The Best Budget Subwoofer - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 28Likes
Closed Thread
post #31 of 35 Old 09-11-2019, 06:03 PM
rwwear's Avatar
Liked: 0
Originally Posted by Squirrel! View Post
How does a 1000 watt, 12" subwoofer, ported, for $100 sound to you? Think it can get to 20?
Ported subs are less likely to go as low as a sealed version and generally sound poorer but anything is possible as long as it doesn't break the laws of physics. Anything called a subwoofer can theoretically go down to 20hz but the question is how loud can it it play at that frequency and how many decibels down is it.
rwwear is offline
post #32 of 35 Old 09-12-2019, 03:34 PM
BP1Fanatic's Avatar
Quoted: 227 Post(s)
Liked: 193
Buy many at a $100 a pop!
Sony XBR65x900e / STR-DN1080 / original PS4 / WOW! Ultra TV / Quantum Access Mini PC Stick w/Windows 10 / 8 x Rockville SPG88 8“ DJ PA Speakers / Dayton Audio SA1000 / Kicker 08S15L74 in a Tapped-Tapered Quarter Wave Tube (negative flare tapped horn).
BP1Fanatic is offline
post #33 of 35 Old 09-12-2019, 03:58 PM
m. zillch's Avatar
Quoted: 5332 Post(s)
Liked: 3846
Without a doubt, in many instances two placement optimized $100 subs trumps one $200 sub.
Squirrel! likes this.
m. zillch is offline
post #34 of 35 Old 10-05-2019, 07:28 PM
SQCraving's Avatar
Quoted: 18 Post(s)
I work from home a lot and have a formal home office. The office is 12x15. I like to rock out while working. I currently just have 2 Polk TSi 500 speakers but want quite a bit more bass. I really don’t want to spend a lot because I basically just use them for computer speakers run through a Denon 940. I was thinking either 2 BIC PL-200 II or 1 Paradigm DSP 3200, SVS SB1000, or maybe an HSU. I think having two $300 subs vs 1 $600 sub would fill the room more uniformly.
Does anyone have any thoughts or other subs I should consider. It would basically be a 2.2 system with the two towers in two opposite corners one on each side of m.
SQCraving is offline
post #35 of 35 Old 10-05-2019, 07:35 PM
Quoted: 2102 Post(s)
Liked: 1758
12x15?.. grab an rsl speedwoofer and be happy..
YAMAHA TSR 5790.. front l/r emotiva b1's and /or kef q100's ..BIC v1220.....Emotiva basx10.... ascend cbm 170 center.. polk t15 rears..samsung 55" j620d
bedroom .. YAMAHA r-xv 383... front l/r.. wharfedale 10.1s... ascend cbm 170 center ... Emotiva basx8... samsung ku6300 50 in
Lp85253 is online now
Closed Thread AVS Forum® Articles
affordable subwoofer , budget subwoofer , polk subwoofer
