UHD Media Codes - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 67Likes
post #31 of 221 Old 05-25-2018, 03:09 PM
astateofmind's Avatar
Quoted: 202 Post(s)
Liked: 50
You mentioned gladiator. Have it?
astateofmind is offline
post #32 of 221 Old 05-25-2018, 03:38 PM - Thread Starter
galonzo's Avatar
Quoted: 1557 Post(s)
Liked: 2170
Sorry, already gone
Main: XBR-85X950H | X4500H (5.1.4) | UDP-203 | TiVo Bolt | 2019 Shield Pro | PS4 Pro | CCU
2nd: XBR-65X950G | LG LAS855M | UBD-K8500 | TiVo Mini | ATV (4thGen)
3rd: 65P-F1 | Klipsch HDT-SB3 | UBP-X700 | Tivo Roamio | AppleTV4K | Roku P+ (4630)
FS - Dr. Strangelove (1964) and other UHD Digital codes (and some HD codes)
galonzo is offline
post #33 of 221 Old 05-25-2018, 03:44 PM
Azreil24's Avatar
Quoted: 157 Post(s)
Liked: 44
A pleasure to do business with. Thank you!
galonzo likes this.
LG OLED 65C8P, Sony UBP-X700, Marantz PM6005, Dali Zensor 7, iFi Nano iDSD DAC, Mogami Cables.
Azreil24 is offline
post #34 of 221 Old 05-29-2018, 06:56 AM - Thread Starter
galonzo's Avatar
Liked: 2170
Found a couple more vaild codes in the stash (in green), some of last week's new releases still available; prices dropped (in orange). Sorry, this week's new release, Annihilation UHD (2018) has already been claimed.
galonzo is offline
post #35 of 221 Old 06-01-2018, 08:14 AM - Thread Starter
galonzo's Avatar
Liked: 2170
Added another valid code form the stash today (in green); there can't be very many left, as it looks like just about my entire collection is either listed or sold (but there's a few more, judging by the total).
galonzo is offline
post #36 of 221 Old 06-04-2018, 09:45 AM - Thread Starter
galonzo's Avatar
Liked: 2170
Just added the remainder of valid codes from my UHD disk collection (in green); I have The Incredibles UHD (2004) pre-ordered, and it will be listed once i have it in-hand.
galonzo is offline
post #37 of 221 Old 06-05-2018, 08:54 AM
Quoted: 45 Post(s)
Liked: 4
Simple question here, but I want to make sure I'm reading the Google Doc correctly. I am looking at the movie "The Revenant" and under the FandangoNow tab it says "Yes/Not UV". Does that mean that if I redeem a code through FandangoNow, instead of UltraViolet, then it will be viewable in UHD?
Sundodger is offline
post #38 of 221 Old 06-05-2018, 09:04 AM - Thread Starter
galonzo's Avatar
Liked: 2170
It means that it will not be added to your UV "locker" if you redeem at FN, but it should port to MA if you have that set up (I haven't been using FN, so I can't confirm); it is my understanding that if you redeem a MA movie, such as this one, at moviesanywhere.com/redeem , you'll get UHD rights across all supported services you have linked (the sheet says to redeem as iTunes for UHD MA rights for this one in particular).
HTH!
Edit, I believe it also means that you won't get UHD if you redeem at FN, as the UV UHD rights column says no code redeems as UHD for UV
Last edited by galonzo; 06-05-2018 at 09:11 AM. Reason: added additional clarification
galonzo is offline
post #39 of 221 Old 06-05-2018, 09:22 AM
Quoted: 45 Post(s)
Liked: 4
Originally Posted by galonzo View Post
I
Gotcha, thank you. I thought maybe FandangoNow and UV were separate enough that I could redeem on FN and be okay. Getting down to it, my streaming device is Xbox One X and I don't think there is a MA app for that.
post #40 of 221 Old 06-05-2018, 09:29 AM - Thread Starter
galonzo's Avatar
Liked: 2170
So you wouldn't need the MA app anywhere (sort of like how there isn't a UV app, but you can watch UV movies on VUDU and/or FN), you would only need to create a MA account and link services (my FN is linked, but I never use it; I can check one of my similar UHD Fox redeems and confirm that it ported to FN as UHD on my Roku, I'll post back what I get...)
galonzo is offline
post #41 of 221 Old 06-05-2018, 09:58 AM - Thread Starter
galonzo's Avatar
Liked: 2170
So the Fox UHD codes I redeemed prior to setting up my MA account did not port to FN as UHD, but the UHD Fox code(s) I redeemed at MA after I set it up and added my FN account ported to both FN and iTunes as UHD/HDR (Maze Runner for example, which says the same thing as the Revenant on the sheet). HTH
Sundodger likes this.
galonzo is offline
post #42 of 221 Old 06-05-2018, 10:33 AM
Quoted: 14 Post(s)
Fast and easy transaction!
galonzo likes this.
Display - LG OLED77C8PUA
Processor – Marantz AV7003, Amps – Sunfire Cinema Grand Signature, Emotiva A-700
Speakers LCR - Definitive Technology BP3000TL, C/L/R 3000, Surrounds - GoldenEar Invisa HTR 7000, Atmos – GoldenEar Invisa MPX,
Bass - Seaton F18s, Crowson Shadow-8s
jmontesea is offline
post #43 of 221 Old 06-05-2018, 12:42 PM
Quoted: 45 Post(s)
Liked: 4
This helps a ton, thanks for testing!
post #44 of 221 Old 06-07-2018, 12:48 PM
Quoted: 45 Post(s)
Liked: 4
I'm not sure what I did differently, but I linked MA to FN and then redeemed a Fox UHD code, but it says it redeemed as just HD. I emailed Fox customer support and they said:
Dear Mike,
Thank you for your email. At this time, Fox is offering e-copy redemptions in HD only.
*Please refer to your packaging for additional information on the type of transfer included and UHD/4K digital restrictions.
Should you have any additional questions or require further assistance, please do not hesitate to contact us.
Thank you,
Fox Customer Care
Oh well, I guess I'll stay away from Fox codes.
post #45 of 221 Old 06-07-2018, 01:36 PM - Thread Starter
galonzo's Avatar
Liked: 2170
Dear Mike,
Thank you,
Fox Customer Care
Ah, yes sorry, I forgot to mention that newer fox codes redeem as HD only (the ones on my list are notes as such in red, but the list is accurate about the older codes; sorry, I'm not sure when the cutoff was, but Maze Runner obviously worked for me, but the newest Maze Runner I sold as HD only (The Death Cure), and Revenant was one of the first Fox UHD titles, so it redeems as the list says, for example.
edit: you may be right @Sundodger ; looking at the list, it says to redeem those old Fox codes as iTunes to get the UHD in MA, which it is possible that is what I did for Maze Runner to port to FN as UHD (again, after I set up MA, the new ones don't have the iTunes option like the old ones did).
galonzo is offline
post #46 of 221 Old 06-07-2018, 02:25 PM
TrendSetterX's Avatar
Quoted: 445 Post(s)
Liked: 332
Just picked up Little Mermaid from @galonzo . Easy Cheesy!
galonzo likes this.
Theater: Sony 75x940E | Yamaha 3060 | DirecTv HR54 | ATV4K | MP 4K HDBaseT Extender | SVS PC2000 sub | 5.1 surround
Networking: ASUS RT-AC68U (wireless disabled) | Ubiquiti AmpliFi HD Mesh Wireless with wired back-hauls
Automation & Lighting: Control4 & Lutron Homeworks Interactive
TrendSetterX is offline
post #47 of 221 Old 06-10-2018, 02:44 PM - Thread Starter
galonzo's Avatar
Liked: 2170
This Week's New Release, Plus One More Added
Added Hostiles UHD (2018), and got shipping notice for this week's new release, Terminator Genisys UHD (2015) - $10 (currently shows that it will redeem as UHD/DV in iTunes, no word yet on whether it will be UHD in VUDU); this one will be added to the list once I have it in-hand.
Thanks to @Sundodger , we figured out that in order to get the older Fox codes to redeem as UHD in MA (the ones that have the option for iTunes on the insert), they must be redeemed as iTunes (I updated the list for those titles).
Thanks for looking!
UPDATE: Terminator Genisys UHD (2015) in-hand and added to post 1!
galonzo is offline
post #48 of 221 Old 06-13-2018, 07:21 PM - Thread Starter
galonzo's Avatar
Liked: 2170
No takers on Terminator: Genisys yet, price has been reduced. Also ended up picking up Tomb Raider (2018, $10), it will be added to the list once I snap a pic of the insert.
Thanks for looking!
edit: Tomb Raider sold
galonzo is offline
post #49 of 221 Old 06-13-2018, 10:18 PM
siuengr's Avatar
Quoted: 256 Post(s)
Liked: 277
Great seller, quick response.
galonzo likes this.
My Theater Build: The Underground Apolkalypse Theater
Marantz SR7010, Monolith 7 Amplifier, Pro-Ject - Debut Carbon Esprit SB
Epson 5040ub, Oppo UHD-203 Player, Xbox One, nVidia Shield
Atmos 7.3.4 - Polk 2x RTiA9, CSiA6, 2x FXiA6, 2x RTIA3, 4x 70-RT
PowerSoundAudio XS30, Sunfire 2x - HRS-12 12" Subwoofers
siuengr is offline
post #50 of 221 Old 06-15-2018, 12:04 PM
ironcross's Avatar
Excellent Seller. Fast response.
galonzo likes this.
ironcross is offline
post #51 of 221 Old 06-19-2018, 12:58 PM - Thread Starter
galonzo's Avatar
Liked: 2170
Added new release Pacific Rim: Uprising UHD (2018) and I ended up ordering Unsane UHD (2018, $8 - MA, UHD/HDR in iTunes, UHD/HDR-10 in VUDU); for delivery by Thursday (edit: Unsane has been sold)
galonzo is offline
post #52 of 221 Old 06-22-2018, 01:00 PM - Thread Starter
galonzo's Avatar
Liked: 2170
Prices reduced on this week's unclaimed new releases
galonzo is offline
post #53 of 221 Old 06-26-2018, 09:39 AM - Thread Starter
galonzo's Avatar
Liked: 2170
Added Source Code (2011) as well as all five Mission: Impossible movies to the list in post 1.
Last edited by galonzo; 06-30-2018 at 08:58 AM. Reason: updated listing, removed bundle deal for MI codes
galonzo is offline
post #54 of 221 Old 06-29-2018, 12:25 PM - Thread Starter
galonzo's Avatar
Liked: 2170
Update: I now have the Mission: Impossible disks in-hand, and the price has been reduced as there weren't any takers at the going new-release rate; so I will do the set for $30 (edit: sold first three), or individually as listed (or always $1 off per title when you buy more than one, except for the ones that are $5 or less).
galonzo is offline
post #55 of 221 Old 07-02-2018, 12:44 PM - Thread Starter
galonzo's Avatar
Liked: 2170
No UHD new releases this week, so I reduced the prices of all of the UHD codes that are left that will only redeem as HD; a sort of Fourth of July sale
galonzo is offline
post #56 of 221 Old 07-07-2018, 07:18 AM
ratm's Avatar
Quoted: 296 Post(s)
Liked: 120
Great seller! Codes shipped immediately.
galonzo likes this.
ratm is offline
post #57 of 221 Old 07-10-2018, 03:54 PM - Thread Starter
galonzo's Avatar
Liked: 2170
As far as new releases added for this week, A Quiet Place has already been claimed, but still available is The Equalizer (2014) edit: SOLD; I also added UHD codes for the Jurassic Park movies, which are from the HD BR box set, but according to the redeem sheet, they are MA and redeem across MA as UHD when redeemed at iTunes (I sacrificed the worst one, JPiii, and can confirm this indeed works).
As always, take $1 off per title on all codes listed for greater than $5 when you buy more than one (discount still applies when at least one of the codes is greater than $5); thanks for looking!
galonzo is offline
post #58 of 221 Old 07-11-2018, 12:22 PM
Buckeye Dave's Avatar
Quoted: 68 Post(s)
Liked: 45
Fast and super-easy transaction complete with instructions on how to redeem to preserve the 4K ownership. Highly recommended, will definitely purchase more in the future.
galonzo likes this.
Buckeye Dave is offline
post #59 of 221 Old 07-17-2018, 08:14 AM - Thread Starter
galonzo's Avatar
Liked: 2170
Added Rampage (2018) UHD code; as always, take $1 off per title on all codes listed for greater than $5 when you buy more than one (discount still applies when at least one of the codes is greater than $5); thanks for looking!
galonzo is offline
post #60 of 221 Old 07-20-2018, 08:31 AM - Thread Starter
galonzo's Avatar
Liked: 2170
Still have Rampage (2018) UHD Canadian code, lowered price; as always, take $1 off per title on all codes listed for greater than $5 when you buy more than one (discount still applies when at least one of the codes is greater than $5); thanks for looking!
Last edited by galonzo; 07-23-2018 at 06:27 PM. Reason: update on Rampage UHD code
galonzo is offline
Reply Media Codes
blade runner , itunes , media codes , uhd , Vudu
