Do I really need a 2070 or 2080 Graphics Card? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-19-2020, 04:58 AM - Thread Starter
steve shafer's Avatar
Ok, were building a HTPC to rip and play movies. I probably have 800 Blu-Ray's and 1000 DVD's. I have a JVC NX7 and stream with a Apple 4K TV.
I have a number of the movies already ripped from my old HTPC. I"m going to be upscaling them using madvr and have read a number of threads where the 2060 graphics cards is good but now I'm seeing posts of 2070 or even 2080.
I do not game so bottom line is 2060 the way to go or do I spend another $100+ and go 2070?
Thanks for your insight
Steve
steve shafer is offline
post #2 of 5 Old 05-19-2020, 05:05 AM
mlknez's Avatar
Quoted: 627 Post(s)
Liked: 213
You could get away with a 1060.
Sent from my LG-H931 using Tapatalk
Media Room: LG oled65c7, Marantz AV8805, Sherbourn 7/2100, Emotiva A-300, Studer A80, Studer Revox b795, Nakamichi RX-202, HTPC, exaSound e38, Sweetvinyl Sugarcube SC-2, (2) Piega P10, Piega Coax Center, (6) Piega AP 1.2, Hsu VTF-15h mk2
Office: Emotiva mini-x A100, Geek Pulse, (2) KEF LS-50, Goldenear FF 4, PC, NAS 130TB
Bedroom: Panasonic TCP55vt35, Marantz NR1200, Dune 3 Prime, (2) Elac Uni-Fi UB5
mlknez is online now
post #3 of 5 Old 05-19-2020, 04:10 PM - Thread Starter
Thanks for responding so if I use a 2060 card with !6 gig of ram I should be good
post #4 of 5 Old 05-19-2020, 09:17 PM
rekbones's Avatar
Quoted: 1326 Post(s)
Liked: 671
If you don't mind buying used there are a lot of GTX cards flooding the market. I don't think MadVR can really take advantage of any of the RTX advanced features but honestly don't know. You can buy a used GTX 1080ti for third or less then the cost of equivalent RTX cards. From the benchmarks I have seen the 1080ti is only a little behind the RTX 2080ti for the majority of uses.
"Smart enough to know better, to old to care" ------ Dedicated Bat Cave Home Theater, JVC RS49U/Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 18TB DroboFS NAS
rekbones is offline
post #5 of 5 Old 05-20-2020, 05:25 AM - Thread Starter
I appreciate the input. I pulled the plug and just ordered a 2060 Super. All of my parts should arrive today and tomorrow and start the build. Hopefully it will last a while.
I'm kind of excited.
Thanks again
Reply Home Theater Computers
