A second run - 3D - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-25-2011, 12:19 PM - Thread Starter
ramick's Avatar
For reference on my previous system (to support HiDef), see:
http://archive.avsforum.com/avs-vb/s...postid=1812354
After a long hiatus while enjoying HiDef, I now see that 3D is starting to take off.
So, time to rebuild/retrofit the HT for 3D
Put 3D on hold to update other sections as I think they need more work and I'm not so sure 3D is ready.
Sources:
HTPC - updated 29JUN2013 (All from Newegg.com):
  CASE ROSEWILL | REDBONE U3
  MB ASROCK|Z77 Extreme4-M Z77 1155
  PSU SEASONIC|SS-750AM 750W RT
  CPU INTEL|CORE I5 3570K 3.4G 6M
  MEM 2X4G|CRUCAL BLT2K4G3D1608ET3LX0
  VGA EVGA|03G-P4-2667-KR GTX660 3G
  SSD 240G|MUSHKIN MKNSSDCR240GB-DX
  CPU COOLER CM| RR-212E-20PK-R2
  MS WIN 7 HOME SP1 64BIT 1PK - OEM
nVidia
3D Vision? emitter + shutter glasses [$149 retail] (Pro uses Quadro cards)
http://www.nvidia.com/object/3d-vision-home-users.html
http://www.nvidia.com/object/3d-vision-content.html
3D Vision Discover? Red-Blue/Cyan glasses (anaglyph)
- http://www.nvidia.com/object/3d-visi...over-main.html
- GTX 460 not on nVidia's rec hardware anymore??!! - http://www.nvidia.com/object/3d_visi...uirements.html
nvidia hack - enable 3DTV Play on any HDMI 1.4 Device for Free:
http://www.mtbs3d.com/phpBB/viewtopic.php?f=105&t=13176
3DTV Play? - no checkerboard?
Stereoscopic [BD] player - http://3dtv.at/Index_en.aspx
free (max 5min), 39Euro full - DLP TV viewing format for checkerboard
http://haali.su/mkv/MatroskaSplitter.exe
http://ffdshow-tryout.sourceforge.net/download.php
Windows Media Player version 11.0.6002.18311
HDMI1.4 checkerboard for all! 3D Vision software fix here:
http://forums.nvidia.com/index.php?showtopic=191819
For gaming, get iZ3D and then Tridef (neither are renewable and the trials only last 3 weeks)
how much $ are these
- looks like Tridef is better for games than nVidia - also looks like Tridef has checkerboard?
For BR3D, either TMT5 or Spectroscopic player
Sony PS3 - firmware 3.60
Comcast DCX 3400 DVR
Can't get Auto 3D to work, yet (setup Native through menu after poweroff), however, I can manually set up the following:
897 XF3D SbS 1080i
898 ESN3D TnB 720p
G4 on Demand
Displays:
Mits HC3000 projector - bedroom
Panasonic PT-AE 3000U projector - living room
3D projector?
Samsung LNT4661FX/XAA LCD 46"
Samsung Plasma 58C8000
allows checkerboard mode for 3D (thanks Frank) - windowed 3D and 60Hz sequential gaming
- current shipped firmware 2011/01/31_001035
firmware: http://www.samsung.com/us/support/do...PN58C8000YFXZA
- crosstalk test at https://www.avsforum.com/avs-vb/showthread.php?t=1291751
In order to enable all 7 3D format options (including checkerboard) on Samsung [58]C[8000], rename HDMI/DVI 1 as "DVI PC"
This will not work for Comcast ESN3D (my 898) TnB 720p
- have to use a different input?
Audio:
Denon AVR-2801 (much older receiver - need to replace)
Infinity Kappa 7 (1987) fronts http://follgott.tripod.com/
JBL NCenter center,
Linaeum rears,
Sony SA-WM40 10" 90W Sub
2x Aura Bass Shakers from 2 Interactor vests
Screen:
Da-Lite CSR 48"Hx112.8"W (2.35:1 AR - 122.6" diag) image field plus 2" black masking all around
Video Spectra 1.5 surface - constant height with commando cloth for sides - pull down in front of Plasma
IR control with x10 Pro Powermids
Lighting control with Heath/Zenith
My Home Theater System
See my weather site at: Seattle
See my webcam at: Wunderground
ramick is offline
post #2 of 4 Old 05-25-2011, 07:48 PM
drewTT's Avatar
Quoted: 2264 Post(s)
Liked: 2441
Sounds interesting. Do you have any pictures to share?
LG OLED65E8 | Plinius Hiato | Dynaudio Contour 20 | Dynaudio Stand 6 | REL S/510 | PS Audio DirectStream | Furman IT-Reference 15i | roon
Panasonic DP-UB9000 | Synology DS916+ | Apple TV 4K | BDI Mirage | NEEO | Focal Shape 40 | iFi Pro iDSD | iFi Pro iRack | iFi AC iPurifier
drewTT is offline
post #3 of 4 Old 05-29-2011, 08:52 PM - Thread Starter
ramick's Avatar
I'll try to get pics up soon - anything in particular you'd like to see?
ramick is offline
post #4 of 4 Old 05-29-2011, 10:41 PM
amarshonarbangla's Avatar
Quoted: 39 Post(s)
Liked: 44
How about everything?
amarshonarbangla is offline
