Antec fusion remote htpc case - black - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 06-28-2020, 12:13 AM - Thread Starter
Sheepdisease's Avatar
Hello there, I have been given this case and it is excellent.
I am having problems powering the display though and not sure where I am going wrong.
There is a cable with three pins and I have never seen it in a female type arrangement like this before. Does anyone know what this is and where it goes?
The instructions refer to another cable supplying power/communication to the display and volume control. I have one slot on my Motherboard that matches but it's an AMD LED Fan USB Header (USB_5) according to the Motherboard manual. Does that matter? If that's the problem, what are my options? Is there a way to connect a standard USB port to one of the Motherboard headers?
Sheepdisease is offline
Reply Home Theater Computers
