Change IVS port? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-03-2018, 08:16 PM - Thread Starter
mpgruett's Avatar
Change IVS port?
I setup one of my Replays to the same IVS port as another port. I forgot that the one in the Living Room wasn't actually the Living Room unit and set the basement unit to the same port. I'm guessing a factory reset would allow me to fix this but it would also wipe out the custom blaster file I have loaded and kill the shows I have recorded on it. Any commands in the utility menu perhaps to reset this?
mpgruett is offline
post #2 of 2 Old 11-03-2018, 10:18 PM - Thread Starter
mpgruett's Avatar
Yeah; nevermind. I found in the "Internet Address Book" that you can change the name of port there ("Change Internet Identity". Obviously haven't looked at that screen too much.
mpgruett is offline
Reply ReplayTV & Showstopper PVRs
