DIY- Budget wire chase. - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By MRAYB
post #1 of 1 Old 10-10-2019, 05:28 AM - Thread Starter
MRAYB's Avatar
Quoted: 272 Post(s)
Liked: 585
Let me preface this post by saying I have been laid off two weeks now due to the GM/UAW strike. Staying busy, trying to do all the jobs at home that you never seem to get around to doing.
New carpet installed in the 32'x22' main room last week. The room is on a concrete slab. Attic and walls are not feasible. Took the opportunity to update/upgrade all of my wiring. I was able to run everything tucked under the baseboards before. Not now. Upped the speaker wire gauge, and added some Cat6 runs. No way it would fit under there now.
Previously have used the neoprene Velcro sleeves in the bedroom and office. I like it, easy to use for short, twisting runs. Doesn't look good when used for long, straight runs. I had some old 1/2 foam pipe insulation leftover in the garage. It is a perfect fit to tuck the wires inside and wrap the sleeve around. Looks much better with the sleeve "filled in" on a long run. 1 1/2" rubber clamps every 5 feet or so. Easily accessed if needed in the future.
https://www.amazon.com/dp/B07Q4MJJY5...ing=UTF8&psc=1
https://www.lowes.com/pd/Frost-King-...lation/1060001
https://www.amazon.com/Cable-Lokman-...WA42NK3ZTETA7T
ID:	2626130   Click image for larger version
ID:	2626132   Click image for larger version
ID:	2626134   Click image for larger version
ID:	2626136   Click image for larger version
ID:	2626140   Click image for larger version
ID:	2626142   Click image for larger version
ID:	2626144   Click image for larger version
ID:	2626146   Click image for larger version
humbland likes this.
MRAYB is online now
Reply Tweaks and Do-It-Yourself
