HDMI source isolation(distribution) device? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-22-2019, 10:44 AM - Thread Starter
Liked: 0
Does anyone know of a black box that will isolate the HDMI source from all other outputs to monitors, etc.?
Using active splitters I have seems let/cause my HDMI source to change/corrupt based on different displays and devices.
Like maybe a multiple output device used in a retail store to demo displays.
Edward_ is offline
post #2 of 5 Old 01-22-2019, 02:26 PM
smoothtlk's Avatar
Quoted: 302 Post(s)
Liked: 94
Not quite sure what you are asking...but an AV Matrix switch is what retail stores demo with. Allows to choose which source goes to which output(s).
smoothtlk is offline
post #3 of 5 Old 01-22-2019, 05:26 PM - Thread Starter
Liked: 0
I'm asking about an isolation device because when I plug an HDMI recorder into one output of my HDMI splitter, my 40" display blinks off momentarily and returns on with a 5 inch wide vertical black bar at each end.
So I thought if I could isolate my HDMI devices it may solve this. Can't imagine how one device can affect another in this manner.
Edward_ is offline
post #4 of 5 Old 01-22-2019, 05:53 PM
FlyingDiver's Avatar
Quoted: 243 Post(s)
Liked: 71
The recorder is causing the source to downrez because it won't pass HDCP (the copy protection protocol). Working as expected.
This might do what you want: https://www.amazon.com/GEFEN-EXT-HD-.../dp/B00MN3KKK2
FlyingDiver is offline
post #5 of 5 Old 01-22-2019, 06:07 PM - Thread Starter
Liked: 0
Thanks FlyingDiver I was hoping that wasn't the problem.
Its kind of odd that everything works at the moment with a new 1x2 splitter I have.
Edward_ is offline
Reply Tweaks and Do-It-Yourself
hdmi
