MPC-BE suddenly not bitstreaming. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-18-2020, 08:08 PM - Thread Starter
Liked: 0
Hi all.
I've been using a standard PC to run media via HDMI to a receiver (RVX 573) and TV, using MPC-BE, MadVR & Lav filters; been working fine for over a year. I've set it all up to bitstream audio to the receiver, no issues.
I tried to play a movie the other night, and the receiver showed PCM. Thought it was the movie, so tried others that have worked in the past, same deal. When I checked MPC-BE, it showed it was using Lav Video & splitter, but internal audio filter. After trying several movies, the following strange behavior has occurred.
Movie 1: TrueHD - Receiver shows: PCM
Movie 2: DTS MHD- Receiver shows: PCM
Movie 3: DTS MHD - Receiver shows: DTS
Movie 4: Dolby Digital - Receiver shows: Dolby Digital
So it seems to be software decoding TrueHD & DTS Master HD, but bitstreaming DTS & DD. I've checked all the settings in MPC-BE, Lav filters etc, it's all good (Lav set to prefered, all formats unticked in internal filter). Also checked windows sound (I know it shouldn't be relevant) and it's detecting the receiver supports the higher formats, so EDID seems to be intact. Also tried uninstalling the Lav filters altogether, problem remained, so it seems to be an MPC-BE issue.
So, question is, anyone know why MPC-BE has suddenly decided to stop using Lav audio? And even if it's not using Lav, shouldn't the internal filter be able to bitstream these formats?
GtrainAU is offline
post #2 of 2 Old 05-18-2020, 09:48 PM
rekbones's Avatar
Quoted: 1326 Post(s)
Liked: 671
Did try to reload the HDMI audio driver? Windows update crashes the driver on a regular basses. Also try a right click in the audio icon and run the trouble shooter as it should give you the option to reload the driver.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
Reply Home Theater Computers
