Carp's Basement - Page 52 - AVS Forum | Home Theater Discussions And Reviews
 430Likes
post #1531 of 1596 Old 01-28-2018, 04:30 PM - Thread Starter
carp's Avatar
Quoted: 3513 Post(s)
Liked: 3195
Like I was saying before, I raised my back row riser a few inches so it's now 15 inches tall so I needed 2 steps, one on each side of the riser. I thought about buying something but figured I'd better do it right and DIY something. That sentence sounds so wrong coming from me.
I had my carpet installer put pad and matching carpet over them.
ID:	2352898   Click image for larger version
ID:	2352900   Click image for larger version
carp is offline
post #1532 of 1596 Old 01-28-2018, 06:44 PM
stitch1's Avatar
Quoted: 368 Post(s)
Liked: 304
Wow Carp! It looks like you moved... You room looks so different with the new carpet and paint! Very nice upgrade for it.
carp likes this.
stitch1 is offline
post #1533 of 1596 Old 01-28-2018, 07:14 PM - Thread Starter
carp's Avatar
Liked: 3195
Thanks Tim! I put off painting for a long time, glad it's finally done.
carp is offline
post #1534 of 1596 Old 01-28-2018, 08:37 PM
d_c
d_c's Avatar
Quoted: 1130 Post(s)
Liked: 1542
Man it looks great - it’s like a whole facelift. I was going to build these complicated boxes to aim my Atmos speakers at the MLP but decided to mount them flush with the ceiling to get them up higher - at least to see if it would work. You have given me hope seeing yours now. I was really not looking forward to figuring out how to build them
d_c is online now
post #1535 of 1596 Old 01-29-2018, 03:54 AM
COACH2369's Avatar
Quoted: 1168 Post(s)
Liked: 986
Originally Posted by carp View Post
Thanks Coach!
Yes, I highly recommend going from the scs8's to the RSL's for the ceiling both for looks but more importantly to get the sound source higher up. The benefits far outweigh any issues with non matching speakers because I can't tell they don't match anyway.
I appreciate the information. I just sent you a PM instead of bogging down your thread with questions about the speakers.
COACH2369 is offline
post #1536 of 1596 Old 01-29-2018, 05:57 AM - Thread Starter
carp's Avatar
Liked: 3195
Thanks man, I used to feel like trying to my room look like a HT was like polishing a turd but it's starting to look better. I need to hire Grant to re-do some of my velvet, his looks perfect.
With the RSL's you can aim the tweeter how you want, and the drivers are angled as well. However I'm not sure how necessary this is as long as the dispersion of the speaker is pretty wide, which yours are.
carp is offline
post #1537 of 1596 Old 01-29-2018, 06:38 AM - Thread Starter
carp's Avatar
Liked: 3195
got it
carp is offline
post #1538 of 1596 Old 01-29-2018, 07:14 AM
JDontee's Avatar
Quoted: 319 Post(s)
Liked: 212
Are you no longer using the JBL's for Atmos? If not, why did you make the change? BTW, the room is looking great.
JDontee is offline
post #1539 of 1596 Old 01-29-2018, 07:38 AM - Thread Starter
carp's Avatar
Liked: 3195
Thanks JD, I changed for a couple reasons. For one thing I wanted them higher up and also the front pair distracted the eyes a bit with the reflection since there is velvet everywhere in front of me. I definitely get better sound from over head because not only are they higher but I moved them a bit closer to the first row (keeping them the same width apart).
carp is offline
post #1540 of 1596 Old 01-29-2018, 07:55 AM - Thread Starter
carp's Avatar
Liked: 3195
Still using the scs8's for side and rear.
carp is offline
post #1541 of 1596 Old 01-29-2018, 02:15 PM
SBuger's Avatar
Quoted: 1160 Post(s)
Liked: 3595
I just took a look at your before and after pics, wow that's a nice change. Its even easier on your eyes in the pics, so probably better for video as well! I'm well aware of what velvet can do now since putting some up, so nice there as well on your curtain up front!
I've admired your basement and setup for a long time, but wow, it's really nice now! I like your Metallica stuff and metal poster on the wall too, bad ass. An awesome room to spend time in I'm sure.
Kudos man!!
carp likes this.
My "Blacked Out" Home Theater Room
1400cuft sealed room, suspended floor | SY Triple Black Velvet for Blackout | Denon AVR-X6300H - 7.6.4 Atmos | KEF Q Series Speakers | GIK Treatments | Oppo 203 | Epson 5040 4K | Eyes 7' to 120" AT Seymour Screen | 6x 18" Sealed DIY Subs (4x SI DS4-18s & 2x UM22-18s) | 6x Crowson MAs | 4x BK LFEs | BOSS 'Sub Riser' 6x JBL12s | MiniDSP 10x10HD
SBuger is offline
post #1542 of 1596 Old 01-29-2018, 03:10 PM
beastaudio's Avatar
Quoted: 5503 Post(s)
Liked: 5317
Killer Carp!!!! I have two questions tho on application
Did you sand then paint the ceiling? I've heard that is a HUGE task to get popcorn/sponge off the sheetrock. My whole house it littered with that junk and I've contemplated many times doing as such but hear nothing but nightmare stories about getting it to look nice and uniform. Mouse ears flat I guess helps a lot with that.
What was your process for raising the riser? I've also thought about this as mine is only 10" and needs to be much higher to get full clearance of screen viewing for the rear seats. 15" would do the trick but aside from installing 4x4 stilts and re-doing the wood sides I have now, it too would be a pretty sizable task. I might as well just build another riser from my design thinking....
carp likes this.
beastaudio is online now
post #1543 of 1596 Old 01-29-2018, 04:57 PM
lukeamdman's Avatar
Quoted: 1385 Post(s)
Liked: 2000
Looks great!
When are you guys having another GTG or crawl? I need to make it down there.
carp and Archaea like this.
lukeamdman is offline
post #1544 of 1596 Old 01-30-2018, 11:47 AM - Thread Starter
carp's Avatar
Liked: 3195
Kudos man!!
Thanks! Yeah, those Metallica records have been the one constant in the room since long before I had a projector. After painting I had a fleeting thought of growing up a bit and not putting them back up. I quickly decided that I'm not fully ready to embrace this whole grown up thing.
My basement ceiling is the only room in the house with a knockdown ceiling, so I didn't have to scrape popcorn. Funny you mention that though because I plan on scraping some of the other rooms in the house this summer. Yeah, I hear it's not much fun.
With the riser I flipped it and screwed 3 layers of 2x4's round the perimeter and wrapped them in velvet. I used more 2x4's in the center area so it won't dip in the middle.
Originally Posted by lukeamdman View Post
Looks great!
Agreed ^
There is talk of doing one next spring - Doug will have his room done and even without that his house was already the place to be.
SBuger likes this.
carp is offline
post #1545 of 1596 Old 02-03-2018, 02:41 PM
ambesolman's Avatar
Quoted: 1156 Post(s)
Liked: 969
Room looks great As far as the popcorn ceiling, I've seen YouTube vids where a guy used a pump sprayer to lightly wet the ceiling and it scraped right off with minimal mess, just wipe off the scraper and keep going.
Sent using Tapatalk cuz the mobile version is still
carp likes this.
"Rockbiter" DO SI18 sub build - https://www.avsforum.com/forum/155-d...o-si-18-a.html
Ambesolman's Cleverly Titled Theater build - https://www.avsforum.com/forum/19-de...ter-build.html
ambesolman is offline
post #1546 of 1596 Old 02-03-2018, 03:15 PM
d_c
d_c's Avatar
Liked: 1542
Carp's Basement
I brought the garden hose in and used the fan nozzle on the sprayer when I scraped ceilings. Spray a 4x4 section and wait 5 minutes, then scrape lightly with a 12” Drywall blade while catching it with a big dustpan under it. The messy part is sanding it smooth. I also did a skim coat of thin drywall mud over the whole ceiling to make it extra smooth. You can do it Carp!
We should do at least a Lite version of a ht crawl next spring. I’ll be ready for a movie night at my place this March.
carp likes this.
d_c is online now
post #1547 of 1596 Old 02-03-2018, 05:14 PM
7channelfreak's Avatar
Quoted: 309 Post(s)
Liked: 203
Does “Lite” include folks from Houston ?
carp likes this.
7channelfreak is offline
post #1548 of 1596 Old 02-03-2018, 06:37 PM
d_c
d_c's Avatar
Liked: 1542
Especially folks from Houston. If folks from Houston don’t come (again), then we are canceling it.
d_c is online now
post #1549 of 1596 Old 02-05-2018, 12:12 PM - Thread Starter
carp's Avatar
Liked: 3195
How smooth does it need to be, I'm having someone apply a knockdown surface after I get rid of the popcorn. So I'm wondering if I can get by without sanding?
Next month? Can't wait!
Always welcome Randy!
carp is offline
post #1550 of 1596 Old 02-05-2018, 03:49 PM
d_c
d_c's Avatar
Liked: 1542
d_c is online now
post #1551 of 1596 Old 04-04-2018, 03:47 PM
Archaea's Avatar
Quoted: 3769 Post(s)
Liked: 3552
Looks great!
I had a dream we had another big crawl, and Jeff brought down four 4000ULF units and wanted to demo them in my room. I was conflicted because I really wanted to hear them, but I didn't want my house's drywall destroyed, and to that Jeff promised he wouldn't destroy my room ----- and yet --- somehow I didn't believe him.
carp and Ladeback like this.
Archaea's 9.8.4 Home Theater Room
(13) JBL CBT 70j-1 | Denon x7200wa | Sherbourn PA 7-350 amplifier | (8) Ultimax 18" sealed subwoofers | (4) iNuke DSP 6000 amplifiers | (4) MB Quart 12" subwoofers mounted direct mounted to Berkline theater chairs BOSS style | Epson 5040UB Projector | Jamestown 144" acoustic transparent 2.35:1 screen w/ Seymour XD fabric
Archaea is offline
post #1552 of 1596 Old 04-04-2018, 04:18 PM
dlbeck's Avatar
Quoted: 661 Post(s)
Liked: 773
All kinds of goodness in that dream
carp likes this.
dlbeck is offline
post #1553 of 1596 Old 04-04-2018, 07:20 PM - Thread Starter
carp's Avatar
Liked: 3195
I lived that dream... well 25% of it anyway.
carp is offline
post #1554 of 1596 Old 04-05-2018, 07:22 AM
beastaudio's Avatar
Liked: 5317
Yes let's play it extremely hot and all go stand in the same room directly above it to feel the floor flexing like crazy. That's a good idea....so when the house collapses we ALL go down with it.
carp, Archaea and Ladeback like this.
post #1555 of 1596 Old 04-05-2018, 09:10 AM
Ladeback's Avatar
Quoted: 1319 Post(s)
Liked: 469
Send a message via MSN to Ladeback
But, we all lived to tell about it and watch Doug screw screws back into his drywall.
Klipsch KPS-400’s FR/FL with built in 15” 300 watt side firing subs, RC-7 Center, RS-3 Surrounds.
Integra DHC-60.5, 5- Marantz MA700 Mono Blocks, Pioneer DV-F727 301 Disk DVD CD Changer, Pioneer DVL-909 Laserdisc/DVD/CD Player, Sony PS3.
https://www.avsforum.com/forum/19-ded...ck-cinema.html
Ladeback is online now
post #1556 of 1596 Old 04-06-2018, 01:08 PM
d_c
d_c's Avatar
Liked: 1542
That’s a great dream. I have some weird ones too. The 4000 is an amazing sub - it’s amount of awesomeness is directly proportionally opposite to carrying it.
Archaea likes this.
d_c is online now
post #1557 of 1596 Old 04-06-2018, 04:51 PM
desertdome's Avatar
Quoted: 1527 Post(s)
Liked: 1856
I've carried it either in or out of 6 different houses and loaded in my van 4 times including picking it up at Fedex! Grant volunteered to go up the stairs first when we extracted it from his basement. Carrying seven 215RT's into AXPONA isn't much fun either.
Ponderosa Theater
High Impact AV
- ISF Level III Video Calibrator, THX-HAA HT3 Audio Designer/Calibrator
desertdome is offline
post #1558 of 1596 Old 04-28-2019, 05:32 AM
Archaea's Avatar
Liked: 3552
Put up some pics and commentary on your BOSS setup!
Archaea is offline
post #1559 of 1596 Old 04-29-2019, 06:30 PM - Thread Starter
carp's Avatar
Liked: 3195
Finally got it all finished yesterday. Front row has a total of 6 drivers and the back riser has 4 in the riser and another 2 drivers under the couch. It's a blast, I'll post some more details when I get more time. I think I'll put up the NF sub and Crowsons for sale first.
carp is offline
post #1560 of 1596 Old 05-24-2019, 06:37 AM
Ladeback's Avatar
Liked: 469
I tired sending you a PM yesterday, but it said you box was full and couldn't except any more till you got rid of some. I didn't know there was a limit till I tired sending you one about doing a demo on your theater.
Cerwin Vega Cv 5000 High Performance Power Amplifier , Jtr Noesis 212ht 212ht Lp , Pioneer Elite Vsx 53 Av Network Receiver 7 1 Channel 3d , Panasonic Dmp Bd80k Blu Ray Player , Epson Powerlite Home Cinema 8350
