DIY Atmos , Auro 3d A&B Speaker Switch Inquiry - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-11-2020, 08:03 PM - Thread Starter
Soze887's Avatar
Liked: 5
Question DIY Atmos , Auro 3d A&B Speaker Switch Inquiry
Hello everyone,
I've got a Denon X4500H I've set up for Auro 3d >>10.1 utilizing Front and Rear height speakers and a VOG Top speaker.
With that said I'd like to also install four more speakers to use for Dolby Atmos Top Front and Top Rear .
Obviously this is not doable because of my current speaker configuration but it seems to me the speaker connections on the Denon are the same but it would require Loading a new speaker profile when wanting to swap Sound Format. Eazy enough with a USB stick.
Here is my question..
Can I use a 4 Speaker dual input A/B Switch to allow for this?
I found this on Amazon << 4 Channel Speaker Selector Switch - Multi Zone A B Speaker Distribution Controller Box w/ Independent Audio Source Volume Control, Supports Home Theater Stereo Amplifier Receiver System - Pyle PSLSW4 >>
https://www.amazon.com/Channel-Speak...ct_top?ie=UTF8
Seems to me this is a viable option to solve my issue..
Please let me know what you think or suggestions .
ID:	2708926   Click image for larger version
Soze887 is online now
post #2 of 2 Old 04-27-2020, 03:26 PM - Thread Starter
Soze887's Avatar
Liked: 5
Manual DIY Speaker Switch to Have ATMOS and AURO 3d Setup
Well if anyone is interested I solved my issue.
Denon X4500
You will need the $20 Denon Multi EQ App
Allows you to create profiles ie Atmos and AURO 3d profiles you can load and send to the AVR
Last part was to install two of these https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I wired up the 8 speakers so now when I want to swap depending on what Im watching total time is about 2 min.
Flip the A/B switch and upload the proper config from my phone using the app
100% Happy.
Reply Tweaks and Do-It-Yourself
