Which Cables I can group, but minimize potential noise impact to audio. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-14-2020, 11:09 AM - Thread Starter
chinmokutak's Avatar
Quoted: 93 Post(s)
I want to group types of cables together for my rack and wondering what I can into one batch so that it's cleaner. Ideally I group them up and put it on the left or right. but I certainly do not want them to interfere with my audio cables.
I have the following cables:
1. Power
2. Ethernet
3. Speaker Audio Cables
4. RCA Audio cables
5. Amp DC trigger cable
6. HDMI
Is power the only cable I should not group with audio? If I have power on one side of the rack, could I assume that all the other cables should go to the other side?
chinmokutak is offline
post #2 of 3 Old 01-15-2020, 06:31 AM
Wayne A. Pflughaupt's Avatar
Quoted: 468 Post(s)
Liked: 392
When I was installing pro audio system many years ago, our system designers typically wanted us to run power on one side, signal on the other, and speaker-level down the center.
That said, there won’t be an issue running speaker-level with signal as long as your signal cabling has a good shield (that’s what it’s for). Thus, you should be fine as long as you’re using decent–quality cables.
Wayne A. Pflughaupt
Equipment List
"A nice mid-fi system," according to an audiophile acquaintance.
Reviews and Tech Articles
Wayne A. Pflughaupt is offline
post #3 of 3 Old 01-19-2020, 12:13 PM
Michael Sargent's Avatar
Quoted: 238 Post(s)
Liked: 223
I group power in with speaker and network cables and have never heard any interference (in over 20 years).
Try it. If you don't have a problem stick with it.
Mike
Michael Sargent is online now
Reply Tweaks and Do-It-Yourself
