My 13.4.12 "Franken-SWAtmos" living room.
EDIT april -23.
Denon finally came out with a AVR capable of Atmos 9.4.6 all with inboard amp channels, so i ditched the Franken Atmos and went legit😂😂 Read on from post 1303 👍
I get a lot of questions about my setup, so i tought i could make a thread explaining it a little more. And maybe some pics too.
Short version: i use more than one Atmos AVR's to expand beyond the 7.1.4/9.1.2 hardware limit on todays affordable gear.
Updated may 2019: ventured into the BOSS world of shakers, post 562..
Updated Mars 2019: stacked Crowson motion actuators and Buttkickers, post 498.
Updated may 2018: new nearfield solution with 12x12" JBL’s behind the couch. Starts at post 281.
UPDATED MARCH 2018
Ok, here we go again. Since reading about the new Denon flagship receiver capable of 13.1 and all amps built in, i had to make changes. So i sold the 5200 and 6200 and have now gotten the brand new AVC-X8500H. So no i can either do 9.1.4 or 7.1.6 with JUST the 8500, or as i have it configured for now 7.1.6 from the 8500 and 9.1.2 from the 7200 for a total of 9.1.6. And this is as correct 9.1.6 as you can get in this price range. And i can also do a (nearly) correct DTS:X 9.1.6. Auro is coming in a May update and will be 13.1. So i should be covered either way.
And if i want(and will test later on) i can still do the 13.1.8 setup i had earlier, but now i just need these two AVR’s. The 8500 for 9.1.4 (FH+RH), and the 7200 setup with 5.1.4+W for special wides and special surround + TF+TR.
So gear now is:
Gear.
Oppo BDP-203 UHD player(regionfree)
XBOX ONE X
Canal Digital HD PVR satellite-box
Apple TV3
(Darbee Darblet and MARSEILLE MCABLE for 1080P content)
Denon AVC-X8500H
Denon AVR-X7200WA
Yamaha RX-V3067
3 X Inuke NU6000DSP
JVC DLA RS600
Dreamscreen V2 dynagrey 120" screen
Samsung UE65JU7005 UHDTV
Harmony Ultimate.
Front=Klipsch RF-82 mk1
Center=Klipsch RC-64 mk2
Wide= Dynavoice Challenger M65 V3
Surr= Klipsch RS52
WideSur1/Sur2=Klipsch RS42
Surrback= KEF3005SE
Height speakers= 10x KEF3005SE
Nearfield mid-bass= Behringer B1200D
LFE= 2 X Sonosubs with 2 X SI18HT v2 in Dual Opposed config.
4x Crowson Shadow8 motion actuators
MiniDSP 2X4 balanced
Read more in post 259
OLDER SETUP:
Did a quick and dirty diagram of the setup.
Blue speakers powered by the 7200.
Red speakers powered by the 6200.
Yellow speakers powered by the 5200.
I will try to have the first post as updated about the setup as possible, and then take the details as we go.
Edit: updated Feb -17:
My HT is in the right half of my living room, and the room dimensions are:
5.1x4.1x2.4 meter
16.5Wx13.5Dx7.8H feet
EDIT sep17:
Or about 1800 cubic feet (+ the other half).
Gear.
Panasonic DMP-UB900 UHD player
HD FURY Integral
Oppo BDP-103 BD player
Darbee Darblet
Apple TV3
PS3 (fat)
XBOX360
Denon AVR-X7200WA
Denon AVR-X6200W
Denon AVR-X5200W
Yamaha RX-V3067
Inuke NU6000DSP
JVC DLA X500R
Surr= Klipsch RS52
Surrback= KEF3005SE
LFE= SVS PB12-Plus/2
ULF= PSA S3000i +4x Crowson Shadow8 motion actuators
All controlled by a Logitech Harmony Ultimate with the hub+4 extenders.
So my earlier setup was a Denon 7200/5200 combo, to get 7.1.4 + Wides + 8 channels of height speakers, for a 9.1.8 setup, explained further down on page(behing the spoiler), but i recently got a 6200 to gain HDMI 2.0 and DTS:X on the second AVR. Then i discovered "Special Wides" descrided in post 67 in this thread. Since i now had 3 Atmos AVR's, this gave me the opportunity to gain both 2 set of wides, AND keep my 8 channels of heights, for a grand total of 13.1.8 in native Atmos and 9.1.8 on DTS:X.
In daily TV use, i have just the 7200 playing DSU in a 7.1.4 setup, but it has all 14 speakers connected, for a 7.1.4 Atmos/DTS:X or 10.1 Auro 3D setup.
So in native Atmos, setup is as follows:
7200 switched to 9.1.2 for fronts @ 25 degrees, "Pure Wides" @ 50 degrees, "Pure Surrounds @ 85 degrees and Surround backs @150 degrees. Playing only 9.1.0(note 1)(note5).
6200 setup as 5.1.4+Wides(note2) for Wides/Sur1 @ 70 degrees, Sur2/Rears @110 degrees and Top Front+ Top Rear. Playing Wides, Sur2, and Tops(note4).
5200 setup as 5.1.4 for Front Height and Rear Height. Playing 0.0.4
(note 1)(note 2)(note3).
So basically the 7200 plays 9.1.0, while the 5200 plays 0.0.4(heights).
And 6200 plays 5.0.4(Wide/Sur1+Sur2/Rear+Tops).
As you can see in the little channel indicators in front display, the 7200(to the left) plays SB and WIDES, the 6200(bottom right) plays wides but no SB's and the 5200 (top right) plays no wides and no SB's.
As before, they are linked together via HDMI ZONE2 daisy-chained to the next AVR.
I only need on/off and main volume changes on the 6200/5200, so one original remote(and Harmony ultimate) handles that very well.
Note 1: both the 7200 and 5200 front and rear heights pre-out goes to the main and zone2 outputs of the Yama, so i just use the remote to switch the heights currently beeing used between the 7200 and 5200. So when the 7200 is in 9.1.2 mode, i let the 5200 power the heights.
Note 2: both the 6200 and 5200 wides pre-out goes to zone3 on the Yama, so i can choose wich one powers the Wide/sur1 speakers. This way i can use Neo:X wides from the 5200 in DSU(wich do not use wides).
Note 3: in Auro 3D, the 7200 powers the full 10.1 possible. But i can copy the 5200 surrounds(in Auro mode) to the surround back speakers(silent in Auro 10.1) for Auro "12.1" This way i get more "rear fill" than with just the 7200 surrounds @85 degrees. This is done with a dual source speaker switch. I can also power the Surround Heights with the 5200 if i change amp assign to FH+SH, for Auro "14.1".
Note 4: i have a "Center Height" speaker above the screen. This is connected to the center output of the 6200, and works as a "dialog lift", and also helps pannings between the front heights.
Note 5: the 7200 powers a VOG(sub2 pre-out) used in Auro 3D. In other formats, i can matrix a VOG using PL2 in the Yama extracted from the rear heights.
After all this was connected, all 3 AVR's got a full Pro calibration. This took a while...
I got a third !?! Kef3005SE 5.1 speaker kit for this upgrade. I switched out the surround backs from Klipsch to Kef, and the rear heights from white to black Kef's.
And got rid of the bookshelfs used as Surround Heights for white Kef's.
See the Kef sub on top of the Bluray rack? I now have bass-managment on the rear heights
Older setup behind spoiler, no longer used. Too complicated
I have a lot of flexibility with this setup, but it is not advisable to leave the remote with grandma
Some pics of the recently redone living room.
EDIT april -23.
UPDATED MARCH 2018
So gear now is:
Gear.
XBOX ONE X
Apple TV3
Denon AVC-X8500H
Denon AVR-X7200WA
Yamaha RX-V3067
3 X Inuke NU6000DSP
JVC DLA RS600
Harmony Ultimate.
Surr= Klipsch RS52
Surrback= KEF3005SE
OLDER SETUP:
5.1x4.1x2.4 meter
EDIT sep17:
Gear.
HD FURY Integral
Darbee Darblet
Apple TV3
PS3 (fat)
XBOX360
Denon AVR-X7200WA
Denon AVR-X6200W
Denon AVR-X5200W
Yamaha RX-V3067
Inuke NU6000DSP
JVC DLA X500R
Surr= Klipsch RS52
Surrback= KEF3005SE
7200 Audyssed with 7.1.4 FH+RH+wides+VOG. 14 speakers.
5200 Audyssed with 7.1.4 TF+TR+wides. 13 speakers.
In native Atmos, my 7200 is playing 7.1.4, no SB+FW.
My 5200 is playing TF+TR.
However: since the 7200 has deactivated SB's in this case, and they then are downmixed into the surrounds, I switch the surrounds and surround-backs over to the 5200, via my old AVR(Yama 3067 set up as a multisource(all three zones) active speaker switch).
So the 5200 also plays surrounds and SB's.
="TRUE" 9.1.8
When playing native DTS:X (wich is limited to 7.1.4 anyway) from the 7200, i can play wides from the 5200 in Neo:X mode(matrixed from fronts and surrounds in both cases anyway).
And then when playing native Auro 3D, the 7200 plays 10.1, and if the track is 13.1, the 5200 can fill in with surround backs.
Setup. Ok, so a little more in detail how it all is connected.
The two AVR's are simply connected with a HDMI cable from the 7200 zone2 HDMI OUT, to AV1 input on the 5200. This output is a copy of the input, untouched, unprocessed, full sound and picture.
From the 7200 the speakers are:
Front LR= 7200.
Center=7200.
Surrounds= goes trough a dual source-dual output speaker switch.
Input A is from the 7200 surround speakers
Input B is from the 5200 surround speakers
Output 1 goes to surround speakers 1 at 85 degrees
Output 2 goes to surround speakers 2 at 110 degrees
So i can choose wich surround should play, even both sets from on AVR. Or one from each. Like when i deactivate the 7200 SB's to gain the wides, i can let the 5200 play surround1 and SB's, and then let the 7200 play the surround2.
Surround back= Both 7200 and 5200 surround back pre-outs goes to Yama AVR zone2 input audio1 and audio2. So i can choose wich plays the SB's. I also have a input from 5200 surrounds here, so i can copy the surrounds to surround back, eg in Auro.
Front wides= goes trough a second dual source-dual output speaker switch.
Input A is from the 7200 front wide speakers.
Input B is from the 5200 front wide speakers.
So either the 7200 or the 5200 can power the wides.
Front height= 7200.
Rear height= 7200 pre-out goes to Yama AVR main zone input AV1
I can choose stereo(2speakers) or PL2 matrixing to the center channel, VOG(3speakers).
Rear height is also connected via a Y-connector to the Yama multi ch front input.
Top surround(Auro 3D)= 7200 sub2 pre-out goes to Yama multi ch input, center channel.
So by switching the Yama from AV1 input(Atmos/DTS:X) to multi ch input (Auro 3D) i get correct signal to rear height and top surround).
From the 5200 the speakers are:
Front LR= connected to 7200 multi ch inputs, fronts. When calibrating or playing from 5200, the 7200 is switched to multi ch.
Center= 5200 to a center height.
Surrounds= see above dual source speaker switch.
Surround back= see above Yama zone2.
Front wides= see above second dual source speaker switch.
Top fronts= 5200.
Top rears= 5200 pre-out goes to Yama AVR Zone 3.
Surround height(Auro 3D)= 5200 pre-out is also connected via a Y-connector to Yama AVR main zone multi ch input, surround channels.
So on the Yama, if i turn of zone3(top rear) and switch to multi ch, the 5200 height2 signal is directed to the surround heights(Auro 3D).
="TRUE" 9.1.8
Front LR= 7200.
Center=7200.
Front height= 7200.
Top fronts= 5200.
