My 11.4.12 "Franken-Atmos" living room. - Page 27 - AVS Forum | Home Theater Discussions And Reviews
 890Likes
post #781 of 837 Old 06-12-2019, 06:20 PM - Thread Starter
Nalleh's Avatar
Quoted: 2403 Post(s)
Liked: 3132
Managed to watch a couple of movies over the weekend and discovered some popping noises from one of the LFE components during loud ULF transients.
One example is at 10:10 in Captein America Civil War, where black widow is fighting some bad guys, there is a couple of ~15hz bursts that is very loud(look at the BEQ spectrum in Bass EQ thread).
My first suspect was the BOSS unit, as i am not yet limiting them on the amp, but it turned out it was the JB/PR VNF that bottomed out. And it wasn’t the SLAPS, it was the JBL’s. I was thinking, if i have to turn down the level, using a HPF or negative LS, that would affect all content on all listening levels. So once again i activated the compressor function on the 10x10HD. And guess what: it worked perfect for this purpose, it is a soft(totally adjustable) limiter, so you don’t notice it engaging, and it allows you to keep whatever EQ or HC you want, and only limits power when it becomes to much to handle.
It kind of works like a "reverse" Inuke DEQ, only instead of increasing area of the FR curve you choose when lowering the volume, you taylor the FR curve like you want, and instead limit it when it goes bananas
And then i thought: could that approach work on the BK’s too, to prevent them bottoming out, instead of using the negative LS i have been using up until now, and yup, it works equally great there . So then i ran each of my LFE components(exept FF’s) through some of my demo clips, while tweaking the compressor on each output, and ended up with no bottoming, plopping or clacking, just clean deep ULF TR. I was very impressed with how perfect the compressor worked in this case, because i don’t have DSP amps on all my gear, so this was a great solution
DesertDog, SBuger, Kevnmin and 1 others like this.
Dual Atmos Receivers - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 6xSI18" - 8xJBL 12" BOSS - 4xJBL 12" w/SLAPS M12" VNF - 3x2 stacked Crowson MA - 4xBK-LFE - 6xNU6K(fan&trig mod) - Minidsp 10x10HD - Oppo UDP203 - XBox OneX - Apple TV4K - JVC RS600 Dreamscreen V2 120"- Philips 65OLED873.
Nalleh’s HT
Nalleh is offline
post #782 of 837 Old 06-13-2019, 09:58 AM
BP1Fanatic's Avatar
Quoted: 203 Post(s)
Liked: 171
Nice adjustments!
Sony XBR65x900e / STR-DN1080 / original PS4 / WOW! Ultra TV / Quantum Access Mini PC Stick w/Windows 10 / 8 x Rockville SPG88 8“ DJ PA Speakers / Dayton Audio SA1000 / Kicker 08S15L74 in a Tapped-Tapered Quarter Wave Tube (negative flare tapped horn).
BP1Fanatic is offline
post #783 of 837 Old 06-14-2019, 10:17 AM
DesertDog's Avatar
Quoted: 513 Post(s)
Liked: 1475
Nice! You said it wasn't the SLAPS but the JBLs bottoming out. Do you think it was the addition of the SLAPS to the box though that allowed the JBLs to start bottoming out?
Mentioning the Inuke DEQ reminded me too that I need to look into how to actually set it up. I've never used it before and wanted to start using it to boost my BOSS up a bit at lower levels.
BEQ Slack group
The struggle is real for Generation Xplain Digital to the Analog and Analog to the Digital.
Klipsch RF-7III, RC-64III
SI HS-24mkIII BOSS-Sac
Sony 85X900F, Denon 8500, nVidia Shield, Apple TV
DesertDog is offline
post #784 of 837 Old 06-14-2019, 03:37 PM - Thread Starter
Nalleh's Avatar
Liked: 3132
Yes, it was because of converting to "ported". Sending the same 300W pr driver to them now, is asking for 25mm+ Xmax from them(at the same 15hz the content in question was), so they bottom out. They no longer has the "stiff air spring" a small sealed box is.
The SLAPS is at ~80mm stroke at that power, so it’s still good .
So, using the compressor took care of the bottoming, but left all the good stuff in there
In fact the compressor works so seamless and unnoticed, that i actually use Low Shelfs on both the BOSS, JBL/PR’s and the BK’s to add as much ULF as possible except for those mega bursts that overpower them
Speaking of, after i read @Sekosche was taking it for a spin, i watched Battle Los Angeles tonight, and O!!!! M!!!!G!!!!!
What a ride!! Holy Moly that movies has a INSANE soundtrack! I used Neural X upmixing for a 9.1.6 config, and altough using even the modern upmixers isn’t a garuantee for a good experience, THIS ONE was ! It had exellent surround and height action and as such was A LOT better than many of the native Atmos/X tracks out there.
And the LFE track...... man it was off the hook! Totally nuts, and BY FAR the best experience i have had in my setup! It was relentless, had very creative use of sounds/effects, guns, bombs, the alien aircrafts, etc.
And it had it all, wobble, punch, sweeps, and all weapons and bombs had different sound signatures, i had such a blast, LOL, i was exhausted after the movie was done, holy cow, HIGHLY RECOMMENDED!! I have of course seen it before, but a long time ago now, with a much smaller setup, so it was such a cool revisit
After my earlier tweaks on the compressors, this was a perfect test to see how it worked, and i am happy to report no bad sounds from my setup, no popping, bottoming, distorsion(although it is probably there, but nut audiable), so that was cool.
In fact i am so impressed with how well all the components work together now, it is awsome, with so many different components that all have their pros and cons, getting them all to cooperate isn’t easy, but it seems i have made them behave together. It is so dynamic, explosive, the wobbles is just nuts, and it is so tight it is like it is trying to slap you. With a BIIIG hand, LOL. And it sounds and feels so effortless, like the headroom is endless, it just keeps going, there is never a time where you think: oh, that was a little over the top. It’s rather : how the hell can it sound/feel like that, without struggling??
Also, i got the 2x SI18" setup in a NF’ish config, like @SBuger has them, to the sides of the MLP along the back wall, and no REW on them yet, just a quick delay and phase setup by ear, but they really seem to "fill out" the LFE better, it sounded more complete and full.
Here is a pic, you can see the SI’s in the outer rear corners. Sorry for the mess, but i was on my way to work, so just a quick pic
Fun times
DesertDog, SBuger and Sekosche like this.
Nalleh’s HT
Nalleh is offline
post #785 of 837 Old 06-14-2019, 08:10 PM
Sekosche's Avatar
Quoted: 1378 Post(s)
Liked: 3393
I bet Battle L.A. is just relentless on your setup!
I agree about setup complexity being finicky, and I hate recalibrating everything for this reason, because usually I get it just to my liking and then the next big change in the setup I lose a little special sauce doing another calibration and am taking one step forward and another one back. I don’t spend much time these days tweaking anymore now that I know where I like most my settings and haven’t even ran REW in a good while, such a rabbit hole it can be.
Battle L.A. and MMFR are probably the two bass tracks that wear me out to the point of exhaustion when ran full tilt. Speaking of which, I haven’t watched MMFR in a while, but that’s part of the reason why, so brutal!
Looking at the long game now for some serious nearfield subwoofer power, and these “reasonably priced” 21” pro drivers have been calling to me. Just ran across the LaVoce San214.5 Neo drivers that look to be a bargain at only $450 each and seem to be nearly identical to the B&C 21DS115 for $150 less, but they are 8ohm only so I would definitely fall short on power with an iNuke 6K, but I probably wouldn’t need that much anyway. I barely use 5-600w for each of my current 15” nearfields and rarely ever hit the limiter on them.
https://www.parts-express.com/lavoce...8-ohm--293-732
It’s innovative DIY threads like yours that make this hobby so fun, and a never ending journey for what is possible and enjoyable. I’ve been working nights the last 4 years and am finally getting back to day shift soon, so I’ll be looking forward to having more time for projects during the daylight hours. I’ve got a big family vacation coming up at the end of July so probably not a good time to drop another grand on HT gear, but will see if any decent sales pop up to get the ball rolling before the end of summer. And this is only if the wife doesn’t kill me for wanting to already replace my current 4.5 cu ft VNF subs with a larger single 10 cu ft box behind the couch after only a year.
Keep up the good work!
SBuger and Nalleh like this.
Speakers: PSA MTM-210T x2, MTM-210C, MT-110SR x2; Atmos-SVS Satellite x2, DIY Volt-10 x2
Subs: PSA V1801 x2, DIY: 18" RSS460HO, 15" RSS390HO x2, BOSS w/JBL CX1200 x6
MA’s: Crowson Tech x2
Processing: Denon X4200, NU6KDSP, 3KDSP
Video: Epson 3700; Screen: Silver Ticket 106" High Contrast
Sekosche is online now
post #786 of 837 Old 06-14-2019, 08:53 PM - Thread Starter
Nalleh's Avatar
Liked: 3132
^^^Thanks man
Hey now, don’t sell yourself short, i bet it is insane on your setup too, with MA’s, BOSS and ported 15" VNF’s, you have a pretty crazy setup too
Oh yeah, the complexity can be daunting when you start tweaking, but what i find extremely satisfying is when you get a better results than when you started Just from tweaking what you already have!
But i agree, i was super happy with my setup after i did the stack MA’s, and had no plans on going further, but as we now: i did, LOL.
But today i am glad i did, because the end result is just staggering, and much better than i hoped. Tried a lot of versions, but have now ended up with a setup i can live with .... i think...
And yes, i too know what works with my setup, and a REW session is rather fast nowadays, so delays, levels and EQ is almost done without measuring. A advantage of knowing your setup and what you like
Yeah, i have been reading about those B&C and LaVoce drivers too, they seem quite spectacular for the money, so they would probably pound something fierce as nearfields, LOL. Seems like they work extremely well i PSA’s new TV36 subs, so yeah, would be fun to try out. Let us know how that goes, if you go there
I work nights and weekends too, so i understand about finding time for projects, however i am single, so no WAF to consider, LOL. I don’t think my setup would be this crazy if i wasn’t, HAHA.
BTW: have you seen Fury lately? It is insane in UHD and Atmos, and it has a awsome LFE track too
SBuger and Kevnmin like this.
Nalleh’s HT
Nalleh is offline
post #787 of 837 Old 06-14-2019, 10:05 PM
Sekosche's Avatar
Liked: 3393
It is insane! I’ve watched the Fury UHD twice already with BEQ too (I think once after adding the first BOSS), and it was spectacular! Such a well balanced track with just brutal midbass, mortar explosions, machine guns galore, and that deep tank rumbling ULF. Although it’s just an updated soundtrack in my setup, it was easily one of my favorite’s of the year.
I posted my brief thoughts on it in the bass thread after @PioManiac recommended it, and how it nearly gave me an anxiety attack at +120dB’s; only time I’ve experienced that from audio. It was the first movie I really let rip after adding the VNF subs, and wow they really made it pound. It’s memories like that when I wonder why/if I really want more bass...but more is usually better.
Now I want to watch Fury again, but first I need to give Lone Survivor a BOSS ride, lol.
The new PSA subs are also what got me looking into pro audio drivers, as those definitely look to be some beasts. I’m still undecided if I want to shoot for a little higher tune in the mid/upper 20’s in a bit smaller cab 5-7cu ft with a pair of boxes or go bigger around 10 cu ft for a 20Hz tune closer to where all my subs are now with a single driver. I guess I could just build one smaller cab for starters and see how I like it, would definitely be the wallet friendly way to go.
I feel like I wouldn’t miss much around 20Hz for TR with all the other fire power I have now, but it’s hard to say without experimenting. The cabs have to be really slim, 14-16” at most for depth to fit behind me and less than 24-26” tall, so I’m not really wanting to build a super long 80”+ single sub enclosure that would be very awkward to handle, which is why I broke up my current VNF into two boxes with one behind each seat.
Luckily, I’ve got a week off now, so plenty of time to get the DIY wheels turning. I think I’ll start a build help thread for potential slim 21” sub designs to verify my WinISD modeling is accurate, and the ideas are sound. We’ll see what the future holds!
Hope you have a good work/weekend!
SBuger, Nalleh and Kevnmin like this.
post #788 of 837 Old 06-15-2019, 08:42 AM - Thread Starter
Nalleh's Avatar
Liked: 3132
^^^ Yup, Fury was probably the first movie that got me exhausted too, after the first tank battle i was like: "phew, i almost fogot to breathe there". It is awsome !
Yes, all this TR firepower decreases the need for a low tuned NF somewhat, but if tuned to high, it migh be more localizable, so it is a balance. However you can just turn it down, it that happens, so no biggie. But it seems midbass/punch isn’t hard to do, it’s the ULF that is difficult, and that is what i love, so i would actually do as low a tune as possible. But that’s just me
A build thread sounds like a good start
Have a nice weekend you too
SBuger likes this.
Nalleh’s HT
Nalleh is offline
post #789 of 837 Old 06-16-2019, 07:18 AM
Quoted: 212 Post(s)
Liked: 117
....I was thinking, if i have to turn down the level, using a HPF or negative LS, that would affect all content on all listening levels. So once again i activated the compressor function on the 10x10HD. And guess what: it worked perfect for this purpose, it is a soft(totally adjustable) limiter, so you don’t notice it engaging, and it allows you to keep whatever EQ or HC you want, and only limits power when it becomes to much to handle.
Nalleh, can you share more about what you're doing with the compressor function. Either the settings you use or how how you derived the setting to use. I read the manual last night for the 2x4HD I have in my system. It sort of make sense, but I'm still somewhat confused by it.
I'm using an old Sony AVR to power my BOSS. I feel that I have my MV on that unit set just about right, but I do experience the random bottoming out. Last one was in the new Death Wish with Bruce Willis. I didnt time stamp the time, but it was at the bar scene about 3/4 into the movie. The deep ULF music in the background scene was the culprit, but only at one time throughout the whole scene. I think this compressor function would work effectively as you've found.
Sony 75X940E, Denon X6200w, Sony X700, Roku Ultra, MiniDSP 2x4HD
Parasound (2x)HCA-855a, HCA-750a, Sony ES4300
Mission 705a L&R, dual 70c3 C, 703 SL&SR, 705 BL&BR, (4x)Yamaha NSIC800 Atmos
LFE- Front: M&K MX-200 & MX-150THX; Rear: M&K V-75 & Klipsch RW-12
ULF- 12" JBL(6x) Mini-riser BOSS + (3x)Aura AST-2B-4 shakers
Kevnmin is offline
post #790 of 837 Old 06-16-2019, 08:49 AM - Thread Starter
Nalleh's Avatar
Liked: 3132
@Kevnmin :
Sure, no problem.
In this recent case i had a scene that caused the bottoming, so i used that to test the settings. First of all i played that clip repeatedly with only one LFE component active at a time, while increasing the volume up to my normal movie watching level. This way i found which one was bottoming/overpowered.
Then i started by setting the threshold at -25dB to see if it was enough. You can also see when/how much it activates on the vertical green to red bar. If that was enough, try reducing, if not: increase.
The bar only shows what’s above the threshold, so it should only be active on the peaks/loud sounds). So if it is on 0(zero), it is not still activating.
PS: not the settings i use in pic.
I set the ratio at 4-6 (a rather sharp knee), because i want that level to be more of a stop, not just sligthly progressive.
Then there are 3 more settings: attack, hold and release. As explained in the manual, these are for how quick it activates, how long it holds, and how long before it deactivates after the peak is gone.
Once i found the needed threshold level, i tweaked the others setting and ended up on 30-50ms on the attack and release, and 20-30ms on the hold parameters.
This fixed the problem like clockwork
Nalleh’s HT
Nalleh is offline
post #791 of 837 Old 06-16-2019, 12:32 PM
Quoted: 212 Post(s)
Liked: 117
Thanks for the pointers. I'll do some experimenting to find the magic numbers.
By the way, I love the config of your TR sled setup now. The numbers you posted, holy crap!!!!!!!
Nalleh likes this.
Kevnmin is offline
post #792 of 837 Old 06-16-2019, 01:21 PM - Thread Starter
Nalleh's Avatar
Liked: 3132
No worries, and good luck
Nalleh’s HT
Nalleh is offline
post #793 of 837 Old 06-16-2019, 01:21 PM - Thread Starter
Nalleh's Avatar
Liked: 3132
Hmm, just a week in, and i am already planning upgrades, LOL !
Ok, so a i have now loaded my TR Sled with(amongst other) a 4xJBL cantilever BOSS + the 2xJBL+1x PR VNF/BOSS box on top of that. And it works awsome.
But somehow it just seems i have more gas in the tank....i still feel using 8 total JBL’s pumping free air, seems like a waste, altough it works great for TR, and then i end up with just 2 VNF boxes with "just" 4x JBL’s total(+2x PR) for NF SPL.
So the Pr setup i use now is:
2x 4cf NF boxes each with 2xJBL +1 x downfiring SLAPS M12. MMS for BOSS action= 544 x 2= 1088grams.
And then 8x JBL total in cantilever BOSS. MMS= 179 x 8=1432grams
= 2520grams total MMS for the whole couch.
What i am thinking is:
Use the 3x NF boxes each with 4xJBL as i had it from the start, only adding 2x SLAPS m12 downfiring in each box, so MMS=544 x 6= 3262 gram TOTAL (no BOSS).
This way i will get more MMS for better BOSS function, AND still have all the 12x12" JBL’s for VNF duty making SPL. Plus the added low end from the 6x SLAPS.
The WINisd looks rather similar for the 2xJBL+1xPR as it does for the 4xJBL+2xPR, only more midbass for the latter, but no disadvantages.
Yellow is 4x sealed, blue is 2+1PR, and red is 4+2PR. Both active and passive drivers behave similar in both PR setups, stroke wise.
And instead of 1 xPR working at ~60-80mm stroke, i will have 2 per box!
Sounds like a no-brainer in my brain
Oh, and i slapped some paint on the nr2 TR Sled
Nalleh’s HT
Nalleh is offline
post #794 of 837 Old 06-17-2019, 09:35 AM
SBuger's Avatar
Quoted: 1161 Post(s)
Liked: 3597
Great stuff man!!
Sounds like the compressor on the mini works great!!
Also, way cool about Battle Los Angeles. I thought I had that one but don't. Need to check it out for sure. I remember that used to be one of coolrda's favorites for full band craziness, right before he became inactive. That and HTTYD (and TIH) of course.
As far as your latest plan, sounds good. I'm sure you'll settle in on the ultimate and be nothing short of AMAZING!! It already is, but will get even better I'm sure There always seems to be room for improvement in this crazy hobby of ours.
Seems kind of strange for me after the last couple months (and even years lol) of seemingly endless experimenting and tweaking, that over the last 3-4 days I've just enjoyed the HT with none of that. Felt reaaaaaaally good actually lol. Finished up the last two seasons of Game of Thrones and some other stuff.
Cool that you mention B:LA upmixed as being so good from 5.1.
I don't know what it is about 5.1, but it seems to upmix very well for the surrounds channels with an amazing kind of atmosphere or something with Neural:X. Even more so than 7.1 for me with the mixes I've tried it on. EX. Tome raider (the latest one) upmixed in N:X was just crazy and better in ways than the actual atmos mix. I thought GoT was amazing as well upmixed with Neural from the 5.1 track.
I do think (at least on my system), that the bass (dynamics, clarity, and just raw precision and power (the kind that is hard to describe)) lacks in comparison to the base mix with no upmixer (Neural or the DSU) whether it be 5.1 or 7.1. The bass is just different and losses something with the upmixers in comparison. Maybe a tad bit better in some ways, but suffers in bigger ways (mainly ULF I think). I've noticed this on just about every track I've done the comparisons on. Pirates: DMTNT actually shocked me at the difference and was sickening to find this out. Yes the overall surrounds where better and more engulfing, but the bass suffered in weird ways like I was trying to describe. Sometimes is doesn't matter, and I didn't really care on GOT because the surround and envelopment was so much better and the bass was still good. And if one doesn't do a direct comparison, you may never know the difference anyway in the bass.
Me and biga use to talk about his quite a bit a while back (before he went missing around here too) and we both found the same thing. Except Neo:X didn't seem to do this with the bass on his, nor did it when I was Neo:X capable on my older system. I wish they still had that as an upmixer option instead of just DSU and Nueral:X only for the older (and sometimes newer) non atmos or dtx movie mixes.
I may be in the extreme minority here though and one of the few that notices it. Or it could just be on my system. It may be different on you system with so many speakers, but on mine with the normal 11 channels, bass suffers with these two umixers. Sounds like it kicked major ass for you though on B:LA and all your speakers (surround and bass). I'm sure it does as well with most content, 5.1 or 7.1 non atmos mixes.
Do you ever find this to be the case for you in what I was trying to describe on non-atmos/dtx mix's with the upmixers or do you find it to be the same or maybe even better in the bass department?
With all your speakers though, you may use one of the upmixers (Neural:X) all the time though, even on native atmos/dtx mix's, IDK. Just curious.
Nalleh likes this.
My "Blacked Out" Home Theater Room
1400cuft sealed room, suspended floor | SY Triple Black Velvet for Blackout | Denon AVR-X6300H - 7.6.4 Atmos | KEF Q Series Speakers | GIK Treatments | Oppo 203 | Epson 5040 4K | Eyes 7' to 120" AT Seymour Screen | 6x 18" Sealed DIY Subs (4x SI DS4-18s & 2x UM22-18s) | 6x Crowson MAs | 4x BK LFEs | BOSS 'Sub Riser' 6x JBL12s | MiniDSP 10x10HD
SBuger is offline
post #795 of 837 Old 06-17-2019, 02:23 PM - Thread Starter
Nalleh's Avatar
Liked: 3132
Thanks man
Yup, you need to get Battle L.A for sure, it is awsome. Can’t believe you don’t have that one, it should be in everyones demo disc pile
Yeah, i need to order some more SLAPS, and then go for that change. Looking into it.
It is great to finally enjoy some movies, huh? I have managed to see a couple too lately, both John Wicks for example(both were awsome), and plan to watch more going forward.
Yeah, some movies gets a tremendous upgrade from the upmixers, while others are just "mehh", so you never can tell going in how it will turn out.
However i always use one of the upmixers, unless it is native Atmos/X/Auro, So i haven’t noticed any difference in the LFE track. The little i have tested that, i did not noticed any difference either, so that sounds strange.
It may be that my setup is tuned to how i normally listen to it, as since i always use upmixers, it is not a problem for me.
However i have noticed that the Auromatic upmixer seem to have a louder LFE track than DSU and X, but haven’t investigated it further.
SBuger likes this.
Nalleh’s HT
Nalleh is offline
post #796 of 837 Old 06-17-2019, 04:12 PM
SBuger's Avatar
Liked: 3597
Yep for sure, I need to get Battle LA. I did have it at one time on my Hard Drive but lost it. I thought I had replaced it but guess I never did. Gonna do that for sure!! Also glad you mentioned the John Wicks, as I was wanting to re-watch those again to get ready for the 3rd installment but might have forgotten about it with all the other stuff I want to watch as well.
Also I need to go check out that Underworld Awakening again since you mentioned it in the BEQ thread. That used to be one of my absolute favorite Demo movies (lots of scenes) even before BEQ got hot around here. That movie is insane bass wise and will just pummel and shake you death in such a good way. Some of the best bass ever IMO, right there along side MMFR. Those two just deliver in the BIG bass slam you can really feel, even beyond some of the best bass movies around IMO. Maybe its their mega powerful 20-35hz area and the way its used IDK, along with some deep stuff in there too.
You and Sekosche were talking about MMFR and Fury being so awesome and exhausting with so much intensity and some of your best experiences. On my last system, that's how MMFR and Underworld Awakening were to me. I remember letting them rip full out when I use to listen louder with about the same amount of TR system capability I have now, and was exhausting (and even terrifying) in such a great and awesome way LOL Those were the most insane Bass and TR experiences I've ever had back on that system with those two movies. I need to revisit them again on this one, just not quite as loud and see how it compares (I use to listen too loud, because the louder you can listen the more slam you can get). Not good on the ears though if it gets too loud, at least not mine.
Heck, maybe it'll be even better now with this system . A bit different I'm sure, but hopefully as good or better. That'd be cool I demo'd my current favorite today of that street chase scene in 'Venom'. It seemed so brutal and had that certain terrifying feel to it, yet still in complete control. It actually felt like it was hurting my insides from bass intensity (although I know it was mainly TR intensity that just seems like ultra powerful bass), but man was it ever satisfying It's the feeling I've been chasing ever since moving into this new room. I've had it, but wanted more of it. I'm sure you get a real similar kind of feeling and then some on that Battle LA movie (and others) from your descriptions of it (which I loved reading about BTW!! ) I can only image the brutality you get from it on you system!!!!
I also ran those sniper shots again from The Girl in the Spiders Web that Aron was talking about in the BEQ thread. INSANE!!! Have you checked that on out yet? Super cool use of ULF throughout too!! Good movie too I though, if you haven't seen it yet.
But yeah man, so great to finally start enjoying some content and be really happy with the system, as well as through in my normal demo time (which is just so fun and satisfying in its own way )
Cool then on your up mixer experiences, glad to hear it that you don't notice a diff in bass quality or presentation on your killer Frankenatmos system, except louder with Aura!!! That's fantastic, and easy enough to turn your sub trims down a hair too if need be when you do switch to that one.
I wish I didn't notice a diff in bass presentation, but I do on my system. Oh well, there are becoming more and more good ATMOS and DTS:X mixes all the time. I'll have to try it out again though, and Underworld Awakening will be a good one, since its DTS-MA 7.1 still. I'll try normal DTS-MA 7.1 against DSU and Neural:X. The surround I know will be way more immersive with the upmixers, but am pretty sure my bass will suffer from it too as usual, unfortunately. It's not just that's a little louder either, as I do need to usually turn down the trims about .5 to 1 db to level match them better to non umpmixed (from the redirected bass from extra ceiling channels I think), but it's not just that. It's different feeling and lacking in certain areas vs just the plain ole DTS-MA 7.1 track. Whatever the reason on my system, I wish it wasn't so, but it's there ever time I do the comparison on most good movie bass material. I guess I really only care about this on intense demo sessions on some of my favorite tracks. Just movie watching, not near as big of a deal and the better surround is welcomed.
Nalleh likes this.
SBuger is offline
post #797 of 837 Old 06-18-2019, 07:37 AM - Thread Starter
Nalleh's Avatar
Liked: 3132
Yes, those are all demo movies you mention, for sure
Yeah, i actually have The Girl In The Spiders Web, just haven’t watched it yet. I actually got all of them recently, both the swedish(original) trio, and the other US version with Daniel Craig, so need to see all of them, LOL.
OK, on another note, got "done" with one of the TR Sleds today, so here’s a couple pics of that.
Started by removing the unpainted one and swapping in the one i painted earlier, this will be for my(left) seat, and i will paint the other one and put on the right side. Ready to mount with iso’s in place
Everything setup and connected, BK’s in front, stacked MA’s with temp probes, and the 4xJBL BOSS in cantilever mounting.
Seat on sled.
And VNF in place with the 2xJBL+PR. I will use this "temporary" PR box until i get the SLAPS to convert to 4xJBL+2X PR.
Everything is basically setup to mount the other sled too, only some tweaking on the MDF under that seat. Will probably get it done this weekend.
Will be interesting to see if linking those two sleds together as one will have any impact on how it feels and perform
Nalleh’s HT
Nalleh is offline
post #798 of 837 Old 06-18-2019, 08:00 AM - Thread Starter
Nalleh's Avatar
Liked: 3132
And i also did a little REW to see how it looks.
Since BEQ i have removed a lot of the house curve, as it is plenty without, LOL, so a much flatter curve now. Didn’t do to much tweaking on the curve, i see that the SI18" NF’s have a dip at ~35hz and the JBL VNF’s at ~ 18hz , but no biggie
Nalleh’s HT
Nalleh is offline
post #799 of 837 Old 06-18-2019, 10:19 AM
SBuger's Avatar
Liked: 3597
WAY COOL!!!!!! The meanest looking TR setup I've ever seen, and I'm sure feels like it too!!!!!!!
Paint looks great and so do your FR graphs, NICE!!!!
Yeah will be interesting too see what you think when you connect it to your other sled, as well as the more improved VNF/BOSS 4JBL+2x PR versus the 2JBL+1PR. I'm thinking something like
Nalleh likes this.
SBuger is offline
post #800 of 837 Old 06-18-2019, 11:10 AM
DesertDog's Avatar
Quoted: 513 Post(s)
Liked: 1475
Are you keeping the BOSS now? From your post the other day it sounded like you were removing it and going with 4x JBL + 2x SLAPS boxes instead. I was going to ask why not keep the BOSS with the 4x2x boxes.
@SBuger I'm surprised too that you didn't have Battle LA. It's a monster and doesn't even need BEQ (but of course we BEQed it ) Did you ever check out the Pulse server room scene?
Another movie to mention with the others that were just listed is Ender's Game. If you haven't tried it in awhile there's an explosion at the end that makes the catalyst bomb in RP1 look tame. It rattled stuff that I didn't know could be rattled.
BEQ Slack group
post #801 of 837 Old 06-18-2019, 11:46 AM - Thread Starter
Nalleh's Avatar
Liked: 3132
Keeping the BOSS for now
I only have two SLAPS units so far, so i will order 4 more to do that conversion. And i also have "just" 12 JBL’s in total, so i can’t do 8 in BOSS AND 12 in the VNF boxes.
I don’t want to convert the VNF boxes until i have the SLAPS, because that would leave two gaping holes in each box, LOL. Bad for LFE.....
So for now it is 2x VNF boxes and 8x JBL BOSS.
IT’s not like either is a BAD solution though, LOL.
Yeah, about BATTLE L.A, i didn’t even use the BEQ file when i watched it. I was...afraid to....
Granted it’s not the biggest BEQ, but it should make a difference nevertheless.
Nalleh’s HT
Nalleh is offline
post #802 of 837 Old 06-18-2019, 12:00 PM - Thread Starter
Nalleh's Avatar
Liked: 3132
BTW @ryanmh1 : did you notice they have updated the TS for the SLAPS slighly?
https://content.earthquakesound.dk/w...-12M_chart.pdf
Nalleh’s HT
Nalleh is offline
post #803 of 837 Old 06-18-2019, 02:05 PM
SBuger's Avatar
Liked: 3597
LOL yeah ..i just kinda forgot about it until Nalleh brought it back up. Also, I think LastButNotLeast posted that pulse scene in MKV too for me over in the VS thread a while back. Need to go snag it.
And yep ..Enders Game is another. Now I do have that one on disc Not the Atmos version though ;/
Oh yeah, I didn't think of that, you not having enough 12's for 4 per VNF box + the 4 per seat BOSS canti as well. hmmm ..well should be more than good (maybe even way better) with the extra PRs instead.
yo Nalleh, - I think somebody mentioned over in the BOSS thread, about mounting something in a way to increase X axis (side to side). You ever thought about mounting something (like one of your BKs or driver perhaps facing side to side instead of straight down or forward? Not that your X axis is lacking at all, quite the opposite, but could perhaps overlap perfectly with the other 2 axis into the singles, possibly on your Meg VS and others.
Just a thought if you wanted to bring it up more, might be worth trying. It might be just about right though as is. I think it was d00d that mentioned somewhere that he thought the X and Y axis (even more so on the X side to side) that the body feels that more strongly than Y and even more so than Z. If that is true or not I don't know for sure, but think it might actually be true. I know at one point, when I had two seats and was messing around I had one of my VNF subs facing into the side seat (into its side, not behind it) super close to my seat I don't set in. It gave me a LOT more side to side feel in the ULF department. Honestly, not quite sure what I thought of it, but was most definitely felt and brought a different kind of feeling that I wasn't used to.
SBuger is offline
post #804 of 837 Old 06-18-2019, 02:20 PM - Thread Starter
Nalleh's Avatar
Liked: 3132
Thanks man
It’s kind of funny looking back now, i was over the moon when i got the stack up and running, and after some tuning, got the graph to the left in pic below.
To the right is what i have today. The difference is just ridicolous !!!! Not just the numbers, but the graph is so much better now with all axis combining like that, it’s hard to believe actually.
Nalleh’s HT
Nalleh is offline
post #805 of 837 Old 06-18-2019, 02:26 PM - Thread Starter
Nalleh's Avatar
Liked: 3132
I did try something like that. Don’t you remember when i first built the MDF plattform, i had one BK one each end, and they worked a lot more in the X-axis, actually swapping Z- axis for the X-axis instead.
But didn’t care for it much..... it doesn’t feel natural coming from the sides, i like it from below and behind.
When i moved the BK’s from each end to under the seat, it was miles better
SBuger likes this.
Nalleh’s HT
Nalleh is offline
post #806 of 837 Old 06-18-2019, 02:53 PM
Quoted: 212 Post(s)
Liked: 117
@Nalleh h I'm glad you mentioned your experience with that because just as @SBuger mentioned, I did make the comment about wanting to try the X axis over in the Boss thread. Sounds like you're light years ahead in the TR realm of experiments. I believe I'll pass on the side to side thoughts now and continue to come up with my own version 2 -most likely more of the cantilever design rather than under seat.
Kevnmin is offline
post #807 of 837 Old 06-18-2019, 03:04 PM
SBuger's Avatar
Liked: 3597
Yes, but I'm talking about not something actually mounted to the side of you, I'm talking about maybe a BK underneath you but just mounted sideways, (not normal mounting and off to the side). Or even a driver or something. Make sense? May not be any good though, IDK. Could possible give too much X as well, again IDK. Was just a thought since you are master of experiment
When you had the BK mounted on the sides, you just had them mounted normal side up vertical right? Yes, I agree, pull to one side or the other is not good and seems out of balance if you can feel it (not good at all!). Not the same as side to side motion though (X axis).
EDIT: oh yeah, meant to comment on your graphs above too. BIG difference!!!!
Nalleh likes this.
SBuger is offline
post #808 of 837 Old 06-18-2019, 03:13 PM
DesertDog's Avatar
Quoted: 513 Post(s)
Liked: 1475
You know they've made some more of them, right? What's another 8 to go along with what you already have? THey're almost all hidden.
That's a quote to keep
BEQ Slack group
post #809 of 837 Old 06-18-2019, 04:21 PM
SBuger's Avatar
Liked: 3597
^^^ LOL ..now that's funny and yep a keeper for sure
and yeah, heck what's another 8 x 12's in addition for more canti BOSS action, you've gone this far
SBuger is offline
post #810 of 837 Old 06-18-2019, 06:42 PM
Liked: 2
Updated the diagrams of the new setups.
And the LFE.
Been a big fan of your setup, do you happen to have a diagram of both AVRs (pre-outs, zones, etc) to see how everything is connected (similar to the diagram on first page with three AVRs)? I'm still wrapping my head around that. For context, I have a X8500H and I'm considering getting a cheap X6200W to expand the hardware limitation for more channels (Planning to do > 9.2.4). Thank you!
Nalleh likes this.
chroman is offline
