WTB: GoT on iTunes - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-23-2020, 10:18 PM - Thread Starter
tp2020's Avatar
Liked: 2
WTB: GoT on iTunes
Looking to get the complete series.. Game of Thrones on iTunes. Thanks.
tp2020 is offline
post #2 of 4 Old 01-24-2020, 07:26 AM
mjconnor10's Avatar
Quoted: 45 Post(s)
Liked: 32
Make sure you get a split code - don't spend too much on a full code you won't use.
(What that means is that HBO series digital codes can be used to redeem on Google Play, Vudu AND iTunes, if you do it correctly. If you redeem on iTunes or Vudu before getting the Google Play code out of it, it won't work right.)
mjconnor10 is offline
post #3 of 4 Old 01-24-2020, 08:05 AM - Thread Starter
tp2020's Avatar
Liked: 2
Understood. Thanks for the advice. Very much appreciated.
tp2020 is offline
post #4 of 4 Old 01-24-2020, 08:25 AM
mjconnor10's Avatar
Quoted: 45 Post(s)
Liked: 32
You bet. And if all you can find is a full code and aren't comfortable splitting it yourself, I'm happy to help. Just let me know.
Reply Media Codes
