Calling all engineers, water flow switch - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 01-12-2019, 06:42 PM - Thread Starter
Bigus's Avatar
Quoted: 672 Post(s)
Liked: 602
Not an area I have any experience with. I'm curious about sensing water flow for the purpose of sending an output signal to an automation controller. Nothing as fancy as a flow sensor to measure actual flow rate, though I guess that could be a fallback. More of a simple yes or no flow state output when a threshold is reached.
Specific application would be on a tub filler, so no need to detect tiny leakage flows. Something like 1L/min threshold perhaps.
From reading/Googling, it sounds like maybe I'm looking for a flow switch instead of a flow sensor. But there seem to be dozens of different variations. Any tips to narrow my search? Guessing output of 5v would be useful, could be as easy as a reed switch connecting external power supply.
Bigus is online now
post #2 of 15 Old 01-13-2019, 03:00 PM
smoothtlk's Avatar
Quoted: 302 Post(s)
Liked: 94
whats the "threshold" that is reached?
a container is filled and that's the threshold? Maybe you really are looking for a level switch and not flow? If level, RVs have sensor systems to determine level.
a boat bilge pump has a level switch.
a condensate A/C tank has a level switch.
Describe your use case to narrow in, not on the device you are looking to find.
EDIT...oh, you are trying to fill a tub...is the tub fiberglass or metal or ceramic / tile?
there are ultrasonic level sensors that would mount to the bottom of the tub that will tell you how much liquid height is above the sensor.
You would need a real control system to have the rule of has it hit your "threshold" or not and then to turn the water flow off.
Are you looking to regulate the temp as well? Or will you manually set the temp balance and put a single solenoid on the blended output (that is simple).
Less precise would be to put the fill valve on a timer and just keep it open long enough to get your tube approx. filled. BUT....if the system fails and there is no overflow protection...this could be a very expensive solution.
smoothtlk is offline
post #3 of 15 Old 01-13-2019, 04:10 PM - Thread Starter
Bigus's Avatar
Quoted: 672 Post(s)
Liked: 602
Not looking for level, just flow. Short version, determine whether water flow for tub filler faucet was on or off. Don't need to know the exact flowrate. Only need to worry about the 99% everyday scenario where there will be modest flow rate. Guessing a threshold of 1L/min would suffice, meaning whenn flow was at that rate or above output is positive or switch closed etc.
Specific use... send signal to automation controller to turn on lights over tub when water turned on. Keep them on until occupancy sensor says no more motion in bathroom.
Just a thought exercise at this point in thinking through ways I might want to leverage a lighting system and automation controller. Trying to figure out what is possible, impossible, or just impractical, and what planning needs to happen to make something work.
For example, in this case the tub filler hardware will mount on a wall that is shared with shower on the other side. Even if I were to find a suitable switch and getting suitable signal to a controller isnt difficult, the switch needs to be serviceable. Meaning not enclosed in the shared tiled wall. Would have to find some upstream access point that could allow for service from an adjacent closet, attic etc, and talk to the plumber about whether that was possible or even allowable by code.
Bigus is online now
post #4 of 15 Old 01-14-2019, 11:58 AM
smoothtlk's Avatar
Quoted: 302 Post(s)
Liked: 94
You can use a "Zigbee" or "Z-Wave" moisture sensor with the sensor probes in the water stream. Once water is flowing, there will be conduction between the probes. That will then signal your automation controller to do "stuff". Once the flow stops, no more conductivity and the automation controller can have a seperate defined event for that.
The sensors are battery and last about 3 years. So, easy installation. We can assist end to end if needed. Send me a message.
post #5 of 15 Old 01-14-2019, 01:27 PM - Thread Starter
Bigus's Avatar
Quoted: 672 Post(s)
Liked: 602
I would think the pressurized plumbing lines (pex I'm assuming in my case) would stay filled with water indefinitely, and thus keep sending a signal? Thinking I need to detect flow of water, not presence of water.
Bigus is online now
post #6 of 15 Old 01-14-2019, 01:30 PM - Thread Starter
Bigus's Avatar
Quoted: 672 Post(s)
Liked: 602
BTW, for clarification I'm talking about something involving the supply line, probably hot side since that will always be used first, some distance upstream from the actual faucet/filler hardware.
Bigus is online now
post #7 of 15 Old 01-14-2019, 10:42 PM
smoothtlk's Avatar
Quoted: 302 Post(s)
Liked: 94
I would put the sensor right on the faucet outflow. That has no water when the valve is shut off.
Certainly if you are going to be on the pressure side, then you will need a flow switch plumbed in. With a contact switch or an "impeller" that measures flow rate. Flow rate will typically be more difficult to integrate as you will likely have to have a custom software driver to understand the data the sensor outputs. And a rule in the controller that is set at "more than zero flow".
post #8 of 15 Old 01-15-2019, 08:29 AM - Thread Starter
Bigus's Avatar
Quoted: 672 Post(s)
Liked: 602
Yeah, I don't want anything visible if I do this. Would only consider upstream monitoring. Again, not an area I had any working experience with as an engineer, but there seem to be a class of flow switch devices that are binary on/off at preset minimum flow rate threshold and that seems much easier to deal with than pulses from a flow sensor. Just have to do more research I guess to see which specifically might be a suitable choice.
Bigus is online now
post #9 of 15 Old 01-19-2019, 10:09 PM
dyazdani's Avatar
They make a number of simple flow switches, maybe something like this?
dyazdani is offline
post #10 of 15 Old 01-20-2019, 08:07 AM - Thread Starter
Bigus's Avatar
Quoted: 672 Post(s)
Liked: 602
Yeah that looks just about right. I found a cheaper one but was British threads and higher flow rate threshold. Kept turning up stuff in searches that didn't seem as well suited as this one, thanks.
Looks to be a straightforward implementation. Just a matter of where I'd put it and access for maintanence. I'll have a discussion with plumber in a month or so, will update later if I decide to do this.
Bigus is online now
post #11 of 15 Old 01-20-2019, 12:57 PM
smoothtlk's Avatar
Quoted: 302 Post(s)
Liked: 94
Bigus,
are you going to use two valves? one for cold and one for hot? if only one, then it would have to be on the mixing valve output. Which might be difficult to plumb in a traditional bath / shower system.
post #12 of 15 Old 01-20-2019, 07:55 PM - Thread Starter
Bigus's Avatar
Quoted: 672 Post(s)
Liked: 602
Thought about that. I think a single switch on the hot side would be almost 100% sufficient. When actually using the tub for a bath, this will always be turned on either alone at first or maybe as a mix of hot and cold, but never only cold to start a bath..
There may be occasions when only cold is turned on for cleaning or whatever and its fine to have the light just stay off then.
Bigus is online now
post #13 of 15 Old 01-20-2019, 07:57 PM - Thread Starter
Bigus's Avatar
Quoted: 672 Post(s)
Liked: 602
And I think the actual hardware we picked out is separate valves that combine after the valves.
Bigus is online now
post #14 of 15 Old 01-21-2019, 08:46 AM
smoothtlk's Avatar
Quoted: 302 Post(s)
Liked: 94
I am thinking that if you put a water solenoid on the Hot and Cold lines, and preposition the existing manual handle for the right temp, that it would be more interesting to turn on both solenoids AND the light with a "Shower On" button push. This button could be a hardware or software based button. Then, when the shower is over, just turn the switch off which would turn both solenoids off and start a "15 second" timer to then turn off the light.
For a tub, the problem will be ensuring that it is not overfull. That can roughly be done with a timer. Better would be to turn off when a specific level is determined AND timed. Either way, I don't like the tub problem due to the possibility of flooding. A water moisture sensor should be incorporated as a worse case prevention.
This IS a lot of effort to turn a light on and off and the use case is not apparent. The shower example above has an additional function of pre-warming the shower water for you, which we have done for clients in the past.
post #15 of 15 Old 01-21-2019, 12:37 PM - Thread Starter
Bigus's Avatar
Quoted: 672 Post(s)
Liked: 602
Something to think about.
Not sure if my builder/plumber plans on using a manifold for hot/cold distribution. If so, that would be an obvious point of access and I could play with whatever combination of flow switches and solenoids I wanted.
Bigus is online now
Reply Tweaks and Do-It-Yourself
