AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Tweaks and Do-It-Yourself (https://www.avsforum.com/forum/28-tweaks-do-yourself/)
-   -   IR Extender Issues (https://www.avsforum.com/forum/28-tweaks-do-yourself/3062386-ir-extender-issues.html)
mpintods 04-15-2019 12:43 PM
IR Extender Issues
4 Attachment(s)
Hi, I was hoping for some input into an issue I have with an IR extender. I have two screens that use Binary B-520-rx-330-ir and B-520-tx-330-ir receivers and transmitters to receive video, and one screen uses an IR extender to send signals back to the source (cable box), through the Binary system. I'm trying to get the second screen to also work with IR, but am having difficulty finding an extender that will work. I've tried using two other extenders, but they don't work. However, when I use the extender from the first screen, it works, so I'm sure the issue is finding an appropriate IR extender. I've attached images of the working extender.
Could anyone provide any insight into why this particular extender works, and how I could find another or similar extender? For the situation in question, I'm using a Cox cable remote URC-8820-CISCO with both televisions, if that helps to find an answer.
Thank you in advance for any replies.
-Mat
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
