Help an old woman - AVS Forum | Home Theater Discussions And Reviews
post #1 of 27 Old 11-25-2017, 06:03 PM - Thread Starter
shar2649's Avatar
Quoted: 20 Post(s)
Help an old woman
Robman, if you're around, I think you've helped before....still running 5 Replays thru wired (not wifi) XE104's, Netgear router N041 and Surfboard 6121 which Comcast is now telling me I have to upgrade for higher speed...oh and all that runs through an Ooma phone line. Any suggestions?
shar2649 is offline
post #2 of 27 Old 11-26-2017, 11:31 PM
Reden's Avatar
Quoted: 44 Post(s)
Liked: 65
I don't think your router will make a difference, but your IP range may change and you may need to update static IPs. Are you saying your cablebox will change too? Maybe that's why you're asking the Robman for help.. (IR codes)
I'm sure you're not using dialup through Ooma, there aren't any dialup numbers any more.
If it's worth doing, it's worth doing in PERL!
Reden is offline
post #3 of 27 Old 11-27-2017, 11:45 AM - Thread Starter
shar2649's Avatar
Quoted: 20 Post(s)
No they are not saying the cablebox will change, just that I need a new modem....one of the ones they listed is Netgear CM600...and no it's not dialup thru Ooma. At this point though I am hopelessly lost as to why I need a different modem except that Comcast says so! Any help I can get will be good.
shar2649 is offline
post #4 of 27 Old 11-27-2017, 12:06 PM
uniquepattern's Avatar
Quoted: 810 Post(s)
Liked: 857
Ask Comcast why specifically they want you to upgrade modems (I cant figure out why they would say you need to upgrade) as you current gear should be more then adequate.
uniquepattern is offline
post #5 of 27 Old 11-27-2017, 09:41 PM
Reden's Avatar
Quoted: 44 Post(s)
Liked: 65
I doubt any customer service person would be able to understand, much less explain why she needs a new modem.
Do you use WiRNS or LaHo?
Do you know if you have any static IP addresses (if you use WiRNS, probably)
If you use WiRNS, did you set it up or did someone else? Are they available?
Robert
Reden is offline
post #6 of 27 Old 11-28-2017, 08:42 AM
mlloyd's Avatar
Quoted: 52 Post(s)
Are you getting faster internet?
I have that same model of modem, and get 50Mbps downstream. Apparently, this modem cannot handle downstream speeds above about 172Mbps. A more capable modem is desirable to the cable company even if your speed is less than that. The company here requires a better modem for new users.
They recommend faster Surfboard models.
mlloyd is offline
post #7 of 27 Old 11-28-2017, 10:42 AM - Thread Starter
shar2649's Avatar
Quoted: 20 Post(s)
Thank you all.....yes, I use WIRNS and it works fine. Can you give me some examples of faster Surfboard models? One I saw listed thru Amazon was Netgear CM 600 or Netgear CM 700
shar2649 is offline
post #8 of 27 Old 11-29-2017, 09:54 AM
mlloyd's Avatar
Quoted: 52 Post(s)
SB6141 8 DS channels (twice the speed of what you have)
SB6183 16 DS channels (four times the speed)
SB6190 32 DS channels (eight times the speed)
SB8200 DOCSIS 3.1 (should work on 1Gbps service)
mlloyd is offline
post #9 of 27 Old 11-29-2017, 10:52 AM - Thread Starter
shar2649's Avatar
Quoted: 20 Post(s)
Thank you SO much for helping...out of the four you listed the only one it took me to on Amazon was the 6183. So, and I know this is a stretch, do you think I should go ahead and order it? i think it's about $94. I will await your response before I do anything.
shar2649 is offline
post #10 of 27 Old 11-30-2017, 09:16 AM
mlloyd's Avatar
Quoted: 52 Post(s)
I saw it for $69 on Amazon today (the 6190 is $94.99). I think this would be a good modem for you. You might want to check with your cable company first, to make sure this is acceptable.
mlloyd is offline
post #11 of 27 Old 11-30-2017, 11:09 AM - Thread Starter
shar2649's Avatar
Quoted: 20 Post(s)
Please do not forget that in addition to all the other stuff, I have an Ooma phone hooked up THANKS.
shar2649 is offline
post #12 of 27 Old 11-30-2017, 03:28 PM - Thread Starter
shar2649's Avatar
Quoted: 20 Post(s)
I did send a request to Comcast but have heard nothing from them so far.
shar2649 is offline
post #13 of 27 Old 11-30-2017, 03:31 PM - Thread Starter
shar2649's Avatar
Quoted: 20 Post(s)
As reminder, that's 5 Replays located in different rooms, using WIRNS and XE104's along with the Ooma phone.
shar2649 is offline
post #14 of 27 Old 11-30-2017, 03:33 PM - Thread Starter
shar2649's Avatar
Quoted: 20 Post(s)
So, as soon as I hear from you I will be ordering the SB6183 for 69.00 from Amazon. Again, I canot thank you enough.
shar2649 is offline
post #15 of 27 Old 12-01-2017, 09:33 AM
mlloyd's Avatar
Quoted: 52 Post(s)
It would have helped to say what it is rather than just give a model number, but I looked that up and it appears to be a combination ethernet switch and powerline adapter. What modem you're using should have nothing to do with this, although these will limit your speed (which probably makes no difference with the Replays).
mlloyd is offline
post #16 of 27 Old 12-01-2017, 09:42 AM
mlloyd's Avatar
Quoted: 52 Post(s)
As far as I can tell, the Ooma device is what's connected directly to your modem. I didn't find anything on what modem you can use, so expect it to work with anything.
mlloyd is offline
post #17 of 27 Old 12-01-2017, 04:57 PM - Thread Starter
shar2649's Avatar
Quoted: 20 Post(s)
OK I ordered the SB6183 from Amazon. You would probably rather NOT hear from me again....but I sincerely thank you for helping.
shar2649 is offline
post #18 of 27 Old 12-02-2017, 02:29 PM - Thread Starter
shar2649's Avatar
Quoted: 20 Post(s)
Probably you did not want to hear from me again, but here I go....I already received the 6183 and plugged it in but nothing worked. I have a sneaking suspicion that it could be because of the Ooma hookup. Everything lights up as you would expect but I lose the phone. Any thoughts?
shar2649 is offline
post #19 of 27 Old 12-02-2017, 02:50 PM
satboy's Avatar
Quoted: 799 Post(s)
Liked: 535
If you are replacing a cable modem you need to have the cable company add it to your account or for a lack of words "provision" it.
That would be step one, the newer modems have more channels that provide increased bandwidth plus the newer DOCSIS 3.0.
Step two normally would be to connect your home router into the ethernet port of the cable modem unless your setup is like this?
Modem > Ooma > router which I see some of Ooma models support
Typical setup should be
Modem > Router > Ooma (plugged into one of the ethernet ports)
Router > provides home wireless (SSID)
Router > 4 ethernet ports for direct connected devices like the Ooma
Hope that helps?
Den - LG 65 OLEDE7P - Denon AVR-X4200W - Definitive Mythos STS - ProCenter 2000 - SR-8040BP - SVS Ultra-13 - DTV 4K - XBOX One S
Media - LG 65 OLEDC8 - AVR-X4400 - KFL28F - Vienna Acoustics Center - Def GEMS Rear - Def A60 Atmos - Monitor Silver SUB - DTV 4K - XBOX One X
My YouTube Tech Channel - https://www.youtube.com/c/TechFan
satboy is offline
post #20 of 27 Old 12-04-2017, 05:44 PM - Thread Starter
shar2649's Avatar
Quoted: 20 Post(s)
Bless you satboy for being willing to help me.....but there has been a slight delay. I am trying to write down the questions I have and BELIEVE ME I WILL get back to you. Thank you again.
shar2649 is offline
post #21 of 27 Old 12-11-2017, 11:40 AM - Thread Starter
shar2649's Avatar
Quoted: 20 Post(s)
Sorry, I don't know how to make some of those symbols you used but you said the following:
"Typical setup should be
ooma to router OR modem to router to 4 ethernet ports for direct"
To remind you, I have 5 functioning Replays connected to WIRNS....I just recently changed their addresses from 107 to 112 and they are all working fine so I do not want to screw them up...this was all because my "other" PC is not really working very well.
I have the new Surfboard 6183 at "the ready" as soon as I hear back from you. Oh, and everything is wired and not wireless. Thank you.
shar2649 is offline
post #22 of 27 Old 12-12-2017, 08:51 AM
mlloyd's Avatar
Quoted: 52 Post(s)
If the Replays are connected through the router, changing the modem wouldn't affect the local addresses it provides.
When you say 112, do you mean something like 192.168.112.10 or 192.168.1.112? IP addresses beginning with 192.168 are local addresses from the router (or possibly Ooma) and aren't affected by changing the modem. "wired or wireless" also has nothing to do with the modem.
mlloyd is offline
post #23 of 27 Old 12-12-2017, 11:23 AM - Thread Starter
shar2649's Avatar
Quoted: 20 Post(s)
Exactly, what you said 192.168.1.112...so I guess I should go ahead then and try to hook up the new modem.
shar2649 is offline
post #24 of 27 Old 02-17-2018, 07:45 PM
bri4jenn's Avatar
Quoted: 21 Post(s)
Did you get everything working?
bri4jenn is offline
post #25 of 27 Old 06-19-2018, 05:36 PM - Thread Starter
shar2649's Avatar
Quoted: 20 Post(s)
Sorry it's been a long time and I do not know if anyone can help...but we have now moved to a different zip code (WAS in 60171 and am now in 60172)...Comcast has been here many times and I no longer see any future for the Replays/ used to be all set up with my XE104's and Schedules Direct....all Replays WERE 192.168.1.and 101 thru 105. NOW the comcast idiots can only tell you that the default gateway MUST BE 10.0.0.1. DNS shows up as 75.75.75.75.75.76.76. I have tried using MANY different combinations and I cannot get anything to work. If ANYONE has any ideas, I'd be delighted to hear them. BTW the last comcast dude commented that he doubted that the Replays could record! Thanks for any help!
shar2649 is offline
post #26 of 27 Old 06-21-2018, 11:23 AM
Quoted: 24 Post(s)
Liked: 0
PLEASE REPLY to sharon2649
sharon2649 is offline
post #27 of 27 Old 06-21-2018, 11:29 AM
Quoted: 24 Post(s)
Liked: 0
Oh, and the Comcast idiots said I did not need the router and disconnected it. The three PC's I have re ALL communicating only because of the XE104 adapters.
Here's the last log I just got:
WiRNS Log WiRNS Log Feed.
[6/21/2018 12:01:52] WiRNS v3.0.5889 build 18481
[6/21/2018 12:01:52] (c) 2004-2015 rbolen70, Glenn1963 and hdonzis
[6/21/2018 12:01:52] Portions (c) 2003-2004 kjac
[6/21/2018 12:01:52] C:\WiRNS\wirns.log has been backed up to C:\WiRNS\wirns.log.20180621120151.txt
[6/21/2018 12:01:52] Deleted wirns.log.20180617182206.txt
[6/21/2018 12:01:52] C:\WiRNS\wirns.debug.log has been backed up to C:\WiRNS\wirns.debug.log.20180621120151.txt
[6/21/2018 12:01:52] Deleted wirns.debug.log.20180617174457.txt
[6/21/2018 12:01:52] **************************************
[6/21/2018 12:01:52] Time Synchronizer (C)2001 Valer BOCAN
[6/21/2018 12:01:52] Simple Network Time Protocol (see RFC 2030)
[6/21/2018 12:01:52] Modified for WiRNS by rbolen70
[6/21/2018 12:01:52] Connecting to: pool.ntp.org
[6/21/2018 12:01:35] Local time: 6/21/2018 12:01:35 PM
[6/21/2018 12:01:35] Precision: 5.52139707743245E+73 ms
[6/21/2018 12:01:35] Poll Interval: 1 s
[6/21/2018 12:01:35] Reference ID: bonehed.lcs.mit.edu (18.26.4.105)
[6/21/2018 12:01:35] Root Dispersion: 19.6685791015625 ms
[6/21/2018 12:01:35] Round Trip Delay: 32 ms
[6/21/2018 12:01:35] Local Clock Offset: -16610 ms
[6/21/2018 12:01:35] **************************************
[6/21/2018 12:01:35] Checking connection to SchedulesDirect.
[6/21/2018 12:01:36] Purging old guide/lineup information
[6/21/2018 12:01:37] Update Time: 2018-06-21 12:01:36
[6/21/2018 12:01:37] Updating guide information in the database.
[6/21/2018 12:01:37] Updating guide for SchedulesDirect account: shar2649
[6/21/2018 12:01:37] Downloading guide information for: Thu Jun 21
[6/21/2018 12:01:40] Validating 3628 schedules from SchedulesDirect for: Thu Jun 21
[6/21/2018 12:01:40] Found lineup: Comcast Elmhurst/Oak Park (60171) - Digital.
[6/21/2018 12:01:46] Downloading guide information for: Fri Jun 22
[6/21/2018 12:01:49] Validating 3626 schedules from SchedulesDirect for: Fri Jun 22
[6/21/2018 12:01:54] Downloading guide information for: Sat Jun 23
[6/21/2018 12:01:57] Validating 3674 schedules from SchedulesDirect for: Sat Jun 23
[6/21/2018 12:02:03] Downloading guide information for: Sun Jun 24
[6/21/2018 12:02:06] Validating 3576 schedules from SchedulesDirect for: Sun Jun 24
[6/21/2018 12:02:12] Downloading guide information for: Mon Jun 25
[6/21/2018 12:02:15] Validating 3541 schedules from SchedulesDirect for: Mon Jun 25
[6/21/2018 12:02:20] Downloading guide information for: Tue Jun 26
[6/21/2018 12:02:24] Validating 3592 schedules from SchedulesDirect for: Tue Jun 26
[6/21/2018 12:02:28] Downloading guide information for: Wed Jun 27
[6/21/2018 12:02:31] Validating 3592 schedules from SchedulesDirect for: Wed Jun 27
[6/21/2018 12:02:37] Downloading guide information for: Thu Jun 28
[6/21/2018 12:02:43] Validating 3552 schedules from SchedulesDirect for: Thu Jun 28
[6/21/2018 12:02:49] Downloading guide information for: Fri Jun 29
[6/21/2018 12:02:51] Validating 3608 schedules from SchedulesDirect for: Fri Jun 29
[6/21/2018 12:02:56] Downloading guide information for: Sat Jun 30
[6/21/2018 12:02:59] Validating 3660 schedules from SchedulesDirect for: Sat Jun 30
[6/21/2018 12:03:03] Downloading guide information for: Sun Jul 01
[6/21/2018 12:03:17] Validating 3552 schedules from SchedulesDirect for: Sun Jul 01
[6/21/2018 12:03:22] Downloading guide information for: Mon Jul 02
[6/21/2018 12:03:25] Validating 3604 schedules from SchedulesDirect for: Mon Jul 02
[6/21/2018 12:03:31] Downloading guide information for: Tue Jul 03
[6/21/2018 12:03:34] Validating 3642 schedules from SchedulesDirect for: Tue Jul 03
[6/21/2018 12:03:38] Downloading guide information for: Wed Jul 04
[6/21/2018 12:03:41] Validating 3553 schedules from SchedulesDirect for: Wed Jul 04
[6/21/2018 12:03:45] Vacuuming database
[6/21/2018 12:03:57] Parsing PPV Configurations.
[6/21/2018 12:03:57] Stopping ToDo Timer
[6/21/2018 12:03:57] Processing ReplayGuide Information.
[6/21/2018 12:03:57] Processing local shows.
[6/21/2018 12:03:57] Processing local shows done.
[6/21/2018 12:03:57] Refreshing Replays.
[6/21/2018 12:03:57] Refreshing RecordingGuide for: user-8cc047851d(10.0.0.248)
[6/21/2018 12:03:57] Parsed 0/0 entries as of 6/21/2018 12:03PM.
[6/21/2018 12:03:57] Refreshing RecordingGuide for: Bedroom(10.0.0.248)
[6/21/2018 12:03:57] Refreshing PhotoGuide for: Bedroom
[6/21/2018 12:03:57] Found 0 files on Bedroom
[6/21/2018 12:03:57] Refreshing RecordingGuide for: Office(10.0.0.248)
[6/21/2018 12:03:57] Refreshing PhotoGuide for: Office
[6/21/2018 12:03:57] Found 0 files on Office
[6/21/2018 12:03:57] Refreshing Replays done.
[6/21/2018 12:03:57] Refreshing ReplayGuide information.
[6/21/2018 12:03:57] Added 0 ReplayGuide shows for user-8cc047851d
[6/21/2018 12:03:57] Added 0 ReplayGuide shows for Bedroom
[6/21/2018 12:03:57] Added 0 ReplayGuide shows for Office
[6/21/2018 12:03:57] Added 0 Downloaded shows for all
[6/21/2018 12:03:57] Refreshing ReplayGuide information done.
[6/21/2018 12:03:57] Checking for shows to hide from Poopli.
[6/21/2018 12:03:57] Checking for shows to hide from Poopli done.
[6/21/2018 12:03:57] Updating ReplayGuide flags...
[6/21/2018 12:03:57] Updated ReplayGuide flags in 0.0625 seconds (0.0625 clear, 0 downloaded, 0 duplicate).
[6/21/2018 12:03:57] Uploading ReplayGuide data to Poopli.
[6/21/2018 12:03:59] Uploading ReplayGuide data to Poopli done.
[6/21/2018 12:03:59] Scheduling JIT Recordings
[6/21/2018 12:03:59] Scheduling JIT Recordings complete
[6/21/2018 12:03:59] Checking Manual Recordings.
[6/21/2018 12:03:59] Checking One-Time Recordings.
[6/21/2018 12:03:59] Processing ToDo Information.
[6/21/2018 12:03:59] Building ToDo List for: Bedroom
[6/21/2018 12:03:59] Added 0 ToDo entries for Bedroom in 0.0625 seconds.
[6/21/2018 12:03:59] Building ToDo List for: Office
[6/21/2018 12:03:59] Added 0 ToDo entries for Office in 0.046875 seconds.
[6/21/2018 12:03:59] Determining conflicts...
[6/21/2018 12:03:59] Completed conflict determination in 0 seconds.
[6/21/2018 12:03:59] Done.
[6/21/2018 12:03:59] Configured to refresh ToDo and Replay Guide every 240 minutes.
[6/21/2018 12:03:59] Collecting free memory
[6/21/2018 12:03:59] Configured to update guide at: 6/22/2018 9:30 AM
[6/21/2018 12:03:59] Loading/Refreshing Plugin Channel Guide Provider.
[6/21/2018 12:03:59] Loading ReplayZone genre data.
[6/21/2018 12:04:01] Loading Production Crew data.
[6/21/2018 12:04:01] Loaded/Refreshed Plugin Channel Guide Provider.
[6/21/2018 12:04:01] SchedulesDirect Messages:
[6/21/2018 12:04:01] SchedulesDirect Messages: Your subscription will expire: 2018-07-29T18:43:15Z
[6/21/2018 12:04:01] Ready to intercept/proxy ReplayTV requests
Reply ReplayTV & Showstopper PVRs
