Streamline TV by Signia - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-25-2019, 07:42 PM - Thread Starter
albert14's Avatar
Liked: 0
I am trying to connect the Streamline TV Bluetooth device between Streamline TV, STB, Pioneer VSX-1020 AV receiver, and Samsung One Connect Box. All have Toslink connections. I can get it working, but not through the different inputs are selected on the receivers. Streamline Tv is for streaming to hearing aids.
Thanks in advance.
Al
albert14 is offline
post #2 of 6 Old 08-02-2019, 01:25 PM
DanPackMan's Avatar
Quoted: 485 Post(s)
Liked: 1216
I would think you want to connect the Zone2 output on the AVR to the input on the Streamline. Then select zone 2 output when you want to listen through that device.
DanPackMan is offline
post #3 of 6 Old 08-06-2019, 03:30 PM - Thread Starter
albert14's Avatar
Liked: 0
Thank you. However there are only two toslink ports on AVR. One for tv and the other for Sat/DVR. What type of cables/connectors would be required?
albert14 is offline
post #4 of 6 Old 08-06-2019, 05:56 PM
DanPackMan's Avatar
Quoted: 485 Post(s)
Liked: 1216
The TOSLink ports are for inputs to the AVR from different devices. I believe you want output from the AVR to an input on your streamline TV. The only outputs on the AVR I can tell, beside the speaker outputs, are the Zone 2 audio outputs. Those are RCA connectors, and you'd connect that to RCA input on your Streamline TV.
I don't think your AVR has a TOSlink output.
post #5 of 6 Old 08-06-2019, 06:15 PM - Thread Starter
albert14's Avatar
Liked: 0
Makes sense. I will give it a try.
Thanks very much.
albert14 is offline
post #6 of 6 Old 10-14-2019, 08:30 AM
Liked: 0
Lightbulb Streamline TV by Signia
"I am trying to connect the Streamline TV Bluetooth device between Streamline TV, STB, Pioneer VSX-1020 AV receiver, and Samsung One Connect Box. All have Toslink connections. I can get it working, but not through the different inputs are selected on the receivers. Streamline Tv is for streaming to hearing aids."
Later versions of the Samsung One Connect Box have a Toslink digital optical output. Why don't you drive the Streamline TV from the output of the TV, rather than trying to drive it from the output of the AV receiver?
Ben Thurston is offline
Reply Tweaks and Do-It-Yourself
