DVI and 3.5mm audio to HDMI cable? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-25-2019, 03:17 PM - Thread Starter
ZQ8 Blazer's Avatar
Arrow DVI and 3.5mm audio to HDMI cable?
I'm currently using a led tv as my monitor with the use of a DVI to HDMI cable. This works great, but I want the computer audio to come through the tv speakers as well. There is no audio input anywhere on the TV and my PC as a 3.5mm audio out and a digital audio out. I was wondering if someone makes a cable that has DVI and 3.5mm (or digital audio) to HDMI cable so that I can have both audio and video from the computer coming through to the TV?
ZQ8 Blazer is offline
post #2 of 2 Old 02-25-2019, 03:31 PM
TheRatPatrol's Avatar
Quoted: 277 Post(s)
Liked: 234
You can try this, you'd have to get a 3.5mm to RCA audio cable.
adapter https://www.monoprice.com/product?p_id=8124
cable https://www.monoprice.com/product?p_id=665
TheRatPatrol is offline
Reply Tweaks and Do-It-Yourself
