Multiple RGB lighting IR control Combining - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 06-09-2020, 11:41 AM - Thread Starter
realred2's Avatar
Lightbulb Multiple RGB lighting IR control Combining
I'm looking for some assistance in combining IR receivers on 5 RGB LED recessed lights in my kids bedroom.
Lights are at this link: https://www.amazon.com/Pocketman-Ult.../dp/B07BM1Y9TF
I am running a Xantech mrc88 whole home system, and have a standard mrc88kp keypad in the room. It has a ir reciever and output contacts, can I link up the 5 IR recievers from the slim cans by extending the wiring to my keypad. I'd like to not put a extra tiny hole next to each light for the remote. (And then I can setup a keypad button for lighting. )
Thanks for any help. All the lights use the same remote control.
This was in the Remote section, but it's probably better for here. (If a mod can delete the other one, I would appreciate it.)
My Route 66 Basement Theater Build Thread
realred2 is offline
Reply Tweaks and Do-It-Yourself
