Here is a THIN DIY Amp Cooler - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By MrBobb
post #1 of 5 Old 07-18-2018, 07:54 PM - Thread Starter
MrBobb's Avatar
Quoted: 229 Post(s)
Liked: 107
I have my stereo in a small cubby, pieces are stacked on top of each other. The Amps are generating most of the heat and "cooking" my PreAmp above. I needed a blocker, then fans to divert the heat. A store-bought cooler wouldn't fit, I made my own THIN.
First, a slap to block the Amps' heat away from my PreAmp, then mounted two very THIN blowers fans (MacBook Air), the air gap is only like 10mm. The Amps grills are over the top and bottom of their enclosures, so the fans are right above the openings. The cubby is open front, the rear is also open and exhausts into a closet with venting on top of the doors.
The fan control turns down the fans to about 3,500 RPM, above which they become audible. Result is 10c lower from what I had before without the fans.
I didn't place the Amps on top of the PreAmp because it wouldn't look right plus the Amps are heavier and have bigger footprint than the PreAmp.
ID:	2430070   Click image for larger version
ID:	2430072   Click image for larger version
rondongon likes this.
MrBobb is offline
post #2 of 5 Old 07-18-2018, 10:58 PM
genesplitter's Avatar
Quoted: 117 Post(s)
Liked: 68
Very nice design. I believe a Pulse Width Modulated (PWM) device acts like a resistor to give less power to the fan (blows slower), however unlike a resistor, which simply heats up and effectively wastes the power as heat, the PWM "pulses" at full voltage or zero voltage at variable on and off ratios, which does not waste energy as heat.
U-Turn Orbit Plus turntable, Marantz SR-7009 AVR, iNuke 6000DSP, DIY LinkwitzLab speakers, MartyCube + JohnnySub, BenQ W1070, Roku stick, Plex
genesplitter is offline
post #3 of 5 Old 07-18-2018, 11:24 PM
Spock1234's Avatar
Quoted: 24 Post(s)
Liked: 41
An excellent idea and a very nice build. Thanks for sharing.
Spock1234 is offline
post #4 of 5 Old 07-19-2018, 10:24 AM
EndersShadow's Avatar
Quoted: 1172 Post(s)
Liked: 1430
Cool! That looks awesome and fits perfect with the limited space you have!
For those with a few inches to spare, I’m running AC Infinity Aircom S8s. They are 1.5” thick and you can get one that spits the air out the back, or out the top.
They offer a variety of width sizes (13, 15, 17).
They also are programmable to ramp up automatically as the item gets hot, and slow down when cool.
Anyway just another option out there.
Pictures below of the S8
Sent from my iPhone using Tapatalk (so ignore any typos grammatical errors because my iPhone predictive text stinks)
My Setup | Custom MiniDSP Build | FS: If its For Sale, find it all (here)
Quote: There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is offline
post #5 of 5 Old 07-19-2018, 03:19 PM
Wayne A. Pflughaupt's Avatar
Quoted: 402 Post(s)
Liked: 324
Agreed, well done MrBobb
They also offer one that exhausts out the front.
Wayne A. Pflughaupt
Equipment List
"A nice mid-fi system," according to an audiophile acquaintance.
Reviews and Tech Articles
Wayne A. Pflughaupt is offline
Reply Tweaks and Do-It-Yourself
