USB 3.0 HDD Enclosures for Plex? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-17-2020, 05:12 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 9
Hi,
Are there any cons to using a USB 3.0 multi-HDD enclosure for media storage (https://www.amazon.com/dp/B0734G79FW for example) if my computer is always on anyways? Using a Shield for local network playback.
Thanks in advance.
cp hsia is offline
post #2 of 4 Old 05-17-2020, 07:58 PM
rekbones's Avatar
Quoted: 1340 Post(s)
Liked: 683
Originally Posted by cp hsia View Post
Hi,
Thanks in advance.
Only the fact that there is no redundancy like raid so if it fails you lose all data. As long as you do full backup regularly its not an issue. I prefer a NAS raid box myself but still no excuse not to have it backed up. Or are you talking about a NAS that is USB 3.0 as opposed to using it networked I guess its fine if the computer is always on.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
post #3 of 4 Old 05-17-2020, 08:35 PM
Kelson's Avatar
Quoted: 2322 Post(s)
Liked: 1434
Are there any cons to using a USB 3.0 multi-HDD enclosure for media storage . . .
Not really. I have a small i3 Shuttle PC running as a media server. I have 4 Mediasonic 4-bay enclosures connected via eSATA as the disk farm. Works very smoothly with 16 external HDD's. The only con I can see is if you use USB 3 rather than eSATA. It is hard to get SMART data across a USB bridge if you want to keep track of HDD health. That is one of the reasons I installed eSATA adapters.
Mediasonic sells 4-bay enclosures that will do RAID 5. Those may be more suitable for you if are using USB 3.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #4 of 4 Old 05-18-2020, 09:06 AM
mlknez's Avatar
Quoted: 635 Post(s)
Liked: 214
If you attach to a windows 10 pc, i would turn on storage spaces to protect against drive failures.
Media Room: LG oled65c7, Marantz AV8805, Sherbourn 7/2100, Emotiva A-300, Studer A80, Studer Revox b795, Nakamichi RX-202, HTPC, exaSound e38, Sweetvinyl Sugarcube SC-2, (2) Piega P10, Piega Coax Center, (6) Piega AP 1.2, Hsu VTF-15h mk2
Office: Emotiva mini-x A100, Geek Pulse, (2) KEF LS-50, Goldenear FF 4, PC, NAS 130TB
Bedroom: Panasonic TCP55vt35, Marantz NR1200, Dune 3 Prime, (2) Elac Uni-Fi UB5
mlknez is online now
Reply Home Theater Computers
