Speaker Wire Through Drywall - No Wall Plate - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #31 of 39 Old 05-16-2013, 09:53 PM
olyteddy's Avatar
Quoted: 537 Post(s)
Liked: 943
I was thinking I would put the power strips, and all the bulk in the attic, but just pass it all (speaker wires, power cords, HDMI, etc.) through the wall to the rack.
Bad idea. Probably illegal bad.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #32 of 39 Old 09-09-2013, 09:38 PM
joyryde's Avatar
I stumbled across this post while looking for a single wire grommet, in case anyone still can't find them, here are a ton of options:
http://www.amazon.com/s/?_encoding=UTF8&camp=1789&creative=390957&field-keywords=Feed-Through%20Bushing&linkCode=ur2&tag=djdcom07-20&url=search-alias%3Dtools
They're call Feed-Through Bushings. I gave up on searching endlessly for "grommets"...once I realized they're bushings!
eBay also has plenty of options should you prefer that.
Enjoy.
chi-chi likes this.
joyryde is offline
post #33 of 39 Old 05-21-2014, 01:44 PM
Chudilo's Avatar
Originally Posted by Neurorad View Post
This is another request for my 'half gang' wall plate that I dreamed up, that nobody makes.
No small wall plates are commercially available. Make one.
Guess it took a while BUT....
They do apparently make half height Binding Post wall plates now. I found a few on ebay and here are a couple from Amazon.
http://www.amazon.com/dp/B008IGHWNG/ref=pe_385040_30332200_TE_item
Here is a recessed one (not sure if this is better as you d have to cut a larger opening in the sheetrock and I would assume that dust would collect in there.
http://www.amazon.com/Amico-Speaker-Binding-Banana-Surround/dp/B0076UIT7I/ref=pd_sim_sbs_hi_9?ie=UTF8&refRID=1M6ME1F4PWF3VZFRNEGF
Chudilo is offline
post #34 of 39 Old 05-21-2014, 03:04 PM
Neurorad's Avatar
Quoted: 283 Post(s)
Liked: 158
I saw them from China about a year ago; I guess Amico bought a pallet, or ran with the idea.
That recessed looks great. Hope they sell well.
Edit - hehe. I guess it wasn't that long ago that I posted that same image - 5 mos ago.
https://www.avsforum.com/t/1477357/diy-speaker-wire-before-drywall#post_24153288
Good to see it's now available through Amazon Prime.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #35 of 39 Old 02-12-2015, 05:56 PM
DrBabs's Avatar
Quoted: 62 Post(s)
Thanks for the tip.
https://www.avsforum.com/t/1477357/di...#post_24153288
is there any loss in signal or quality from connecting speaker wires to binding posts and then on to the receiver? seems it would be better to simply run the wire straight to the unit, without interruption.
also, what do you suggest sealing the hole in the drywall with, if it is hiding inside the soffit ? acoustic caulk? expanding foam?
thanks
DrBabs is offline
post #36 of 39 Old 02-17-2015, 06:18 AM
Neurorad's Avatar
Quoted: 283 Post(s)
Liked: 158
I googled that image. Seems like it's cheap crap, I would avoid it.
I would not be concerned about the extra connections in the speaker wire.
A drywall cable bushing may be an easy method.
Single gang low voltage ring with a pass through plate
If the hole for the speaker cable is covered by the speaker, I wouldn't bother with any plate or bushing.
Neurorad is offline
post #37 of 39 Old 06-08-2015, 05:48 AM
pilothaz's Avatar
I like your first suggestion with the simple grommet setup. I have seen the 2nd image setup with the bristles to hold/hide the wires through.
Good suggestions.
pilothaz is offline
post #38 of 39 Old 01-29-2019, 02:32 PM
B_J_G's Avatar
I know this is some serious thread necromancy, but I have been searching for a similar type of thing after moving to a house that just had speaker wire coming out the walls. I don’t have the system to use them now, but I don’t want to just shove them in the wall and lose them either. Due to the location and speaker mounts, a standard wall plate won’t fit.
I just found the following products that look promising.
https://vadcon.com/co/speaker-cps.html
I’m guessing these are for actually building speakers, but I don’t see why they wouldn’t work as a way to tidy up the wires.
B_J_G is offline
post #39 of 39 Old 01-29-2019, 08:22 PM
Otto Pylot's Avatar
Quoted: 3573 Post(s)
Liked: 2572
I don't know if this would help but look up wall plate binding posts.
I never trust an atom, they make up everything.
Otto Pylot is online now
Reply Tweaks and Do-It-Yourself
