IR Blaster code for Motorola DCT2224 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 12-25-2003, 05:30 PM - Thread Starter
reservoirman's Avatar
I just switched from Direct TV to digital cable, and now have to deal with the IR Blaster issue. Can anyone tell me how to find (or what is) the code for the Motorola Digital Cable box DCT2224?
Also, I have two IR blasters at home, am not even sure which one came with my Replay 5400 originally. Does it matter which kind I use?
I can't get the IR Blaster to work at all. Thanks.
reservoirman is offline
post #2 of 10 Old 12-25-2003, 07:17 PM
goinghome's Avatar
i use the same cable box and have had all kinds of problems in the past...im using 7930 now and have had good luck with it...give it a try
goinghome is offline
post #3 of 10 Old 12-25-2003, 07:19 PM
icecow's Avatar
You have a second option.
A serial cable can be run between your replayTV and some of the dish cable boxes. If yours is supported you don't ahve to deal with the IR Blaster at all.
I don't have DirecTV, but I gather that the older boxes worked, and some (or all) of the newer ones didn't.
check it out.
cow
icecow is offline
post #4 of 10 Old 12-25-2003, 07:20 PM
icecow's Avatar
Ah, if he just bought it he has a chance to take it back and chose from the perfered models.
cow
icecow is offline
post #5 of 10 Old 12-26-2003, 11:32 PM
rc
rc's Avatar
I'm trying to get the IR blaster working with the same cable box.
does anybody know where the IR sensor is on the DCT2224?
Rob
rc is offline
post #6 of 10 Old 12-27-2003, 08:39 AM
ShaneV's Avatar
Take a flashlight and shine it on the face plate you'll see the sensor over on thr right half of the box. Also when setting up look through the GE codes as its the same box. Im using 4876 (I think Im going off memory here)
ShaneV is offline
post #7 of 10 Old 12-27-2003, 09:12 AM
sheakt's Avatar
The sensor is located between the A/B switch label and the channel down switch. (Actually it is about midway between the POWER Label and the A/B label.)
I used the Motorola Digital box code that came up in setup. I am using IR Code 4476.
I have 2 of these boxes and 2 replays and both work extemely well....
--Kevin
sheakt is offline
post #8 of 10 Old 12-27-2003, 12:17 PM - Thread Starter
I am now using 7930 and it works well, in case 4476 doesn't.
post #9 of 10 Old 12-30-2003, 08:59 PM
superflysocal's Avatar
i don't know which DCT model i have (how do you tell)? My box is silver/gray face with a large horizontal card slit on the right side. it is time warner digital.
anyway, 7400 works for me. if it doen't work for you, look under genreal instrument after specifying others..it will be one of those codes.
superflysocal is offline
post #10 of 10 Old 12-31-2003, 06:34 PM
rc
rc's Avatar
I found that 4476 works fine.
I did have to experiment with the placement of the IR blaster in order to reduce faulty channel changes.
Thanks for your help.
Rob
rc is offline
Closed Thread ReplayTV & Showstopper PVRs
