Can't get HDR from HTPC to TV - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By mlknez
post #1 of 4 Old 05-24-2020, 02:08 PM - Thread Starter
corwiniii's Avatar
Quoted: 102 Post(s)
Liked: 250
Hi all,
What I want to do is get HDR to display on the TV from my HTPC. I have ripped UHD MKVs with HDR that I want to watch using VLC or Plex. I'm open to other software, but really not looking for more than that. Movies play in 2160 fine, just not HDR based on the TV INFO.
I can get 3840x2160 at up to 30Hz to work. I can't get 60Hz to work (black screen until it rolls back to 30Hz).
When I go to Windows 10 Settings, Display, and toggle on the Play HDR games and apps, my display is totally hosed. I have to boot into Safe Mode and roll back to a prior Windows Settings backup to get the display working again.
When I go into Windows HD Color Settings, under Display Capabilities the Stream HDR video shows No, but Play HDR games and apps is Yes, and Use WCG apps is Yes.
Not really sure what to use in nVidia control panel, but current settings are:
4K x 2K 3840 x 2160 (native) 30Hz refresh rate
Nvidia color settings
Desktop color depth - Highest (32-bit)
Output Color Depth - 10bpc
Output color format - YCbCr 422
Output dynamic range - Limited
Hardware setup is
HTPC -> Denon AVR S920W -> Vizio P75-C1
Windows 10 Pro 1909 build 18363.836
Sandy Bridge Core i5-2500K CPU
GTX 1650 Super SC GPU
What am I doing wrong, or am I hitting a software, hardware, cable limit? Thanks for any help!
ID:	2732020   Click image for larger version
ID:	2732022   Click image for larger version
Klipsch RP-8000F L/R | Klipsch RP-504C C | Klipsch RP-500SA atmos | elemental Designs A6-6T6 MTM surrounds | Rythmik FV18 Rev2 Paper Cone Black Matte + Elemental Designs A5-350 Restored! | Denon AVR-S920W | Vizio P75-C1
corwiniii is offline
post #2 of 4 Old 05-24-2020, 04:00 PM
mlknez's Avatar
Quoted: 661 Post(s)
Liked: 221
use dvdfab media player
corwiniii likes this.
Media Room: LG oled65c7, Marantz AV8805, Sherbourn 7/2100, Emotiva A-300, Studer A80, Studer Revox b795, Nakamichi RX-202, HTPC, exaSound e38, Sweetvinyl Sugarcube SC-2, (2) Piega P10, Piega Coax Center, (6) Piega AP 1.2, Hsu VTF-15h mk2
Office: Emotiva mini-x A100, Geek Pulse, (2) KEF LS-50, Goldenear FF 4, PC, NAS 130TB
Bedroom: Panasonic TCP55vt35, Marantz NR1200, Dune 3 Prime, (2) Elac Uni-Fi UB5
mlknez is online now
post #3 of 4 Old 05-24-2020, 07:54 PM - Thread Starter
corwiniii's Avatar
Quoted: 102 Post(s)
Liked: 250
Bleh, that was too easy, it worked. I guess I was overthinking it. Thank you!
post #4 of 4 Old 05-29-2020, 06:41 PM - Thread Starter
corwiniii's Avatar
Quoted: 102 Post(s)
Liked: 250
I went down a bit of a rabbit hole instead with madVR and MPC-HC. Really with I could have just gotten VLC or Plex to play in HDR. But oh well. MPC-HC seems to work OK and I get the HDR10 notification on my TV screen...
Reply Home Theater Computers
