RS4500 135" ST130 G4 screen in batcave, htpc nvidia 1080ti madVR.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, Infinite Baffle Subs 4x15 fi audio running on behringer ep4000 + 2x12 fi audio mounted in main chair firing into back.
markmon1 is offline
post #3 of 8 Old 05-10-2020, 03:52 AM - Thread Starter
Liked: 0
Hey, thanks for replying!
Fibre optic, I understand. If my PC is in another room and I am using a fibre optic cable, how do I transmit sound to my TV's receiver?
If my PC has a GPU with HDMI and display port connections, which connections should my fibre optic cable have?
post #4 of 8 Old 05-10-2020, 04:06 AM
Worf's Avatar
Quoted: 934 Post(s)
Liked: 666
Fiber optic HDMI cables. They exist, and are $$$$, but are unidirectional so make sure you connect it the right way.
They are also required if your cable is more than 50' in length. Don't be surprised if you're paying $200 or more for 100'.
I'm not sure that 50m cable would even work at 1080p. Flaky at best since HDMI is only spec'ed to about 15m or so (50').
If you want a 50m fiber optic HDMI cable good for 4k, you're going to be shelling out $3-400 for it.
Worf is offline
post #5 of 8 Old 05-10-2020, 04:35 AM - Thread Starter
Liked: 0
100 feet is $74.99: https://www.amazon.com/ATZEBE-Optica.../dp/B07KG71K8K
I need to read if the signal will be stable or what the limitations are.
$275 for the latest ultra high speed cable with eARC at 100 feet: https://www.monoprice.com/product?p_id=38629
post #6 of 8 Old 05-10-2020, 06:20 AM
markmon1's Avatar
Liked: 4726
What do you need eARC for on an HDMI cable between an HTPC and AVR??
markmon1 is offline
post #7 of 8 Old 05-10-2020, 09:41 PM
rekbones's Avatar
Quoted: 1340 Post(s)
Liked: 683
Long HDMI runs are well established as unreliable so it's up to you if you want to experiment with your money as you can't always trust the manufactures claims. Second most wireless keyboards are Bluetooth and can be problematic even at their claimed range of about 30' max. Most of us use a streamer like a FireTV, Roku, ATV or Shield as a front end using Plex, KODI or any other software to stream from your main PC.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
post #8 of 8 Old 05-11-2020, 10:27 PM
bob2300NX's Avatar
Quoted: 18 Post(s)
Check out the tivo 4k stream, its only $50 till 5/27. Or if you need atmos audio (currently not working on the tivo) get an nvidia shield. This would be a much better experience than controlling a PC from another room, assuming your network can handle whatever you are trying to stream.
bob2300NX is offline
Reply Home Theater Computers
