Windows 10 PCM Output - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-14-2020, 06:30 PM - Thread Starter
Quoted: 17 Post(s)
Good afternoon,
I have a nanoAVR HD that I use in conjunction with REW to equalize my 5.1 system. I have an old laptop that I use with no issues. I will connect it to the nanoAVR and I will equalize away. The laptop is getting quite old. I have an NUC7i7BNH that I tried to use but I guess I cannot get it to output PCM since I am not getting a signal when I hook it up to the miniDSP. It works fine when I hook it up directly yo the receiver.
How do I force Windows10 to output LPCM?
Thank you in advance.
Cleveland
ClevelandFreeman is offline
post #2 of 4 Old 05-15-2020, 05:11 PM
ES_Revenge's Avatar
Quoted: 584 Post(s)
Liked: 193
What is connected on the other end of the nanoAVR HD--i.e. what is on the HDMI output? I believe that device (assuming pre-amp or AVR) will have to be on in order for it to be detected as a multi-PCM device to send audio to. Either that or the nanoAVR needs to have its own EDID info and present itself as a "display" with multi-PCM capability.
ES_Revenge is offline
post #3 of 4 Old 05-16-2020, 01:40 PM - Thread Starter
Quoted: 17 Post(s)
The output of the nanoAVR is the input to the receiver, Marantz NR1509, it is on when I try to hook up the new PC to the NanoAVR. I'll go check it's settings to see if there is an adjustment I need to make.
post #4 of 4 Old 05-16-2020, 07:31 PM
ES_Revenge's Avatar
Quoted: 584 Post(s)
Liked: 193
Hmm well that's weird because it should detect either that or the nanoAVR itself as the "display" device for outputting audio.
Reply Home Theater Computers
