12v power supplies - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-03-2019, 10:05 AM - Thread Starter
Quoted: 23 Post(s)
Liked: 3
12v power supplies
I'm looking for good quality 12v power supplies to use with a class D amp. I need a barrel type connector (5.5mm outer, 2.1mm inner). The power supply that came with the amp is mediocre, it works fine with bluetooth, but introduces some noise at higher volumes when using the analog input.
I know iFi makes a very good power supply and I'm going to get one of those for another application, but it's entirely too expensive to use with a low-power amp - I just need something that is "good", not crazy audiophile grade.
FireDragon76 is offline
post #2 of 4 Old 03-03-2019, 07:31 PM
MrBobb's Avatar
Quoted: 229 Post(s)
Liked: 107
Have an old PC PSU sitting around? can try that, is free.
MrBobb is offline
post #3 of 4 Old 05-13-2019, 09:34 PM
Liked: 2
Current requirements?
phtli is offline
post #4 of 4 Old 05-20-2019, 02:10 PM
holl_ands's Avatar
Quoted: 914 Post(s)
Liked: 489
Are you SURE that you need 12-VDC....most Class-D Mini-Amps are using 19-VDC....and some at 24-VDC Max Limit for the "chip" found inside:
https://www.amazon.com/Channel-Audio.../dp/B071XQGYRJ
You should tell us which Class-D Mini-Amp you want to use....if PS is not included with the order, Amazon listing should at least provide a PS recommendation....
holl_ands is online now
Reply Tweaks and Do-It-Yourself
